Do the 60's need backpressure? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 01-18-2008, 12:04 AM   #1 (permalink)
Reaper8253's Avatar
I was thinking of cutting off my stock muffler and and clamping a piece of pipe in its place on my 6.0 until I can get a new exhaust. My question is would doing this be bad for the engine? Doesn't the engine require some backpressure? My girlsfriend's 05 cummins with the straight pipe from turbo back actually feels like it lost power since muffler and cat was removed. Will my truck lose some power and not be running as well if I cut off the muffler and leave the cat? Thanks
2004 F350 6.0 XLT, 4x4 CC, srw, Arizona beige, 3.73, FX4, short bed, 2 inch rough country add-a-leaf, MBRP 409SS 4 inch turboback (cat and muffler delete), SCT X3 w/ Innovative tunes, AFE Stage II PG7,ITP regulated return, Isspro trans, boost, and pyro on A-pillar, Pioneer AVIC-D3(STOLEN), Pioneer Avic-Z3, Alpine PDX-5 amp, JL auidio coaxials, 2 JL 8w3v3's, rear marker lights w/ 04 dually wiring harness, hornblasters shocker s4 train horn w/ 3 gallon tank, Viper security, Inductive heat flash 1/25/08
Reaper8253 is offline   Reply With Quote Quick reply to this message
Old 01-18-2008, 12:38 AM   #2 (permalink)
darsey715's Avatar
no to all the questions you asked. do it.
2003 6.0 f250
darsey715 is offline   Reply With Quote Quick reply to this message
Old 01-18-2008, 12:49 PM   #3 (permalink)
ROLLIN COAL's Avatar
i have seen it heard it and felt it, its awsome and there is alot more power do it for sure.
2011 F-350 6.7 lariat
2007 F-350 6.0L
-exhaust
-Dioblosport preditor programmer
-S&B Air intake
1993 F-250 7.3L (Non-Turbo)
1985 F-250 6.9L (Non-Turbo)
1989 F-250 7.3L
-Auora turbo
-6 inch stacks
-straight dana 60 front end
-rear lockers
-5 speed manual
ROLLIN COAL is offline   Reply With Quote Quick reply to this message
Old 01-18-2008, 05:10 PM   #4 (permalink)
Reaper8253's Avatar
Thanks for the responses guys.
Old 01-01-2009, 04:18 PM   #5 (permalink)
I just unbolted my whole exhaust system. Including the cat The truck sounds soo good. What do you suggest for a pipe size? I plan on putting a cold air intake on and a bully dog exhaust. Some people say 4" for "x" amount of horsepower, or should I just leave it 3.5"? Thanks
Mark
grappler is offline   Reply With Quote Quick reply to this message
Old 01-01-2009, 06:56 PM   #6 (permalink)
HeavyAssault's Avatar
My Photos: (6)
What you experienced is a shift in the low end torque to a higher RPM. Seems like you lost power, but it actually "moved". You have the answers, do it!!
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline   Reply With Quote Quick reply to this message
Old 01-01-2009, 09:04 PM   #7 (permalink)
Location: Greatest nation on Earth! You don't like it...get out!
And it might look something like this...if you cut the little locating pin off the mating front pipe and rotate it.
'05 Shadow Grey F-250 XLT PSD CC 4x4 LB, Build Date 8/8/04, Lariat wheels w/BFG AT KO 315/70R17's, ID's extreme tunes, Livewire, Coolant filter, Muffler Delete, 5" Chrome tip (10 plus hp there alone), Fomoto Valve, Rotella T Syn 5W40, ZooDad Mod, F350 blocks in back, Fabtech leveling kit in front, Bilstein Shocks, 800+ Watt AMP, 2-12" Subs in custom enclosure behind rear seat, Tonneau cover, Line X, UNGO 2-way alarm with remote start & turbo saver, Garmin GPS, Escort radar detector, AIC and aux backup lights on added upfitter switches, electric trailer brake module...more to come soon.
SLAPS Member#139
http://i125.photobucket.com/albums/p...k/IMG_0068.jpg
'92 Mustang GT, Black on Black and FAR, FAR from stock
Shadow_Grey is offline   Reply With Quote Quick reply to this message
Old 01-01-2009, 11:15 PM   #8 (permalink)
mt454casull's Avatar
I have the 4 in turbo back exhaust and all I noticed from installing it was a small increase in power, and a little better fuel economy. I would go with the full exhaust kit 4in, but just getting rid of the muffler will help. With the new exhaust and a cold air intake I uped my mpg by 2mpg and I am certain that I actually get more power and torque at a lower rpm. Just my 2 cents
2004 Ford f350 6.0 4x4. 4" silverline turbo back, cold air intake, six speed manual tranny, sct x3 with php tunes, ficm 40 from php, 373 rear end, running full synthetic in every part that takes oil. Arp head studs and egr delete. Coolant bypass and oil bypass.
mt454casull is offline   Reply With Quote Quick reply to this message
Old 01-02-2009, 07:08 PM   #9 (permalink)
exhaust size
I'm not going to put on a bolt on exhaust. I'm getting a custome pipe job done. Just going to put a bolt in delete pipe in place of my cat and my muffler. Just wondering if i should keep it 3.5"
Mark
Old 01-02-2009, 07:08 PM   #10 (permalink)
Thanks man. I'll let you know how it works out.
Old 01-03-2009, 11:41 AM   #11 (permalink)
Sound level w/o muffler?
What is the difference in sound levels w/o the muffler? I don't live in the woods somewhere- my neighbors are up close and personal (next house is about 20 feet away from my truck). Is it just a throatier sound, or is it seriously obnoxious? I want to keep the peace, but I would love to go straight pipes.
2005 Excursion Limited - 6.0 Turbo Diesel, Stock Rims, Dueler AT Revos 285s, Viper Alarm.
bsclayton is offline   Reply With Quote Quick reply to this message
Old 01-03-2009, 11:51 AM   #12 (permalink)
turbo bark??
Also, I read this on the comments from a Youtube video of a 6.0 straight pipe. Is this valid? : dont you know its bad to just let out of the throttle like that. It may sounds cool but you will snap the shaft for the turbo cause they are not wastegated turbos an it can only push so much air back into the intake. thats where that turbo bark comes from That's a little scary if it's true...
Old 01-03-2009, 03:09 PM   #13 (permalink)
hey bsclayton i live somewhere where the next house is 10 feet away from my truck and i removed my cat and do not have a problem with them... with removing the muffler u get a louder whistle and a more manly sounding truck... i would do it and consider removing your cat too
strokin 03 f250 is offline   Reply With Quote Quick reply to this message
Similar Threads
Why zercs on 450 ball joints, but not on 250/350, all Dana 60's CaptSkup 6.4L Power Stroke Engine and Drivetrain 9 03-16-2007 04:56 AM
Diesel engine in a 60's Deville? dust General Diesel 13 11-17-2005 10:31 AM
Late 60's GMC 3/4ton with 8V92TT Jeremy General Diesel 4 06-12-2005 07:50 PM
Confirm Dana 60's on 2002's? 1999-2007 Ordering Information 22 08-04-2001 12:09 AM
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
