Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 10-03-2008, 07:21 AM   #16 (permalink)
sawed off's Avatar
Originally Posted by josea1952 View Post
Where on the filter is that line to the crank case beather? Do you have any pics of the parts and areas? I'll check this morning when I get home. It's not the fart that really bothers but the engine actually surging almost cutting out "like". Thanks for the response and I'll have a look.
Jose
Jose, if you look at the engine and to the right I think its the valve cover you shoould see a 3/4" hose comming off of it, and that should be going to a tube that's attached to the turbo. If its still the oem plastic piece on it, It will be very hard to see. Its a hose thats about at the max 5" long and its tucked way under the oem plentum. If its an aftermarket tube, mines facing the firewall with an elbow welded onto it. I'll try to snap some pics of it for you.
06 F-250 Superduty
6.0 CC
Mods so far
Recon lights
Amsoil/Injen cold air intake
Raceline predator 8 20" wheels
Toyo A/T tires
High idle mod
More to come!!!
sawed off is offline
Old 10-03-2008, 08:42 AM   #17 (permalink)
josea1952's Avatar
Thanks I looked but honestly I had no idea what I was looking for....
Dingo!!!!
03 6.0
8IN Full Traction lift
King Coil-Overs
4-Link Conversion
Edge Tuner
AFE Intake
38.5 IN PC EXAT
Str8 Piped
josea1952 is offline
Old 10-04-2008, 09:49 AM   #18 (permalink)
josea1952's Avatar
Drove the truck to work to day and it was bad. I rolled the window down and it sounds like its the bov or whatever it called in these trucks going off sporaticaly and I think that is why the truck surges. I have an edge on there but I don't know if its fast enough to read the boost drops. Also it threw a P0102 or a P0104 for the MAF but not diagnostic trouble codes.
Any ideas?? Should I just start a new thread?
Dingo!!!!
03 6.0
King Coil-Overs
4-Link Conversion
Edge Tuner
AFE Intake
38.5 IN PC EXAT
Str8 Piped
Old 10-04-2008, 12:03 PM   #19 (permalink)
sawed off's Avatar
I'll see if I can't find the trouble codes for ya. As far as the tuner goes, I have heard quite a few people stating that the only good tuner for these trucks are the SCT tuners. Probably doesn't have any thing to do about it because a few people have the edge.
06 F-250 Superduty
6.0 CC
Mods so far
Recon lights
Toyo A/T tires
High idle mod
More to come!!!
Old 10-04-2008, 12:10 PM   #20 (permalink)
sawed off's Avatar
Just checked, I can't find that code being a right one. Are you sure if those are the right codes that it flashed?? Tell ya what, go to Competition Diesel Forums go to forums, then go to 6.0 technical information. Their is a sticky on all the DTC codes for the 6.0 there. See if you can match your code up to any of the ones listed. Good luck man!
06 F-250 Superduty
6.0 CC
Mods so far
Recon lights
Toyo A/T tires
High idle mod
More to come!!!
Old 10-08-2008, 02:25 AM   #21 (permalink)
all i know is i LOVE my SCT and would recommend it to anyone
-2006, Black on tan, f250 SD, 6.0l, long bed, Frontier-Gear Bullnose Bumper Replac., crew-cab, 4x2 , manny tranny, 5" MBRP turbo-back, ARP Head studs to keep that power goin to the tires and not through my hood,
SCT from DP ....
azkcr is offline
Old 10-08-2008, 11:33 PM   #22 (permalink)
Sawed off,
You are not making me feel good about this INJEN/AMSOIL cold intake system. I am planning on purchasing this January, but from what you are saying you are not happy. I have the programmer and exhaust now then I planned on opening the air to the engine. I have read in many forums for towing you need better air flow to the engine after exhaust and programmer. Is this not true?
I the reason I am set on the INJEN intake is due to the fact I am using all AMSOIL products now in my 6.0 so I thought I should go with what I know and from what I have read about AMSOIL and filtering I have been sold.
Please help me out here, now I am really confused now.
thanks....Jarrod
2005, F250, Crew Cab SB, MBRP 4" Exhaust, Autometer Pryometer (EGT) gauge, SCT XCalibrator 2 SF (Canned Tunes)
tannerj is offline
Old 10-22-2008, 06:21 PM   #23 (permalink)
Dustin58's Avatar
If you do decide to get an aftermarket kit dont waste your money and time on the airaid kits. The filters are oiled gauze and fall apart after 20,000 miles. Look for the new dry flow kits. I know afe has one and i think aem brute force has a dry flow
2005 F-250 4x4 CREW CAB
BANKS SIX GUN.
