On that subject, try and get your RPM at 55 around 1800-1900 which puts you at 70 at around 2200-2300, then you'll be right in the torque band and probably won't down shift much. But if you do downshift at 55 your rpm in third would be around 2500-2600 which should be sustainable through out the climb. That would seem like a minimum, you may even want to go lower.
97  7.3 CC 2wd Dually 140,000 mi. stock except for
DIY Intake
Transmission Just Rebuilt, Tugger Kit, Billet Converter, Steel Gear Sets, Larger Cooler
