Which coolant filter system? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 11-08-2011, 07:37 PM   #1 (permalink)
07PstroKe's Avatar
Send a message via Yahoo to 07PstroKe
Probably a few thousand posts about this....Dieselsite, Sinister, etc?
All about the same price.....any better than others?
Larry M.
2007 F-350 6.0 PSD MURDERED
6" Procomp stg II w/37" Toyo M/T's on rockstars
Edge Juice
Stacked 7" straight cut
Pioneer D2 Nav
Sinister Coolant Filtration
Amsoil oil bypass
Blue spring "update"
BD Power hose/clamp kit
CFM+ Intake
6.4 Banjo bolt upgrade
LMelilloiv@gmail.com
07PstroKe is offline   Reply With Quote
Old 11-08-2011, 08:26 PM   #2 (permalink)
Feedback Score: 2 reviews
They are both the same just a way to filter coolant it is all about bling and color
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline   Reply With Quote
Old 11-08-2011, 09:12 PM   #3 (permalink)
jeffws's Avatar
I have the dieselsite filter and cant complain but I do like the blue bling of the sinister.
05 F 250 CC PSD FX4
Dieselsite Coolant Filter
Edge Insight CTS w/ Fuel Pressure, EGT and Turbo Timer
Blue Spring Upgrade
High Idle Mod
Mag-Hytec 6 Quart Diff Cover
Bilstein Shocks & Dual Stabilizer
285 70 17 Toyo's
Airlift Air Bags
18k Pullrite Superglide
06 Gearbox 295FS
00 Harley FLHR
06 KTM 525 EXC
06 Rhino 660
jeffws is offline   Reply With Quote
Old 11-09-2011, 06:39 AM   #4 (permalink)
I went with the Sinester be because of the ball valves included in base price
05 F350 6.0 AUTO FX4 SCT Extreme street by Innovative Diesel
RHJJ is offline   Reply With Quote
Old 11-09-2011, 10:46 AM   #5 (permalink)
07PstroKe's Avatar
I have had great experiences with XDP as well, plus 10% off. I heard not to run the WIX filter, isn't this what the Sinister kit comes with?
I may be stupid but are all coolant filters interchangeable?
Larry M.
Edge Juice
Pioneer D2 Nav
Amsoil oil bypass
CFM+ Intake
Old 11-09-2011, 11:58 AM   #6 (permalink)
Here is a list, I believe this list contains all NON-charged filters.
Fleetguard WF-2077
Baldwin B5089 (shorter version)(this one is less expensive than the long version)
Baldwin B5134
John Deere RE11992
Caterpillar 9Y4528
Cummins 3300721
Wix 24070
NAPA 4070
AC-Delco WF-108
Fram PR3383
Donaldson P554685
Alliance (Freightliner) WF2077
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
Old 11-09-2011, 04:16 PM   #7 (permalink)
I've only heard that in relation to the oil, fuel, and air filters, to only use Motorcraft or the exact same filter from Racor or (perhaps) Fram, no aftermarket "will fit" filters.
For coolant I haven't heard anything bad about any of them except that you need "non charged" or something like that. That list should be interchangable without problem, regardless who made your filter kit, they all have the same spin on design.
2005 F-250 XLT SuperCab long bed 118k. ScanGauge II. 3X Fumoto's. Dieselsite filter. Delvac ELC. Rotella T6. Rev-X. Improved HFCM plug. Power Service every tank. 24" wipers. PIE. AutoEnginuity. Soon to install BPD EGR cooler, OEM oil cooler, STC kit, blue spring kit, NCHornet CCV.
Idahoser is offline   Reply With Quote
Old 11-09-2011, 10:15 PM   #8 (permalink)
hawkeyediesel's Avatar
Here is a different coolant filter kit that is less expensive. It looks like a little cleaner install due to the extra hoses they include and not needing hose clamps.
6.0L PowerStroke Coolant Filtration Kit PRE-ORDER SPECIAL!! - Ford Powerstroke Diesel Forum
2006 F-250 Lariat Crew Cab | 6.0L Powerstroke | 4x4 Auto Tranny w/ 3.73 | ~105,000 miles | AstroStart Remote Start | LineX Spray-On Bedliner
Turnover Ball Gooseneck Hitch | Scangauge II w/ homemade mirror mount | Glow Shift Fuel Pressure Gauge | Glowshift EGT Gauge
Dieselsite Coolant Filter | CAT Delete Pipe | SCT Livewire tuned by Innovative Diesel
| River City Diesel EGR Delete | Blue Spring Upgrade
High Idle Mod | ARP Studs
2009 30ft Puma Travel Trailer | Approx 8000lbs when loaded up for the weekend!!
hawkeyediesel is offline   Reply With Quote
Old 11-10-2011, 10:56 AM   #9 (permalink)
07PstroKe's Avatar
I went with my instinct and bought the Sinister system from XDP. With the 10% discount I got it for $118 shipped. I like the idea of having hose clamps only for the fact in case of a line rupture, you can snip and re-clamp.
Small chance of that happening I'm sure, but the cost of a line replacement IMO would be a bit more pricey than a snip and re-clamp. Of course, this also depends on the location of the rupture.
Larry M.
Edge Juice
Pioneer D2 Nav
Amsoil oil bypass
CFM+ Intake
Old 11-11-2011, 09:04 PM   #10 (permalink)
07PstroKe's Avatar
Well, I got the coolant kit today and picked up some Fleetrite ELC from my local international dealer for $17/gal. I will be conducting the filter install and flush tomorrow morning. The kit seems to be great quality so far, guess we wont really know until there's pressure, heat, and fluid in the lines.
