Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 07-20-2006, 05:00 PM   #1 (permalink)
Exhaust brake with the VVT turbo
Has anyone here rigged up a way to use the VVT turbo as a exhaust brake? I know that innovative has there jake brake tune but you can't* turn it off at will
Anyone?
2005 250 6.0 4dr Short *6 Speed* FX4 4x4 Lariat
Innovative SCT, ARP Headstuds, BD short shifter, MBRP 304 Duals Turbo Back, Trans/Flow 46gal Repl. tank, Rancho 4 inch kit w/ skyjacker coils, Firestone Air bags, custom onboard air system 2 viair 420c compressors, Train Horns, Bestop Power steps, Pioneer DVD-6300 in dash monitor, 37/13.50R20 Toyo M/Ts on Driv Tremor 8, 400rwhp 788rwtq
Other Money Pits:
2003 Sonic Blue Kenne Belled Cobra 660rwhp 575rwtq, Cannondale Cannibal 460, 32ft United Expressline Race Goose
ViperKiller is offline
Old 07-21-2006, 11:25 AM   #2 (permalink)
My Photos: (9)
Re: Exhaust brake with the VVT turbo
I don't think its possible without causing problems. the VGT turbo uses signals from the PCM to close and open the vanes. If these signals are boogered with its bound to set a code and cause operational troubles. Easiest and safest way would, in my opinion, be to do it in the programming.
2005 F-350 XLT PowerStroke Diesel FX4
SCT Xcalibrator2 with Tunes from Innovative Diesel
37 X 12.5 BFG Mud Terrains *No Lift-See Pics Below*
5% 3M Tinting
Viper 791XV with Remote Start
152dB Kleinn 3-Trumpet Horn System
Dakota Digital Gauges
T409 MBRP Straight Pipe
AFE Stage II Intake
HARPOONED Fuel Tank ::click, click, drive away::
2003 10 Vane Turbocharger
Blacked Out Harley-Davidson Edition Headlamps
ARP Head Studs
Mods Very Soon to Come:
HID Lights
Code 3 Lightbar/Highway Strobes
Rear Reciever Mount Winch
AVIC-Z2 In-Dash Navigation Sytem
Nathan K5LA 5 Bell Train Horn
Road Armor Rear and Front Bumpers
My Pictures
cmirabile is offline
Old 07-21-2006, 02:42 PM   #3 (permalink)
I really dont think it would be a problem. All you would have to do is give the EBP sensor a false "correct" reading. Then use a electronic module to put out the correct PWM signal to close the vanes in the turbo. Since the CVT solenoid is not a stepper motor (like the egr valve)it should not return a signal to the PCM (strictly a pcm output). The all you would need it a switch to arm and disarm it.
Im actually quite surprised no one has done it yet, especially for us manual guys.
I'm going to be pursuing this venture and ill keep those who are interested up to date.
Other Money Pits:
Old 07-21-2006, 04:53 PM   #4 (permalink)
My Photos: (9)
[img]/ubbthreads/images/graemlins/wink.gif[/img] See, I knew that If I had it wrong some one would correct me and give him a good answer. Thanks.
5% 3M Tinting
AFE Stage II Intake
ARP Head Studs
HID Lights
My Pictures
Old 07-21-2006, 08:13 PM   #5 (permalink)
Roy_Boy's Avatar
I will add my 2 cents and say we have enough trouble with the turbo to be adding the stress of an exhaust brake to it.
Just do it right and put on a REAL exhaust brake, worth every penny to me. [img]/ubbthreads/images/graemlins/smile.gif[/img]
Roy
2004 F350 super cab short box dually
One of a kind
6.0L, 6speed, 4x4, 3.73 axles
US gear exhaust brake
Custom SCT,tuned by Tadd
Engine#3- 6398 miles (still running great)
Haulin' More than most of y'all
02 VW Beetle TDI 5 speed
Roy_Boy is offline
Old 07-21-2006, 08:30 PM   #6 (permalink)
I wouldn't be so sure... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
It's a viable and safe prospect for a less expensive exhaust brake. Enough said.
Proud to be a sponsor of thedieselstop.com
Test Fleet
2001 F350 Crew Cab 7.3L
2004 F250 Crew Cab 6.0L
2004.5 Dodge Ram Cummins
2006 Jeep Liberty CRD
2007 ML320CDI
Soon To Be 2007 Dodge Ram 2500 6.7L
http://www.spdiesel.com
"Can your Resistor do this?"
spdiesel is offline
Old 07-21-2006, 09:46 PM   #7 (permalink)
The EBP sensor is no longer used.....
Inferred EBP Description
• 6.0L diesel engines use the EBP sensor for control of the
turbocharger and EGR systems
• With the implementation of the 03.25MY 06E17 action the
Powertrain Control Module (PCM) eliminates the use of the
EBP sensor input.
– Exhaust Backpressure is now “inferred” through the use of inputs
from the MAF, MAP, BARO, and EOT sensors. These sensors now
provide a more critical function for turbocharger control.
– As a result, the new PCM function places increased importance on
MAF input, MAP input , turbo performance, intake integrity, exhaust
integrity, etc. It is possible that driveability issues may arise or be
more pronounced following 06E17 update.
– Aftermarket equipment such as intake or exhaust systems also may
have a more adverse effect on vehicle operation following update.
• Following calibration update or KAM clear it is necessary to
allow the PCM to execute an adaptive turbocharger learn
process which exercises the turbocharger at idle to “learn”
control duty cycle for optimum performance.
NoStatic is offline
Old 07-21-2006, 11:11 PM   #8 (permalink)
InnovativeDiesel's Avatar
EBP sensor input.
The EBP sensor isn't used on late 03 and really early 04 trucks that have the latest reflash. Other than that, it's still used in all the other trucks.
Innovative Diesel Performance
410-620-3020
http://www.innovativediesel.com
The Original SCT Custom Tuning Dealer!
We are the first and most experienced custom tuner for the 6.0L truck!
*No gimmick's and no marketing ploys.*
Only the best custom tuning, from stock to highly modified trucks. We have a proven track record and tune the fastest and most powerful Ford vehicles in the industry.
IDP thrives on carrying only the best parts and great customer service. Over 5000 parts ready to ship for your diesel truck!
InnovativeDiesel is offline
