Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
I have a coolant filter kit which I bought from SPDiesel.com. I have a 6.0 liter diesel and I am wondering if I need to get the suppliment type of filter or the non suppliment filter. I am running the GOLD coolant. I know on the 7.3 diesels you wanted the suppliment for the SCA's. Anyone??
Dave [img]/ubbthreads/images/graemlins/confused.gif[/img]
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!! http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
Non supplemental filter. I had to make the same call when I got my kit from dieselsite.com; the extra that I got is the same one that with the kit. The filters with SCA charge are just for the engines that require SCA's (7.3)
Mark
2004 White F350 XLT, CC, SB, 4x4, 6.0L Auto, 3.73LS, Camper Pkg, Skid Pkg, Edge 2" Mini Spring Pack, Bilsteins, MBRP Exhaust, FluidAmpr, Elite Regulated Return (55 psi), Airdog, Weld Evo Velociti & LT285/75-16
Built: 11/03/03
Dave,
You do great work. Please post pics when you are done. Also, I've seen coolant filters from other suppliers that cost ~$100 more. Thanks for the line on a cheaper one.
BTW, Is your truck in Redwood Shores for some of the pics? Those glassy buildings look familiar, like some near Oracle that I've worked in.
Thanks for your comments. I live in that area so I am sometimes near the Oracle Buildings. The pics in my website are down the road at the end ao Seaport blvd. It is infront of the great Dot Bomb complex. The buildings were constructed during the Dot Com hay days and are still unoccopied. I will post pictures when I get the coolant filter done. I am still collecting parts.
Dave
Please read my other post on this subject. Our kits include the stainless bracket, as well as the new CNC machined tee for the heater hose connection.
Bob
Bob Riley, Owner DieselSite.com & BlueOvalSite.com
CPR Fuel Systems, Wicked Wheel, The PULSE
Proud Sponsor of TheDieselStop.com
GOT DIESEL? call us at 888-414-3457
How much coolant did you need to drain out before you spliced into the heater hose? I got the kit from Diesel Lite - very professional looking. Probably need to make sure those lower intercooler clamps are tight before installing. One more question: what is the change interval for the filter? My 05 KR has right at 8,800 miles and has done well - I'm trying to get 10 or 12 K just to make sure all is well under the hood before doing a performance mods.
05 F250 KR CC AUTO AND LOTS OF STUFF
If anyone who hasn't installed it yet has one of the old style brass heater hose tees, please contact me and I'll send you one of the new CNC pieces for free. I want you to have the best current version.
Bob
To answer the question, you don't have to drain any coolant out. Just lift the hose upwards as you cut it. You'll lose less than a cup full.
I purchased the coolant filter kit from dieselsite, great setup. It's been on for about a month now. I have the brass style tee, and if you are considering an aftermarket water temp gauge that style tee is the way to go. I drilled and tapped it for the water temp sender and it works great. The new style tee looks great, but would not work for what I wanted to do. Food for thought for any others out there contemplating a water temp gauge. Thanks Shawn
2005 F350, 6.0L, DRW, Racor 4500CCV, Pro Flap rears.
I haven't put one on yet, do ya'll recommend this as an absolute necessary add-on? I heard the 6.0's are dirty, all my other trucks were 7.3's and I never had any problems. I like the one from dieselsite. i have about 10k on mine now.
2005 F-350 DRW 4x4 CC
2005 F-350 DRW flat bed
Shawn, these could be drilled and tapped just as easily, but the coolant filter housing has two spare ports in it for just that purpose.
Bob
Damn, just when I thought I was almost done...another mod I gotta do [img]/ubbthreads/images/graemlins/tongue.gif[/img].
Bob, are you saying the housing is out of the box ready to screw in a temp sender? Any part of the instal process require special tools, considerations, grow an extra arm, etc?
Any chance FMC would have a problem with add on?
__________________ 03/03 (Original Factory Flash) F250 SC Lariat FX4 6L, AIC, TS Auto; 6 Bilstein 5125's; Rancho Steering Stabilizer; Toyo AT 305/70/R16E's on 16x8's; Tuff Country 2 1/2" Level kit; 2" rear add-a-leaf; UTE Bumper; Turbo Back Cool Duels; Autometer Phantom Pyro, Boost, Trans, Volt gauges; Hella 4000 Euro's; Hella Micro DE Fog's; SUV headlight harness & Hella 80/100 9007's; Clear Corners; Billet Grille; 2x60 watt battery heaters; 250 watt oil pan heater; Delo 5w40 Synthetic; Compustar Remote Start/Alarm; My Truck