Larry M.
Edge Juice
Pioneer D2 Nav
Amsoil oil bypass
CFM+ Intake
Old 11-12-2011, 04:44 PM   #11 (permalink)
07PstroKe's Avatar
Got the coolant system flushed and filled with new Fleetrite ELC (concentrate). The old coolant didnt look bad at all on the first drain or the 4th. I pulled both block drain plugs, lower radiator hose, and the radiator drain. Not much sediment, no goo or honey like substance, it looked pretty good for 100,000 mile "ford gold" coolant.
I also installed the sinister coolant filter. The setup is nice, everything went smooth except for that little nylon plug at the radiator drain. All those tips about not over tightening.....well, I did just that and broke the hex portion off. Just my luck! Its in good n tight, but I will need to drill and obviously replace. Thanks to everyone for theyre advice on 6.0 coolant flushes.
Sometimes I hate beer muscles.
Larry M.
Edge Juice
Pioneer D2 Nav
Amsoil oil bypass
CFM+ Intake
Old 11-12-2011, 05:08 PM   #12 (permalink)
Sounds good but did you do a flush
2 stroker
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
1700 Super Chip
3" dp-4" exhaust
Tymar Intake
Old 11-12-2011, 07:14 PM   #13 (permalink)
07PstroKe's Avatar
2 stroker
I flushed her 4x......first flush with restore plus and distilled water. 2nd, 3rd, and 4th with just distilled water. Last fill was with fleetrite ELC concentrate and distilled water (to make a 50/50 mix).
Took me almost 4 hours without removing the thermostat. Heat up and cool downs were a bit time consuming. Next time with the t-stat removed for sure.
Larry M.
Edge Juice
Pioneer D2 Nav
Amsoil oil bypass
CFM+ Intake
Old 10-27-2012, 01:46 PM   #14 (permalink)
Ty1
Ty1's Avatar
I went with this kit here>>IPR High Flow Coolant Filter Ford 6.0 ....It's been a really good buy, I pulled out a crap ton of crud my first 400 miles. When the max A/C is on it turns into a full heater core line flow and in normal A/C or the heater on it's a 50% flow. Either way it's way more than the degas bottle line and has a washable filter. So I'm saving on filters and filtering way more coolant over less time.
Ty (Dukey)
I may be the average teenage Farmer/Rancher, but everything done to my trucks I did myself!
2006 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~4 inch Diamond Eye Turbo Back Exhaust, IPR Research Coolant Filter, XDP EGR Delete, ARP Head Studs & Black Diamond HGs, SCT SF3 3015 tuner, Air Lift Load Lifter 5,000s w/ On Board Compressor System~~
Early 2004 F-250 6.0 POWERSTROKE!!!~~6.GO!!!!!~~ 03 motor, Straight pipe with stock pipe, DFUSER Coolant Filter, River City Diesel EGR Delete, Ranch Hand Grille Guard, Flatbed, Regular Cab...my Cow feeding/farm truck ~~~
2008 F-350 6.4 POWERSTROKE!!!~~Diamond Eye 4 Inch Turbo Back DPF DELETE Exhaust, SCT SF3 3015R Race Tuner, Sinister MFG EGR Delete, AFE High Flow Filter~~NOT A SINGLE REPAIR!!~~~~
JUST SOLD>>400,000 MILES!!!~~1999 F-350 7.3 Powerstroke 6 Speed with AFE Cold Air Intake, Hypertech Max Energy, Air-Lift Load Lifter 5,000s.............and of course a Dixie Horn~~~
Ty1 is offline   Reply With Quote
Old 11-07-2012, 01:07 PM   #15 (permalink)
05_HARLEY_F250's Avatar
Just ordered the same thing from IPR, I plan on installing at the same time I install the Gen2 EGR delete.
Pros
1: reusable, washable stainless steal filter, this factor alone means it can pay for itself a little quicker.
2: this kit has bigger lines and is designed to handle full flow but can also be setup to be a bypass system like the sinister
3: mounts above the vacuum pump leaving that popular spot to the left of the radiator open for some other goodies like a bypass oil filter kit or IPR's high flow external oil cooler kit.
Cons
1: from what I can see, there are no ball valves at the cooler housing. I talked with IPR rep this morning and he verified that the kit will not include valves but reassured me that there would be no more coolant loss than what stays in the larger filters of the popular bypass kits that are already out there.
2: looks like this kit doesn't include a "bling" package other than the housing and filter.
3: this kit is a little more expensive.
Replaced stock w/stock
Radiator
EGR cooler
Head gaskets
Harley Davidson windshield
Replaced w/or added, upgraded, modded or converted.
Scangauge II
RECON Big Rig Ice running board lights, interior LED light conversion.
RECON smoke LED tail lights, third brake light, mirror lights, fire & ice tailgate strip.
ARP studs
Garrett powermax turbo
Metal CAC tube, Turbo oil supply and drain conversion
Blue spring
Fuel/water separator drain plug
Goodyear Wrangler Duratrac 275/65R20
Drilled/slotted rotors w/ceramic pads
IPR Generation 2 EGR delete.
IPR High flow coolant filtration system.
JVC KW-NT700
Coming Soon!
Rear mounted under bumper off road lights for hooking up & setting up trailer.
Frame mounted air compressor w/ 2gal. Reserve.
05_HARLEY_F250 is offline   Reply With Quote
