easy coolant filter - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 03-11-2010, 04:18 PM   #16 (permalink)
blueoval4ever's Avatar
I think that lubbockguy1979 is giving some good information.
There is a lot of plastic fittings that will not handle high temps for a long period. I have worked in Plastic Injection and know about some of the plastics used. I did look at some hose barb fittings at Tractor Supply and thought they would not hold up to the long exposure to the heat of the coolant. When I found the PE fittings I knew that these would hold up without any problems. I wanted to stay away from the brass due to the weight and the vibration from the motor. I think that the HELP fitting above would be a good item to used because it is made the same as other plastic items in other cooling systems. This is a plastic that has fiberglass strands in it. I wish I could have found it first and just used 3/8" fuel line hose.
2003 F-250 CC SB 4X4 Purchased new 6/18/2003 Sonic Blue XLT Sport Package Automatic 26,250 miles July 1, 2010
blueoval4ever is offline
Old 03-12-2010, 12:23 AM   #17 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
Lab testing vs real world is totally different. Out trucks commonly see 180+*. I personally as a licensewd plumber have seen a lot of those fittings fail in less than 10yr on hot and cold water lines at a lot lower temps than 180* more around 140-150* @30-60psi. In most residential applications vibration is not a issue where it would be in a vehicle. I guess from my exp I wouldn't use plastic barbed fitting designed for plumbing on my coolant system. Now the automotive parts I have no clue on how they stack up.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 03-12-2010, 09:52 AM   #18 (permalink)
If you want some heater hose tees, all you have to do is step up to the parts counter of any decent auto parts store and tell them you need a heater hose tee. They will bring you a Gates or Dayco assortment and let you pick the size you need.
444-4D is offline
Old 03-12-2010, 09:54 AM   #19 (permalink)
I am more confused about the whole "Bypass" deal.
The hose that is being Tapped into is for the Heater. If you run ANY Coolant Filter Kit the filter will not see much flow unless the A\C is set to Max. I guess that is the reason my first filter clogged up so fast. Plus the Wix Filter Specs has the fuel filter at 10 Microns and a Wix Coolant filter at 27 microns. I was thinking of getting a Filter Base and a Wix Coolant filter and find a 3/4 U shaped Heater Hose and a 2 foot section 3/4 of Heater Hose. Remove the hose from between the pipe under the alternator bracket and the Vacuum Control Valve. When the filter gets clogged, you would have less heat and you would know when it needs changing.
Old 03-12-2010, 01:09 PM   #20 (permalink)
Made some pictures of the Temps from a IR Gauge.
Coolant Filter pictures by DunDoneIt - Photobucket
Right side of Radiator 150 Degrees
Left side of Radiator 158 Degrees
Metal Tube near Alternator 179 Degrees
PE Tee 153 Degrees
Fuel Filter 147 Degrees
Tee from Filter to Degass Tank 153 Degrees
Degass Tank 157 Degrees
This was with motor still at idle after a couple of 0-60 burst. Had been driving about 20 minutes with a Spartan tune Aggressive Street Economy 130HP.
Old 03-13-2010, 10:47 AM   #21 (permalink)
You are not correct in your statement that the heater needs to be on max to get the flow thru the coolant filter. It is called a "bypass" system because if installed per instructions the coolant bypasses the heater control valve, allowing a good flow thru the filter. Your filter probably plugged up so fast due to the small micron rating.
'06 F350 Lariat SRW X-cab,4X4,Torqshift 5-speed Auto,w/23000lb GCVWR and many other options, Vandal Alert Cyclops, Pressure Pro TPMS, Extang Tuff TonnoIII, Duraflap mud flaps and Roadwing mud flap system, towing a Hitchhiker 33' Discover America 5'er and a Lund boat. Stock and doing fine. Coolant filter, Fuel regulator upgrade.
bobsherrie is offline
Old 05-02-2010, 02:13 PM   #22 (permalink)
Thought I would update the Mileage on my second Filter. I have gone past 24,000 miles now, that's over 2,000 now on second filter. It is still flowing like new. I also have towed my 5th at at combined weight of 19,860 lbs. With the ScanGaugeII I had a high of 212 on the Oil Temp but the Water Temp was at 204 at the same time. I guess mine did not have much sand in it or I have not put enough miles to get any sand loose enough to clog the system.
If I had it to do over again I would just use the HELP Tee and 3/8" fuel hose.
Old 05-17-2010, 08:56 PM   #23 (permalink)
Hi there just becarefull using the help 3/4x3/4x3/8 tee. I was using that tee when I added a quart of vc8 additive. With in a week of adding the vc8 the tee collapsed,and started leaking. Going to brass.
06 F250 6.0 POWERSTROKE XLT EC,LB,4WD,SRW
MBPR Cool Duals turbo back
LINE X bed liner
Bakflip tonneau cover
Harley lenses
ARP studs/headgasket,3/3/11(52602miles)
coolant filter/ Rotella Ultra ELC
Amsoil oil bypass filter
blue spring fuel pressure upgrade
Sinister EGR delete
SCT performance program
mikekavelish is offline
Old 05-17-2010, 11:59 PM   #24 (permalink)
Wonder why the VC8 would affect that coolant rated T and not the other plastic parts in the cooling system. Would the VC8 react with the brass. I am still looking for a filter I can put inline that would be light enough, small enough and that would not restrict flow. It does not take much to stop flow since the water pump does not produce much head pressure.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0
'06 40' prairie schooner 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'88 F350 Crew SRW (now parts)
'85 F7000 mechanic service, 3208na CAT
'97 Aerostar 4X4 Extended 4.0
'93 Sable 3.8
'92 Taures 3.0 sold
'84 Bronco II 2.8 4 speed 4X4
'84 Ranger 2.8 2X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline
Old 05-18-2010, 12:54 AM   #25 (permalink)
Don't Know if you have the VC's mixed up. VC-8 Should not be used in the 6.0. It was an additive for the 7.3. The 6.0 use the Gold Coolant that does not need VC-8. VC-9 is a cooling system cleaner that might cause some problems but remember the the Radiator itself is plastic along with other connectors on the Motor.
Old 05-21-2010, 09:24 PM   #26 (permalink)
cut apart filter
Filter after 4500 miles. Was stopped completely with rusty, gritty, gunk.
easy coolant filter-filter.jpg   easy coolant filter-filter2.jpg   easy coolant filter-filter3.jpg   easy coolant filter-filter4.jpg
06' F350 6.0 dually 4x4- straight piped, quadzilla
02' f250 7.3 4x4 179,000 miles
71' K5 blazer 4x4 nv4500/np 205 Geartech twinstick
dieselwelder is offline
Old 09-17-2010, 04:24 PM   #27 (permalink)
Any updates or anyone cut their filter open. I think I'll do this mod too.
2004 X Ltd 4x4 (10/03 build date) 150k miles.
ARP head bolts / Black onyx head gaskets
EGR & cooler delete, MBRP 4" turbo back.
2000 VW Golf TDI. 300k miles and going strong.
2005 Mustang Convertible. Wife's car.
1965 Mustang GT Convertible. My play car.
Don65Stang is offline
Old 09-17-2010, 08:07 PM   #28 (permalink)
FTG-05's Avatar
My Photos: (25)
I used those plastic tee's for my diy-coolant filter for my '98 Dodge Ram 5,9 gas engine. The plastic broke with only about 2000 miles on it. Never again.
If you're going to add a coolant filter to your 6.0, do it right. I'll think you'll find that putting it together yourself doesn't save any money and it sure as heck doesn't save you any time. The other upside is that all the parts will work, unlike that plastic crap.
Al
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
