Could Tuner Cause This? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 05-26-2010, 06:36 PM   #1 (permalink)
Hi-The dealer just had to replace the fuel injection control module on my truck (luckily under emissions control warranty). It was throwing multiple codes. Would running a mild tune place stress on this component? I'm thinking not, but want to make sure before I reprogram it back from stock to performance tow on my Flashpaq. The first time I got a code I went back to stock, but it kept getting worse. By the time I took it in, it had 11 codes (each cylinder, the control module and two related to the fuel level sensor).
thanks,
dave
05' Dark Metalic Stone FX4 Crew Cab
6.0PSD, Automatic
Kenwood Head Unit, Eclipse AMP,Speakers, Sub
Snug Top Shell with Rack
MBRP CAT back exhaust with slash cut tip.
Raceline 17 x 9 Wheels and Toyo MT's
Flashpqaq: Currently on tow performance tune
Dieselsite Coolant Filter
Glowshift EGT, Boost , Fuel Pressure Gauges
Optima Red Top Batteries, ScanGauge2
harted is offline
Old 05-26-2010, 08:13 PM   #2 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
the tuner is very unlikely to have caused the issue. it is known that the ficms have weak solder joints and are likely to fail. i would not put the blame on the tuner for that
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 05-27-2010, 08:17 PM   #3 (permalink)
I believe that the FICM doesn't like low voltage and that can shorten its life, maybe someone could confirm that. Don't think a tuner will lower the voltage but you may want to keep an eye on the voltage in case there's an issue in the charging system.
2007 F-350 Crew Cab DRW 4X4 4.10LS, MBRP 4" Cool Duals turbo back, SCT/ custom tunes from Elite Diesel, Autometer gauges EGT, Trans, Fuel Pressure, MSD Dash hawk OBD II reader for ECT,EOT,Voltage and Boost, Dieselsite coolant filter
dougjpr is offline
Old 05-28-2010, 03:23 PM   #4 (permalink)
Thanks-I'll keep an eye on the voltage. I have had the tuner installed for over 4 years with no issues until now.
6.0PSD, Automatic
harted is offline
