Do I want to add propane - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 06-17-2007, 11:07 PM Thread Starter
I recently learned that by adding a propane kit on my truck my reg. tax will go down from $400 + to $16. Which is a considerable savings.
The truck is bone stock, with the exception of the mud flaps, and ham radio. I see no real performance reason for the add on, but to save my tax dollars, I can recoupe my investment in two years, and save $400 a year after. Even if I never turn it on.
What risk is there to damaging the motor, are there any benefits to running propane? Would it cut down on soot build up if ran?
2005 F-250 Lariat CC SWB FT-8500
89 F350, 7.3 Turbo,Dually,CC,LWB, E4OD,4:10ls,Electric fuel pump,FT-8500,laid to rest @ 204k
lwhitmer is offline
post #2 of 6 (permalink) Old 06-17-2007, 11:30 PM
Re: Do I want to add propane
Well first off I have heard it will void the factory warranty if it causes a problem to the truck. I have also heard that it sometimes creates to much boost for the turbo to handle. But the advantage it does have is more power and better fuel economy. Also you can change the setting to only allow propane injection at certain turbo psi and higher. They added it to truck a year or two ago on "Two guys Garage" and it only injected propane at 7 psi and above.
2008 Dodge 1500 Quad Cab SLT
2006 F-350 4x4 Crew Cab SB 6.0L Diesel Lariat (trade)
1996 F-250 CC SWB 7.3L XLT traded
Markford14 is offline
post #3 of 6 (permalink) Old 06-18-2007, 10:31 AM
I have heard many heads blowing due to propane use on the 6.0 liters. I don't know but this is what I have heard around here. I personally do not want it but I would call people that sell it or make propane units and ask them how it works. It might be useful to you if you can get a big discount like that. Do alot of research before buying would be my advice.
2006 F350 Lariat Dually Crew Cab 6.0 Liter 4.10 gears, SCT Excalibrator 2 with tunes from Innovative Diesel--these guys are awesome to deal with. AFE Stage 2 enclosed air intake with new part to fit the 2006 model trucks. SIRIUS SAT RADIO, Garmin 2610 GPS, Cage off road leveling kit, 5100 Bilstein Shocks, B&W gooseneck hitch, LINEX bedliner, CAMLOCKER toolbox, MBRP SINGLE 4" EXHAUST.
powerstroke6lite is offline
post #4 of 6 (permalink) Old 06-18-2007, 11:13 AM
KML
A lot of head gaskets blow on stock trucks too and some that just have programmers. Programming should add moderate power and be simple, especially if you are going to add other performance enhancers.
If you have a stock truck...........you will throughly enjoy propane injection. Increased power, and mileage and a tax break too......
It will not harm your truck used properly and it sounds like you use your truck as it was intended........
2001 F250 CC, Lariat 4x4, exhaust, chip, PS2K propane, Line-x, etc.
KML is offline
post #5 of 6 (permalink) Old 06-19-2007, 05:54 PM
I live in AZ and would like to find out more also. Where can I find the info on the registration break?
Thanks,
Johny
2005 F-250 Lariat
Turbo-Back Magnaflow Exhaust cat-less
Edge Juice w/ Attitude
ARP head studs w/ new head gaskets July 2009 98K miles
10/24/2007 Stolen from work parking lot.
10/24/2007 Recovered after 6 hours, just North of Mexco. Damage: broken passenger door lock, broken ignition lock.
1995 32ft Fleetwood Wilderness 5th
1975 35ft 3 horse living quarters goose
JohnyLingo is offline
post #6 of 6 (permalink) Old 06-20-2007, 02:25 AM Thread Starter
It looks like you register it as a alternative fuel (propane). I only know of one truck 04 PS register this way, I hope to meet with him this week end to research the story. I will let you know what I find out.
lwhitmer is offline
