Does replacing the FICM alter your tune? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 11-08-2012, 09:19 AM   #1 (permalink)
Hey Guys,
Just had to replace my original FICM the other day..
My truck had a Superchips tune on it, but the tech working on my truck discovered that my FICM was bad (cold snap in weather and it wouldn't start for them).
Now that it's back it seems to be running w/ a bit less throttle response and overall bit more sluggish than when it went in.
Is it possible that the Tune was overwritten when they replaced the FICM?
May be a dumb question but again, just trying to do some research so I know what I'm talking about before calling the shop back.
I don't have the original tuner that programmed the truck, but looking at purchasing the SCT this weekend regardless, but was more curious as to whether or not this could happen when they replaced my old FICM.
Thanks!
Fivehat is offline   Reply With Quote
Old 11-08-2012, 06:47 PM   #2 (permalink)
Okay, got my own answer. Apparently, YES, for all you new to the diesel tuning world like myself.
Old 11-08-2012, 09:04 PM   #3 (permalink)
Replacing the FICM will overwrite a tune ONLY if the FICM was programmed after the install. Once installed, you must progam the FICM, PCM, and TCM altogether- Motorcraft does not give you a choice to do it individually.
This is one reason pre-programmed FICMs are popular. You just install them and go.
Evel486 is online now   Reply With Quote
Old 11-13-2012, 10:01 PM   #4 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
to best awnser your question. when replacing the ficm, ford will typically update the ficm tunung to the latest flash which is good and bad. not going to get into that. iirc the dont have a choice as to reflashing the pcm and tcm. if you had aftermarket tuning loaded to the pcm it was over written. the loss of power could be attributed to 3 things. the loss of aftermarket tuning. a different ficm tune which is probably detuned from what your probably had. and lastly again a different pcm tune which is likely also detuned from the original. i would do a little reasearch on ficm tuning and pcm roll backs. this will give you more insight on the issue, as far as aftermarket tuning your on the right track with the sct and custom tuning.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline   Reply With Quote
Old 11-14-2012, 08:51 PM   #5 (permalink)
Thanks Lubbock,
Seems that the tech reset everything on me, FICM and PCM, with the latest flash for the 6.0L, so I'm running totally stock now.
I've been doing a lot of research on the threads on this forum and must admit my head is spinning a bit trying to make sense of the difference between CHIPS, PROGRAMMERS and TUNERS, etc...
Thanks for chiming in and clarifying on the original question.
