EGR delete, Will fan work or not ? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 01-26-2011, 10:27 PM Thread Starter
Hello all you 6.0 owners. I have a 2003 F 350 6.0 . I have been reading alot of posts/threads on egr delete and this is something I really want to do to my truck because I think it cant be a good thing pumping exhaust back through the engine. The theory behind the delete all makes perfect sense to me and it all seems like positive results in the end except for one thing that I cant get a definite answer out of all the reading that I have been doing, will the coolant fan work after the delete or not. Some say that they just put the egr valve in and plug it up and the valve no longer is functional but they plug it in. Some use the block off plate. I have read the info about how this disables the fan and Im trying to find out how to handle this. I want to do the delete but I want my fan operational also. Thanks for all the valuable info and keep up the good work forever
Superduty_Will is offline
post #2 of 6 (permalink) Old 01-26-2011, 10:53 PM
I have an 04 and did the full egr delete (new up pipe instead of just plates). I have not heard anything about the fan shutting down so maybe some one else can help with that question. I would recommend the egr delete though because it first and most importantly eliminates the egr cooler that is prone to burst, even though 03s and 04s had the better round style cooler (mine did), which prevents coolant into the intake. Secondly the coolant no longer is heated by exhaust gasses and finally no inert gas going into the combustion process. Hope this helps the decision to delete. Fan question though, sorry no help.
ars5147 is offline
post #3 of 6 (permalink) Old 01-26-2011, 11:00 PM Thread Starter
Thanks ars5147 , I like the sinister kit with the new up pipe it definetly looks like the way to go. Do you know if your fan is working alright after the delete ? Some people said that they didnt even know that it wasnt working after the fact.
post #4 of 6 (permalink) Old 01-26-2011, 11:07 PM
tuckman's Avatar
Depending on your strategy you may have to keep the egr valve plugged in under the hood with a full delete but most 03-04's don't need to. My 05 needs the valve plugged in.
2005 Excursion Limited 6.0 4X4
Leveling kit,
Swamps 58V, PHP tuned FICM
Edge Insight
SCT tunes by Quick Tricks
Sinister EGR Delete
6.4 banjo bolts
Ford fuel pressure spring kit
Excursion High Idle Mod
Cat EC-1 coolant and a Sinister coolant filtration kit
Magnaflow Turbo Back with muffler
ARP's
Powermax turbo
Retro-Solution Digital HID
tuckman is offline
post #5 of 6 (permalink) Old 01-26-2011, 11:11 PM
Not sure on what you are talking about with the fan but Ive had no over heating problems and no codes or electrical problems. That isnt supposed to be a problem on 04 and 03 but 05 and up will throw codes without the valve plugged in. I just left my egr valve in. Makes no diff in or out and the plate after the delete. This is the kit i bought
FORD 6.0L 2003-07 EGR DELETE F250 F350 F450 POWERSTROKE - eBay (item 300495522566 end time Dec-01-10 0026 PST)
Ive had no problems with it so far
ars5147 is offline
post #6 of 6 (permalink) Old 01-27-2011, 12:05 PM
Never heard that before. Easy to test. Hook up a scanner and command the fan and see what happens.
lenzhotrod is offline