ARAID INTAKE
BOOST RELIEF VALVE
BANKS INTERCOOLER
4.5 INCH DONAHOE LIFT
MAG HYTEC REAR COVER
37 TOYO MUDS
4 INCH TURBO BACK RBP EXHAUST
4 TURBOS
3 SETS OF HEAD GASKETS
2 EGRS AND COOLERS
1 SET OF HEADS
1 TRANNY AT 47K
4 BATTERIES
Dustin58 is offline
Old 10-23-2008, 10:36 PM   #24 (permalink)
I second the AFE intake. They are really great and I really doubt you would regret getting one. They filter atleast as good as stock and breath a lot better.
Ford f350 6.0 4x4. 4" silverline turbo back, cold air intake, six speed manual tranny, sct x3.
mt454casull is offline
Old 10-25-2008, 08:52 AM   #25 (permalink)
Dustin58's Avatar
I was saying you will be wasteing your money if you were to buy an airaid kit and to purchase the afe or aem
BANKS SIX GUN.
ARAID INTAKE
BOOST RELIEF VALVE
BANKS INTERCOOLER
37 TOYO MUDS
4 TURBOS
2 EGRS AND COOLERS
1 SET OF HEADS
1 TRANNY AT 47K
4 BATTERIES
Dustin58 is offline
Old 10-25-2008, 10:37 AM   #26 (permalink)
I installed the AFE stage II with pro dry S filter last weekend on a 2000 Ex 7.3. No other mods. I wasn't modding for extra pwr, just trying to right some sorry work from the body shop after one of my daughter's driver-learning experiences. Anyway, stock batt-box/intake was re-installed after significant front-end collision, and whilst air path from filter to engine was intact, the entire inboard wall was destroyed so essentially intake air was coming from exhaust manifold. Batt box nothing to be proud of either. Originally ordered the stage I figuring I'd worry witht the battery later, but was on back order so I sprung the extra $$ for the stage II which included the batt mount tray.
Only on a week, and my wife drives it...'cept when it needs fuel....but on that one trip, I'd say the power increase is at least noticeable, if not "significant." I do sincerely doubt +50 hp claimed, though. I know this: a)the sound is louder than OEM, but not louder than broken OEM. It is however, different, and more pleasant than that made by the OEM filter box broken in the way mine was. b) the Michelin LTX's (w/10K mi on em) on the rear squealed like an Obama-supporter-who'd-just-been-asked-to-register-legally under full throttle acceleration on dry pavement and I've NEVER heard that before on this truck, even before the tire change, same brand/model tires with 100K on 'em. So there's an increase, but after one week (and a 13 mi. round trip for fuel) I can't really quantify it for you. Will repost when enough data is available to make a statement on potential fuel mileage effects. AFE kit was an easy install and generally a good pc. of gear, it appears. Filter cleaning via tap on hard surface, vacuum, or wash it in the sink. No oil. Only complaint is that the grommet supplied to mate filter indicator to box seems a fuzzloose btwn grommet and sheet metal, grommet to indicator fit is good.
aholbro1 is offline
Old 10-30-2008, 01:36 PM   #27 (permalink)
HAHA!!! that was funny.. and i'm considering getting an aftermarket kit.. but $$ is the issue as of now
SCT from DP ....
azkcr is offline
Old 11-11-2008, 02:39 PM   #28 (permalink)
I ahve a s@b intake and love it. easy as pie to isntall and never had a problem. NAyway that noise you are eharign is trubo fart. its when you let off the throttle after being on the throttle signifigantly. it is the excfess boost coming back down the intake. Nothing to get alarmed about
-Jon
2006 F250 Supercab Lariat
Appearance Mods
8" Icon lift kit, 38x15.50 mickey thompson mtz, 20x10 diamo chrome rims, Amp Power steps with led light kit
Performance Mods
S&B intake with zoodad mod, Xcal3 INNOVATIVE TUNED, 4 inchexhaust with no muffler, Autometer Phanton Gauges, Brand NEW 03 Turbo
jonnysteals is offline
Old 11-12-2008, 12:19 AM   #29 (permalink)
i'm wondering if there is anyway to prevent it.. like get rid of it, even though it sounds cool
SCT from DP ....
azkcr is offline
Old 11-13-2008, 10:07 AM   #30 (permalink)
It isnt really good for the motor. I dont rememebr the company but they make a blow off valve for our trucks. Its 800 dollars. it billet alluminium and very nice piece. personally I am saving my 800 dollars and I tought my foot to gradually let off the throttle. tada no more turbo fart; almost evryone aggrees its relatively harmless
-Jon
Appearance Mods
Performance Mods
