Edge Tuner Question - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 11-12-2005, 09:45 PM Thread Starter
Edge Tuner Question
Does the non platinum Edge Tuner cause Transmission problems on lower levels too? I noticed that alot of you guys are always in extreme mode, I tried that once the trans can't handle it for sure, but what about level 3 or 4, can the trans handle it or is that a guaranteed meltdown as well. Thanks for the help
TYEGUY07 is offline
post #2 of 10 (permalink) Old 11-12-2005, 10:09 PM
Re: Edge Tuner Question
The earlier Edge/Attitude set up can cause problems at level 5 when driven hard). You'll experience gears revving too far, then slamming into the next, and slipping clutch plates after a while. Then shifting from park to drive or reverse will start to be delayed, and sometimes will slam into gear.
Level 3 is probably the highest level you can go with a stock tranny and be ok. I'm not saying it is impossible to do damage, but it is unlikely.
RL
Black 2003 F350 DRW (almost nothing stock)
Other rides:
Black 2006 SRT8 300C (Mopar exhaust and CAI)
Black 2008 SRT8 Jeep (Mopar exhaust and CAI)
Black 2008 Mercedes E550 4MATIC
Pictures:
6L Shootout Report:
ralphinnj is offline
post #3 of 10 (permalink) Old 11-13-2005, 12:24 AM
call edge and they will give you all the 411. i think edge has something for you to reprogram the trans..
shiftkx is offline
post #4 of 10 (permalink) Old 11-13-2005, 12:18 PM
what do you mean 411,and reprogram the tranny?
2004 f-250 supercab. edge juice w/att.{just for the gauge and backdown.} sct custom tunes from ID. baldwin coolant housing with wix coolant filter,homemade mount. extang tonn. cover
fordman13 is offline
post #5 of 10 (permalink) Old 11-13-2005, 12:30 PM
ritschner's Avatar
Send a message via AIM to ritschner
I think he means information (411). Edge makes a transmission only tuner. You might want to call Mark Craig, I understand he has them in stock. Thats what I plan on doing since I also have the Edge/Attitude. DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM
White 06 F350 Lariet CC 2WD DRW Tow Boss, Timbren SES, Bilsteins, Smiths Ultimate Bedliner, RK Tool Box, CondensorGuard, IntakeMod, S&B Intake, SEIC, Banks 4"TB, Accufab elbow, Edge Attitude CS, Blue Spring Mod, DCPower 185a alternator, Rebuilt FICM, STC and Standpipe update, Harpoon Mod, Coolant Filter, Glove Box Light, Hood Insulator, Rewired Mirror Heat, Seat Heater Indicator.
ritschner is offline
post #6 of 10 (permalink) Old 11-13-2005, 12:31 PM
teamroper60's Avatar
411= "street slang" for info
Edge has the Evolution out with a "Trans Only" tune in it that is made to stack with the older Juice module. I have it and it works really well!!
#43
President and Webmaster
teamroper60 is offline
post #7 of 10 (permalink) Old 11-13-2005, 01:00 PM
Right, but if you have an older Edge or Edge/Attitude, you can damage the tranny or TC. How much is the Evolution upgrade you mentioned?
RL
Other rides:
Pictures:
6L Shootout Report:
post #8 of 10 (permalink) Old 11-13-2005, 05:11 PM
411= information.
opps few of you guys already said that [img]/ubbthreads/images/graemlins/smile.gif[/img]
edge for president!!!!!!!!!!!! [img]/ubbthreads/images/graemlins/smokin.gif[/img]
shiftkx is offline
post #9 of 10 (permalink) Old 11-14-2005, 09:56 AM
TYEGUY07,
The Edge Juice/Attitude Platinum has all the trans controls that you need to make your tranny live a long life. If you need trans only tunes you need the Edge Evolution programmer, it has HP programs too but you can load the tranny tunes by themselves that allow you to make all kinds of trans adjustments without adding HP to the engine, or you can do both if you want. Call us if you have any questions etc.
Mark @ DPPI
Mark Craig is offline
post #10 of 10 (permalink) Old 11-14-2005, 12:59 PM
I have a Juice Platinum now, but I started with a 6 gun. Banks has a "transmission learning procedure" that says to start out at level one, and then do three runs from 0-60, then one run from 30-60 in top gear so that it will downshift, and then keep increasing the level untill you are at the level you want to keep it on. If you encounter any slippage on the next higher power level you are supposed to go back and do the "procedure" again on the previous power level. I had mine running level 5 with no slippage at all. So it works, but you can't be running around in level 1 and then go to 5 at a light to drag a duramax and expect it to be fine. The torqshift adapts to the increased power and will handle it if the learning procedure is done correctly. I have my Juice running "HOT" level 6, w/ 40" tires and I don't get any slippage. Try doing the procedure and see what happens.
04 Crew cab Lariat, 6.0 w/torqshift, 03 turbo retrofit, 11" lift, Deaver springs, 40" X-terrains w/ 4.88's, 20x12 KMC Black Rockstars, Juice Platinum, 5" Bulldog exhaust, AFE stage 2,
Fox 2.25" reservoirs, ORU dual shock hoop, and crossover steering, and trac bar relocation kit.
CruJones is offline
