Edge Attitude with juice-display bad - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 04-15-2010, 11:16 PM   #1 (permalink)
trs900's Avatar
My attitude gauge when in monitor mode wont display a dark enough screen to see during the day, won't adjust already tried, emailed Edge told $100 to look at it and if it couldn't be repaired then who knows so I thought maybe about upgrading display as I want to keep juice.
I wonder what new Edge product will work with my juice-3 position switch, and let me display water temp-oil temp-transmission temp, I have a Exhaust temp, sensor in exhaust manifold with the current Attitude...bought it in 2004
chargedf350@yahoo.com
2003 350 Lariat CC DRW 4x4 6.0 5 speed auto 2002 build date magnaflow #15956 turbo back & Backdraft Cobra 392 stroker & 08 GT500
trs900 is offline
Old 04-16-2010, 06:20 PM   #2 (permalink)
trs900's Avatar
I guess I can get an Edge insight and just use my juice 3 position switch manually, I know everyone recommends the SCT tuner but I have had the juice for over 6 years and have had no problem and don't want to blow any more money than I have to, does anyone know if the exhaust sensor that works with the Attitude will work with the Insight ???
trs900 is offline
Old 04-19-2010, 12:01 PM   #3 (permalink)
trs900's Avatar
Called Edge about sensor EGT probe for Attitude won't work with Insight as it requires an electronic style probe, etc.. so if I go with Insight will have to buy new probe.
trs900 is offline
Old 04-19-2010, 02:51 PM   #4 (permalink)
trs900's Avatar
Update I took a screwdriver and tapped on the bottom of the unit and screen is dark enough to see again, I always said a good mechanic only needs a hammer and a screwdriver and he can fix anything, LOL
I had already banged on it everywhere else except the bottom
trs900 is offline
Old 05-22-2010, 09:48 AM   #5 (permalink)
West28's Avatar
If you end up needing it I have an extra Attitude monitor. I switched to the A2
West28 is offline
