Custom 5in. or 6in. Exhaust system.... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 05-28-2008, 05:12 PM   #1 (permalink)
Alexvb22's Avatar
Send a message via AIM to Alexvb22
I'm building my own exhaust system because I really can't see spending $1200 for a system w/ kinks and turns in it that will not need to be there later on after the lift. So if anyone is interested and wants to do there own I figured I'd start a thread to show how I was going to accomplish this task.
CAGperformance.com ~1-(877)-529-1935~ has Down pipes for anything. I have an 05' so thats what I got. It was a 4in. DP for $90... Also they can get you the couplers that go from 4in to 5in. and 5in. to 6in. or if you want 4in. - 6in... Ask for Chris. Really helpful.
If your putting out 450-550hp then the 5in. is your max they say. And 6in. is fine for OVER 550HP. Do it before and you'll be disapointed because you loss ALOT is all he said (bottom end). 5in. will do for up to 750hp I think I read some where before.
Then for all the stright pipes and 45* or 90* you'll need you can call your own local BIG RIG truck shop or you can call mine. 410-848-9167. Ask for Buck or Kel Gross...
Not sure on the pricing yet but I'm headed up before this weekend. The guys there seem really excited to be able to help out. Mine is going to be a dual set-up with 2 5in. pipes coming out in front of the dually tires on my truck. 6in. tips. All stright piped w/o cat and muff.
Anyhow thats it for now. I'll keep on posting about the progress and chime in with any questions or ideas.
Alex
Have:
05' 6.0L f-350 Kingranch, Crew, Dually.
SCT Tuner w/ Custom tunes
AFE XP Stage 2 Intake Sys.
ARP Studs
Egr delete
Coolent filter
Upgraded ficm 58volt
Dual Rear Straight Piped Exhaust
Looking for:
Guages-Dashhawk?...New HPOP..Stage 2 Fuel System..Injectors.. Fire Rings and ported heads-future...New Turbo... Banks Intercooler.. Torque Converter.. Tranny buildup..Stage 1 Cam.. Elbow- CFM+.. Coolent/Oil Bypass.. Circ. lines. Blow-off valve.. 8-12in. lift (rize) and Toyo 40in. M/T's
Alexvb22 is offline
Old 07-12-2008, 02:21 AM   #2 (permalink)
1200 for an exhaust? is it made of stainless?
i got my 5 inch turbo back for under $500 shipped
good luck w/ your custom exhaust. i bet it will sound good setup like that.
only issue i see is dirty wheels
gat0r is offline
Old 07-12-2008, 06:08 PM   #3 (permalink)
Just don't go to crazy on diameter. If you like the look, fine. But for performance, there are very few guys here that can actually justify over 4" pipes. You are MUCH better off focusing on impediments, like muffler/cat's. That is your enemy (flow restrictions). An open 4" pipe could run 750RWHP no problem.
Ralph
Black 2003 F350 DRW (almost nothing stock)
Other rides:
Black 2006 SRT8 300C (Mopar exhaust and CAI)
Black 2008 SRT8 Jeep (Mopar exhaust and CAI)
Black 2008 Mercedes E550 4MATIC
Pictures: http://community.webshots.com/user/ralphinnj
6L Shootout Report:
http://www.thedieselstop.com/downloa...toutReport.pdf
ralphinnj is offline
Old 08-06-2008, 08:43 AM   #4 (permalink)
Alexvb22's Avatar
At this point I'm just running into PROBLEMS with finding people confident enough to actually get, bend and install a set of five inch pipe. And I'm kinda anxious to get a set on my truck. I may just go with the MBRP 4in. duals.... turbo back.
Irritating
Have:
ARP Studs
Egr delete
Coolent filter
Looking for:
Alexvb22 is offline
Old 08-06-2008, 10:00 AM   #5 (permalink)
HeavyAssault's Avatar
My Photos: (6)
My T409SS system cost less than $300.....
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
