EDGE Platinum HOT JUICE CODE??? - Page 3 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 10-19-2009, 09:30 PM   #31 (permalink)
ptr34's Avatar
just get a sct and be done with the edge
04 CC F350 6.0
8" lift on 24's with 38
in tampa florida
ptr34 is offline
Old 10-21-2009, 04:35 PM   #32 (permalink)
Splinter Cell's Avatar
Originally Posted by lubbockguy1979 View Post
If you want to prevent it you must address the egr deficencies and make sure your heads are flat. Then use either stock head gaskets or the black onyx gaskets and arp studs. Might be a good idea to monitor your egts and other vitals.
The dealership just changed my head gaskets, so studs and/or making sure the heads aflat are out of the question (to much hassle). It looks like they put an updated gaskets in atleast the part number suggests it. They also replaced some pins and used some misc. hardware I'd imagine new bolts? I'll have to look into the EGR deficiencies?
Thanks,
Chris
"The battle, sir, is not to the strong alone; it is to the vigilant, the active, the brave." -Patrick Henry
Splinter Cell is offline
Old 10-21-2009, 09:00 PM   #33 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
they call it a upgraded kit. basically the same bolts only new and more torque is applied, contact first coast diesel performance and talk to adam about egr solutions
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 11-05-2009, 07:11 PM   #34 (permalink)
Originally Posted by CruJones View Post
I can tell you straight up, that the new platinum is not as powerful as the old chip. I spoke to Edge, and they say the same thing about toning down the power due to the trans issues. I broke down and popped for the "hot" option. The exhaust note and turbo whistle have gotten louder, and it's closer to where the old juice/attitude was performance wise, but not the same hit when the turbo comes on, also my trans shifts weird. I need to mess around with the settings, but it feels almost like a stick shift the way the truck seems to accelerate, then stop, shift then accelerate again, instead of a smooth transition. Oh well, I guess it's not that bad. Anyone want to see if the code can work on more than one truck??? Hit me up PM, and I will give it to ya.
You have to go into your trans settings and change the difueller setting, its probably at 100% lower it to how you like the trucks shifting, it will suggest transmission upgrades but ive had mine at 50% for about a year and havnt had the slightest problem with anything.
hhall1114 is offline
