Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 04-11-2007, 06:55 PM   #1 (permalink)
bcoakley's Avatar
Exhaust Brake
I have a 2005 F250 6.0SD 4x4 with automatic. I tow 12,000 pounds plus and it can sometimes be a bear to slow down on a steep grade. I see That BD now makes an exhaust brake for the 6.0 automatic. If I was to use this does anyone know if it will affect my warranty?
2005 Arizona Beige F250 6.0PS automatic, MBRP 4" turbo back, AFE stage I, Diablo Predator programmer, B&W turnover ball gooseneck with 5th wheel companion, Firestone airbags, Dipricol gauges, B&D exhaust brake, Bedrug and Snugtop SL tonneau cover, Zoodad mod.
bcoakley is offline
Old 04-11-2007, 08:14 PM   #2 (permalink)
Re: Exhaust Brake
Well, I have a BD exhaust brake on my 05. I was told by the installer that they don't work as well on an auto trans. It works great on the 6 speeds. As far as warranty, I do believe it will void any warranty if the brake caused the part to fail. I took that chance. I also talked to someone first hand who has ran the BD brake for over 200K on two different trucks and never had a problem. I would talk to your dealer and see what their take on the brake is.
2005 F350 6.0 PSD srw lb sc Zf6 speed
mods: BD exhaust brake- Dura flap mud flaps-Piaa back up lights-Wilson cell amp and antenna-Midwest short throw shifter--C-Betr mirrors-Burning B100
wdwkr is offline
Old 04-11-2007, 10:22 PM   #3 (permalink)
My Photos: (9)
Re: Exhaust Brake
how well does it work on your automatic? is it worth having?
2004 CREW CAB PSD, no mods, 305/70/16R wrangler MTR.
1985 ford f-250 4x4 6.9l sc. "the beast"
http://photos.thedieselstop.com/show...hp?photo=18913
hougie is offline
Old 04-12-2007, 01:21 AM   #4 (permalink)
bogg's Avatar
My Photos: (5)
Re: Exhaust Brake
I cant imagine having an issue slowing my truck pulling 23k down any mountain here in the west. The Tow Haul mode in both of my 6.0's have never left me wanting to change. 80k maybe...
07(built 06/06) 6.0 Lariat/Moonroof/Camper Pkg/ FX4/DRW/5spd TS/13K GVWR/4.10LS/CC/LB/F350: Accufab Elbow/Mag-Hytec/AutoMeter Tripod(EGT/Trans/Diff)/PIE-Sirius-IPOD/Infinity Speakers/Zoodad/Fumoto/IH-HFCM/Precision Grill/Special Edition UT Weatherguard Crossbox/Coolant flush@25k/Coolant in-line Filter/MBRP 4" Duals/ My Truck Pics:
http://good-times.webshots.com/album...ost=good-times
bogg is offline
Old 04-12-2007, 02:19 AM   #5 (permalink)
Re: Exhaust Brake
hougie--I don't know how well it works on the auto since I have a manual trans. But on the manual it works very well. Not as good as a real jake brake though.
bogg--I would have to say the exhaust brake on a manual works better at slowing down a load than the tow/haul alone on an auto.
rideblue--I see you have a programmer. That will void the warranty. So having an exhaust brake is just more noticable.
wdwkr is offline
Old 04-12-2007, 06:10 AM   #6 (permalink)
Re: Exhaust Brake
I don't know about the other tuners, but Innovative has a tune called agressive tow. One of the features is an exhaust/jake brake function. from what I read on their site and heard from others is the turob functions as an exhaust brake. They can probably answer your questions better than me. Keith
2004 F350, Lariat, True Blue/Arizona Beige, CC, LWB, 6.0 PSD, Torqshift, FX4, Camper package, captains chairs, power & heated TT mirrors, adjustable pedals, AIC, dual alternaters, power sliding rear window. C-Betr mirrors, ARE K series cap, Bedrug, BFG MT 285/75r16,overhead DVD player, DPPI turboback dual exhaust, gauges, Husky mudflaps, Weather tech vent visors, and Lund bug deflector. Date ordered 12/23/2003. Delivered 2/5/04
http://community.webshots.com/album/122797684QJFiJY
MD-TDC Secretary
ktpauley is offline
Old 04-12-2007, 08:56 AM   #7 (permalink)
guardrail22's Avatar
Re: Exhaust Brake
three observations
12000# is very near the limit for the F250 so you are at the outer edge of capability on things like brakes etc.
an exhaust brake retards the engine speed to create braking effect. on a std transmission, this is effective because with clutch fully engaged, the drive line is solid from crankshaft to wheels.
for an exhaust brake to work on an automatic where there is normally NOT a solid driveline because of the torque converter, the brake is only going to work if its control features include a torque converter lockup.
This can be done by using tow haul mode on the Torqshift transmission.
I'd first have the trans and PCM checked to insure tow/haul is working. Exh brakes are a $1000-1200 deal plus install. I looked into it briefly and decided against it because I couldn't buy just the brake (alrady have 10gal of 125psi air on board).
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Ford Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver
New Truck
http://www.f150online.com/galleries/....cfm?num=15052
Traded In Nov 07: 2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch, Adv Security Group, Clearance Lights, Adj Pedals, Privacy Glass, Sliding RW
Delivered 11/27/2002
7100# with full fuel and no occupants
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
http://www.f150online.com/galleries/...w.cfm?num=3016
guardrail22 is offline
Old 04-12-2007, 12:57 PM   #8 (permalink)
Re: Exhaust Brake
three observations
BD has the torque converter lock up function that must be used with the auto trans. Here is more info on the brake. http://www.bd-power.com/ford/product...es&tt=ford
I had my brake professionally installed by a BD dealer it was $1750.00 installed. I am hoping that the cost will justify the brake over the life of the truck. But I got the brake more for safety than cost.
wdwkr is offline
