Cheapest way to delete Check Engine after EGR Delete - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 12-18-2012, 07:05 PM Thread Starter
Hello guys,
I just did a EGR Delete on my 06 F250 6.0L and wanted to know what is the absolutely cheapest way to fix the check engine light on which is now On with P0401.
What is the cheapest Tuner that I can get? or any other way.....
miamidiesel is offline
post #2 of 11 (permalink) Old 12-18-2012, 07:38 PM
dieselmac's Avatar
Electrical tape over the idiot light.
Or an SCT Tuner.
Scott
SOLD -- 2006 F-250 PSD, Lariat
Mods: All the usual stuff
2015 F350, 4x4, Platinum
"Let us endeavor so to live that when we come to die even the undertaker will be sorry" - Mark Twain
dieselmac is offline
post #3 of 11 (permalink) Old 12-18-2012, 09:25 PM
rock_doctor's Avatar
i just look at the light as an indication that i know the truck will last longer now. Just consider the light to be a thank you from your truck. You really only need to be concerned if you live in a state that will not let you pass the state inspection with the light on. Then you need to tune it and you can do a no power increase tune. I just delete the code with my insight as i am passing the keys over to the inspector. Takes a couple starts to light back up. He would not fail it for that anyway but why poke the bear.
rock_doctor is offline
post #4 of 11 (permalink) Old 12-19-2012, 11:09 AM Thread Starter
Is there any other cheaper tuner than SCT to solve this problem? SCT is like $379
post #5 of 11 (permalink) Old 12-19-2012, 01:11 PM
some folks have had good luck just plugging the valve back in and mounting to the intake elbow flange. You can then use a SCANGAUGE II to clear the code and light until it comes back and just reclear it as needed. This will also let you see what is actually going on with your engine.
dannyboy950 is offline
post #6 of 11 (permalink) Old 12-19-2012, 05:55 PM
There has been a direct correlation that when the light is on the truck runs with different air/fuel tables as shown by different performance and economy. Some have called this "EPA limp mode". The point is the EPA tables let the truck run better. Not as much high end power but more low end power and much better economy. If i delete the code the light goes off and the mileage goes back to what it was before the delete then after a few starts the light goes back on and the mileage goes back up. Seriously, as long as it does not impact your state inspection just leave the light on.
post #7 of 11 (permalink) Old 12-19-2012, 06:16 PM
Early Cuyler's Avatar
Try a harbor freight obd 2 scanner for 37 bucks. You may have to repeat occasionally. otherwise a piece of black tape.
03 E350 7.3 psd 15 pass, stock Hi-top with tall doors,245000 mi SOLD
00 f250 7.3 psd 2rwd supercab stock,Reese electric brake controller,Firestone rear airbags, 300000
completely reliable miles,
Still starts runs and drives as new, and has been run hard. SOLD
Early Cuyler is offline
post #8 of 11 (permalink) Old 12-20-2012, 12:38 AM
Ty1
Ty1's Avatar
03-04 the lights would never come on. Some 04s and all 05s, just keeping the EGR valve plugged in will do the trick. 06-07, you've gotta have the SCT or some other aftermarket tuner to turn it off. Black tape is cheap, lol....but I'm one of those that likes to have that light incase something else happens so I can know something else is happening. Black tape will cover your light from EGR codes, but it also covers it from Turbo codes, temp codes, and whatever elso other codes that may be vital to know!
Ty (Dukey)
2006
F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~4 inch Diamond Eye Turbo Back Exhaust, DFUSER Coolant Filter, XDP EGR Delete, ARP Head Studs & Black Diamond HGs, SCT SF3 3015 w/ Custom Tunes from Matt @ Gearhead, Air Lift Load Lifter 5,000s w/ On Board Compressor System, My POV~~
Early 2004
F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~ 03 motor, Straight pipe with stock pipe, DFUSER Coolant Filter, River City Diesel EGR Delete, Ranch Hand Grille Guard, Flatbed, Regular Cab...my Cow feeding/farm truck ~~~
2008
F-350 6.4 POWERSTROKE!!!~~Diamond Eye 4 Inch Turbo Back DPF DELETE Exhaust, SCT SF3 3015R Race Tuner, Sinister MFG EGR Delete, AFE High Flow Filter~~NOT A SINGLE REPAIR!!~~~~
LONG GONE>>400,000 MILES!!!~~1999
F-350 7.3 Powerstroke 6 Speed with AFE Cold Air Intake, Hypertech Max Energy, Air-Lift Load Lifter 5,000s.............and of course a Dixie Horn~~~
Ty1 is offline
post #9 of 11 (permalink) Old 12-20-2012, 01:48 AM
Something weird with the way the system detects egr flow problems. Most 06-07 will set the codes when EGR is not flowing but some don't with no rhyme or reason.
SCT is the only way I know of and they are at the bottom of the price range for tuners with custom tunes installed.
2006 F450 CC Hauler bed 4x2 6.0 L Pstroke/Torqshift, Lariat, 4.30 r/a, SCT, 4in exhaust. 103K New heads to repair diesel in coolant.
2006 F350 Lariat CC Dually 4X2, 6.0 TorqShift 4.10 LS, SCT, airbags, 4 in. exhaust. 147K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
36 foot double tandem axle flatbed trailer.
36 foot Sooner 6 horse large dressing/ mid tack.
2003 EB Expedition 149K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 228K (no engine repairs)
2007 BMW 550i 6MT 130K
jimmy is offline
post #10 of 11 (permalink) Old 12-20-2012, 08:13 AM
HeavyAssault's Avatar
My Photos: (6)
Maybe get Power Hungry Performance to hard tune the PCM with a custom PCM strategy. Bill was able to hard tune a tow file based off my PCM strategy onto a spare PCM.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #11 of 11 (permalink) Old 12-20-2012, 08:23 AM
My X which is an 05 but has 04 running gear does set a flow light. I did some research and it seems the general consuls is, when it calls for the egr to open it looks for a temperature change in the air moving though the intake. Plus it does look for a change in the valve to tell it is moving, which is why the most common thing to do after a delete is to leave the valve in place and plugged it.
