commandor monitor ???'s - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 06-26-2007, 08:28 PM   #1 (permalink)
I just got one installed on my truck and I have a question. The boost readings are way different then the factory gauge.When the monitor says 30 pounds, the factory gauge only reads 20 or so. Should I be worried or no? I just want to make sure I have everything hooked up correctly. Thanks
Woodster is offline
Old 06-26-2007, 09:27 PM   #2 (permalink)
Re: commandor monitor ???'s
I find this to be the case with my Banks PDA also. The stock gauge never shows over the 20-25 range while the banks will say 32 at times. They match up to the 20-25 range perfectly. The banks just pulls the info from the stock sensor also. I wonder if the stock gauge might just work like the rest. That is they don't show the high side of anything until it's really high like the trans temp and coolant temp stock sensors do. Maybe someone with an aftermarket gauge in the elbow will chime in and can let us know if their readings match the stock.
2005 F-350 FX4 XLT 4x4 CC/LB Torqshift with Diamond Back ATV Truck Cover, Zoodad Mod
Banks Power PDA with Monster Exhaust and Accufab intake elbow from Innovative Diesel
35x12.5x18 Toyo MT with 2.5" leveling kit, 2005 Weekend Warrior FB2200 for the toys
tzurick is offline
Old 06-26-2007, 11:55 PM   #3 (permalink)
Banned
Are you running this with one of our modules or another module?
It sounds like it and the reason is that the modules send a false signal, or a Capping signal to the ECM to prevent overboost from showing up in the ECM.
The Commander actually reads the signal before it gets altered.
I am not familiar with the Banks but, I am betting it is the same situation.
QuadBoenker is offline
Old 06-27-2007, 05:28 PM   #4 (permalink)
Im actually running a SCT tuner with your monitor. I wanted the eaze of returning back to stock when neccessary. The factory boost gauge will read 20 pounds while the commandor reads 30 pounds? Im just assuming the factory gauge is just like the water temp gauge? Reads to slow? I noticed my water temp gauge moves almost halfway up before the truck even reaches 120 degrees.
Woodster is offline
Old 06-28-2007, 01:23 AM   #5 (permalink)
most of the chip,programmers use a boost fooling technique which allows the engine to build more boost. stock the ecm monitors boost pressure and when it sees to much boost it will cut back on fuel,kick ses light.the after market companies only let the ecm see about 20 lbs of boost so it will not cause issues with fueling,were in reality the boost numbers are higher that is why you are seeing more boost on your aftermarket gauges,monitors. I THINK
[img]/ubbthreads/images/graemlins/shrug.gif[/img]
2011 F-350 Lariat DRW,4x4,crewcab,black with black interior.B&W turnover,Duraflap mud flaps,ventvisors,recon tailgate lightbar.weathertech floorliners
SOLD 2008 F-350 XLT, 4x4 crewcab.shortbox,swd.black with chrome pack.6 speed manual,3.73 gears.Ride Rite 2450,2158 compressor,B&W turnover ball.
Gooseneck horse trailer 4 horse elite with living quarters.
http://photos.thedieselstop.com/showgall...=1&ppuser=45952
calfroper1 is offline
Old 06-28-2007, 11:15 AM   #6 (permalink)
bcollison1's Avatar
Make sure you have the right vehicle selected in the menu.
Are you just using the Commander as a monitor?
I have the same setup. SCT/Commander.
My boost reading is dead on with the factory gauge.
2006 F-250 Lariat 6.0L PSD,CC,SB,FX4, Black with the Chrome Package with Chrome Door Pulls. Smoked windows, Rhinolined, 4" Stainless Turbo-back Magnaflow exhaust, Zoodad mod., DEE ZEE mud flaps, CCV rerouted, High Idle mod., High beams w/Fog Lights mod, Sylvania Silverstars in Headlamps and Fog Lamps, Intake Elbow from intakeelbows.com, SCT X Cal2 programmed by Eric from Innovative Diesel, Dieselsite Coolant filter, Quadzilla Commander Monitor with Fuel Pressure Kit, Autometer Oil Pressure gauge.
2008 Ford Edge Limited. AWD, Vista Roof aka Big Ass Moonroof, Navigation System. Black with Chrome 20" wheels. It has ALL the Options for an Edge.
My other toys:
2006 Rinker 232 Captiva Liberty Edition Bowrider. White gelcoat with Red band in the middle. Fuel Injected 320 HP Volvo Penta 350 with duoprops and captians call exhaust.
2004 Jayco 27BH travel trailer.
2005 John Deere 5303 64HP 3cyl. Turbo Diesel Utility Tractor with 512 Loader/Bale Spike. Too many implements to list.
bcollison1 is offline
Old 06-28-2007, 05:09 PM   #7 (permalink)
It sounds like you may not have set the unit to "Ford 6.0 liter" in the setup area. If you don't set this then you will get wrong boost readings
2007 F350 CC KR LB DRW Auto 4:10; Dieselsite coolant Bypass filter; Oilguard bypass filter; Quadzilla Commander with fuel pressure kit
longjim is offline
Old 06-28-2007, 07:39 PM   #8 (permalink)
Thanks guys ill check it out
Woodster is offline
Old 06-28-2007, 08:16 PM   #9 (permalink)
Supporting Member
powerstrokin05's Avatar
My Photos: (10)
My boost gauge comming from my elbow matches my factory gauge perfrctly! I was shocked!
2003 F650 Pickup Custom Copper Paint, 385's all around, 2007 interior (getting reupholstered soon) Recon smoked LED lights everywhere Polished Alcoa's
2006 F-350 CC short bed, 8" lift, 37" Khumo's on 22" KMC wheels. ALpine/JL Stereo, Sirius, Airaide Intake, 03 turbo, SCT Excal 2,Elbow, NOS, Spearco Intercooler, 6" stacks, 100 gal aux tank. Kelderman Airride, The list goes on! All work done by dmbperformance.com in Baltimore, Md!
http://photos.thedieselstop.com/show...t=1&thecat=996
55' Hatteras,
powerstrokin05 is offline
Old 06-28-2007, 11:08 PM   #10 (permalink)
You guys were right! I had the monitor set for a Dodge cummins.. Oops! The gauges now match perfectly and the water temp was off by 10 degrees also.. Thanks again
Woodster is offline
Old 06-29-2007, 08:15 AM   #11 (permalink)
Glad I found this thread too, I didn't know there was a HW setup for which Make/Engine/Year. Once I set mine to Ford 6.0 03-04 mine reads Boost and Temp perfect too now. Temp was always 30 deg low it seemed. And boost was always hitting 30, But Hey I was pulling hard :-)
04 F350 CC 4x4 SRW 6.0l fx4 Lariat 33" Yoko
Quadzilla Commander gauges
Some accessories
uberlinuxgeek is offline
