Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
What is the difference in egt's pre turbo versus post turbo. I got the EGT probe right behind the turbo in the downtube of the exhaust. i was just curious if anyone out there had any experience pre vs. post turbo egt's..
thanks
06'F250 6.0 SWB Supercab. Edge juice/attitude. 4" turbo back exhaust with test pipe..... I love it!!
Pre-turbo readings will tell you how hot the exhaust gases are as they exit the engine and head toward your turbo. This tells you how hot your engine is running and is handy for preventing catastrophic failure to the engine and turbo.
Folks with pyros in both locations on the same truck have reported some very drastic differentials in the two readings with the post-turbo readings being well below that of pre-turbo. They also report that the differences are not linear. So nothing of significant value can be obtained from a post-turbo reading that would help prevent a catastrophic failure. It might be handy for knowing when your turbo has cooled enough to shut down, but that's about it.....
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03, (still running the original flash!), AIC, MBRP turbo-back exhaust, Tuning by Total Diesel Performance, AFE PG7, Fumoto valve, B&W hitch, Di-Pricol gauges, Voyager brake controller, DIESELSITE Coolant filter, Timbrens, Rancho RSXs, Michelin XPS Traction's, a whole bunch of "bling", Connex 4300hp, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers. 376hp
I run one in each manifold and one post-turbo....the post pyro generally runs 250 degrees cooler than the pre's
...coming soon... 2004 Twin Turbo 5.9 F250 Hellmann Performance
Direct Injection Performance
TS Performance
DI Performance
Greg Hogue
Grand Rock Exhaust
Dynomite Diesel
DC Customs
I agree, post 250-300deg cooler.
I like having the post turbo to see the temps drop for cooldown.
The pre turbo(manifold) temp drops way faster than the post at cooldown.
2006 Harley Davidson F250 6.0L-PSD #02250
Bully Dog--Triple Dog w/Outlook
MBRP Turbo-Back 4in SS off-road Exaust
Airaid cold air intake, Zoodad, PDP Intake Elbow
FabTech lift W/ Dirt Logic 2.25 shocks
Stock HD 20in rims & tires, Line-X, Roll-N-Lock bed cover
Viper Remote Start Alarm
Eclipse TV/DVD/NAV,Custom TV in center console, JL 500/1 on 2 10W3's, JL 4ch on 5x7 Boston's
I am currently installing my gauges and was wondering the same. On the large marine applications all cylinders plus "stack"/post turbo/turbos are monitored. On some vee blocks its left and right bank plus post turbo/s.
Why is post turbo bad on the 6.0? Isspro sells gauges for both pre and post turbo readings.
I guess I just don't like having the probe so close to a cylinder outlet only on one side of the engine. What if the other side has a problem?
I don't mind pre turbo, but it seems the current location is #8 cyl. (I think) vs. pre turbo.
I'm interested in hearing more pros/cons.
Mark
SOLD - 1994 F250 4x4 S/C 7.3L idi with Banks Sidewinder turbo & Monster exhaust, 4.10s, 5speed (with LUK clutch) and Racor 500fg filter/separator, custom seat. (the Mule)
2003 F250 4x4 C/C 6.0L Powerstroke. The "grocery getter/family car"/the new MULE <img src="/ubbthreads/images/graemlins/smile.gif" alt="" />
"I don't think post turbo is a bad thing. I just think most people want a reading of the hottest part of the engine and that would be pre-turbo"
I agree, my only thought is having the reading only representing one side of the engine. Ideally we should be reading both "banks" vs one side only. If not sensing both, it should be sensing all. Maybe I need to get a "dual" pyro.
Does anyone know it the down pipe is "thick" enough to TAP?
Mark
I think they make a clamp on setup for the down pipe as one option.
1998 E350 7.3 extended with 93000 miles and stock drivetrain. Late model doors with power windows, locks and mirrors.Isspro gauges from DPPI, 5 speed chip from DP Tuner,Power Slot Cyro rotors from DPPI, Hawk LTS from DPPI,NAPA DOT 4 brake fluid,NAPA calipers,Evans coolant,Dieselsite ac control valve,Dieselsite 203* thermostat,BTS valve body, Amsoil tranny fluid,4WD deep tranny pan from Dieselsite, DieselSite transmission bypass filter,Amsoil dual oil filter, Amsoil 15-40 wt oil,4 inch Warpspeed Performance exhaust,Thermo-Tec Exhaust Insulating Wrap, Bilstein shocks,
My EGT probe is installed post turbo.
However I'm considering a pre turbo also.
Correct me if I'm way off base here.
My idea is mounting the pre turbo probe into the opposing exhaust pipe?
You'd get nearly the same reading as in the manifold with greater ease of installation.
All 8 cylinder and dual bank probe installations along with post turbo seems like OVERKILL to me.
Ken Kill Sr.
2005 E350SD 6.0L PSTD
SMB RB15 Modified
All Electric
Yes, ISSPRO makes clamp-on thermocouples (R650A-HT is a popular one).
As far as drilling and tapping downpipes, I can't speak for factory 6.0L pipes, but I can confirm that I was able to do it on the Tymar downpipe on my OBS. I recently installed a post-turbo thermocouple and gauge. So far it appears to work as I expected. When temps are going up, it lags the pre-turbo by as much as 400 degrees. When running steady-state, it tends to slowly approach the pre-turbo readings (but never getting quite as hot when the temperatures are high). When cooling down rapidly (like driving downhill after cresting a hill) the post-turbo is hotter by 150-200 degrees. I would be interested to hear anyone else's data, to see if the truck type and set-up has much influence on these readings.
Thanks,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 255k miles (Ford rebuilt E4OD at 226k)
ISSPRO Prototype Performax gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Edge Evolution on "Tow", Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 doorslammer drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
NRA member and certified firearms instructor
GOA member
IDPA member
I guess I just don't like having the probe so close to a cylinder outlet only on one side of the engine. What if the other side has a problem? Mark
if there is enough of a problem with your fuel delivery that you notice it on the pyro you will FOR SURE notice it in the SOTP meter.
there realy is no reason to monitor both sides, if there is significant variance you will feel it in the lose of power.
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me. '86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
The reason being is that the farther away you go from the heat source the less sensitive to changes it will be.
In addition, you are checking EGT to keep chamber and exhaust valve temps in check, if you measure post-turbo, you are measuring the temp AFTER all the pieces have had a chance to deal with that heat
Just my opinion but drilling and tapping an exh manifold is so easy, I dont see any reason not to go that route
- 2008 XLT Crew Cab 4x4, Tow Command, Camper Special
- 2007 Lariat Crew Cab 4x4 - GONE
- 2002 F250 S/C 4x4 PSD, 4 inch turbo back, zoodad, pre-pump and tank mods, QLJ5/PMT1 Tipton Econotune, Sonnax/Tricumulator, ISSPRO under cubby mount gauges, Prodigy controller, 3.5 inch rear blocks, KYB Monomax Shocks...GONE BUT MISSED
- 1971 F100 Ranger XLT shortbed 4x4, hotrod resto
- 1970 Fastback Mustang, 489 cid FE, TKO-600 5 speed, 3.70 9 inch, ported KC alum heads, giggle gas
- 2007 HD Street Glide, Vivid Black, 96 inch 6 speed
