Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Be very careful guys!!! I have a truck in the shop right now with a smoked engine at 9000 miles. The guy said it made a popping noise and lost all power. The Edge is still on the truck, mounted real low where you couldn't see it while driving, and the records in the module show 1885 degrees pre-turbo and 58.2 psi of boost. This guy COOKED his engine and will have to pay for it out of pocket. This is just to reinforce the theory that gauges save engines, as long as you watch them!! Obviously this poor guy wasn't watching them.
Have fun with your trucks but do it wisely!!!
1997 F350 XLT Crew Cab Long Bed PSD, Wildman chip, Bully Dog Propane, Diesel Turbo Lifesaver, 3 Inch Downpipe, 4 Inch straight pipe DIY exhaust, SD Intercooler, 160cc DIY-Injectors, Shimmed FPR, Tymar style intake, DIY exhaust brake, JVC stereo, Crimestopper remote start, Autometer Gauges, Cobra CB, B&W Turnover ball hitch, Timbren suspension enhancement system.
Pulling a 1986 Vacationeer 28ft 5th wheel and Honda TRX450ES, Honda Rubicon, Polaris Scrambler 50, and a TTR-125. 1989 Bayliner Capri.
The boost gauge is not reading correctly his truck needs to be reflashed in order for it to read te correct boost psi value. as for the 1885 degrees that is probabley correct. How high did he have max egt set on? [img]/ubbthreads/images/graemlins/phoney.gif[/img]
I haven't talked to him at all, another guy here is helping him out.
That's the only thing I can think of too. He had to be pulling a heck of a load up a big grade on the highest setting to get those numbers.
Yes, we would have been able to tell if it had been there but even if we couldn't, melted pistons is an obvious sign of abuse. Some people have more money than sense I guess.....
How would you of been able to tell if it were removed? either way you really have to be drunk or stupid to not pay atttention to your vital reading on the gauges.
No way it made 58 lb's of boost.
No way unless he had nitrous hooked to it..
1885 degrees with a stock exhaust is possible..
He must have been towing something up the side of a mountain and had the gas planted.
My guess is that there is much more to this stiry.
Sorry to say, but he had this problem coming, and I don't feel sorry for him.
We just removed the air intake and glow plugs, oil smells terrible (burnt) and there are several large chunks missing from the intake side impellor, the impellor shaft won't hardly turn either. This is gonna get expensive.
I am willing to bet it did not reach either reading. My truck has shown same readings(in memory) and I do not see them on gauge. The Attitude readings are that high often(junk). My X monitor readings are never above 1300 and 32 when the Attitude is reading those high numbers. I have the pyro to my Attitude disconnected for above reasons.
The engine might be junk but no way for those readings.
2005 Lariat,CC,SB,6.0,auto,4X4,Black/Silver accent,Lt slip,ESOF,moonroff,FX4, SCT,Hog 4"exh, Firesone Riderite, Grove air horm, x-monitor, AFE,headlight mods,etc(NASCAR=325/60r18nitto&weld evo mags,full blk,gry leather,blk carbon dash trim,liquid billet grille,chrome handles,fuel cap,tailgate,tonneau cover,IronCross running bds)
2006 Ford Five Hundred LTD, AWD
200l Honda Rubicon 500
1999 28 Thor TT
