Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
I'm about to switch over to amsoil synthetic tranny oil and I was wondering if it would be worth the money to upgrade to a deep sump aluminum tranny pan as well. I pull a 22ft. gooseneck cattle trailer on a fairly regular basis. Most of my towing is done in town and not on the highway...Would it be beneficial to spend the extra money and upgrade the pan?
PS...what tranny is the automatic in a 2004 Super Duty?
Assuming your 2004 Superduty is a diesel, then it is a TorqShift automatic. They already have all the trans cooling you should need. AMSOIL is not the right fluid for that trans, it requires MERCON SP. AMSOIL doesn't make a MERCON SP. Now go ahead and tell me different.
__________________ Mark
Appearance:
33 in. Toyo Open Country A/T's., low profile Bullett toolbox, Herculiner bedliner, lockable rear bumper, diamond clear bumper, corner, and headlights, Ranchhand front bumper
I don't think AMSOIL makes a MERCON SP fluid. They have a universal fluid that they say works for MERCON, MERCON V, and MERCON SP. I don't believe it.
There are two 6.0L coolers. '03 and '04 had a 31 pass cooler. They downsized it to 25 pass in ''05. The difference in cooling capacity is so small it isn't worth changing if you had the small one, but you don't.
The 5R110 is a strong transmission and does not have cooling issues. An after-market cast aluminum pan whould theoretically extend fluid life, do to a volume increase, and add some rigidity to the transmission case. For the price of an after market transmission pan you can add a set of gauges or one of the PCM monitors that will show transmission temps along with engine oil, engine coolant, intake air temp, and several other operating parameters. I believe most of these monitors also have an aural warning if a temperature goes above a preset temperature. A lot of the sponsers carry them. Of course, for peace of mind, you could add all sorts of equipment, although most of us just add them them for fun.
I have been running amsoil trany fluid in my 07 350 4x4 for a year an towed a 13000 LB 5er for almost 10,000 miles and had no trouble with the trany or fluid. I did get the Mag-Hytec trany and rear dif covers for increased volume/rigitiy/ and for the additional heat disipation of the aluminum and additional volume. I build computers part time and know that aluminum will wick away heat. The heat of the fluid will wick away while its in the pan. unfortunately I did not have any gauges before for comparison.
LOL
Kurt from KC
2007 F350 SRW CC LG-BD
Airaid intake
AMSOIL bypass oil filter
Mag-Hytec Trany & Rear Dif covers
MBRP 4" turbo back (kept the cat) 5" tip
SCT Livewire runin Innovative Diesels tunes
Sneaky pipe & EGR block plate
Coolant filter
B&W turnover ball with 5th wheel adapt.
35' Sundance 5er
Just curious where you live..... The comments I have heard relative to the Amsoil fluid have been positive in the warmer, southern climates but speculate there may be a problem with it in cold weather (maybe too thick in cold weather??) I'd be curious to hear from anyone that has used it under those conditions......
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Tuning by Total Diesel Performance, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. 376hp
