Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 08-13-2004, 09:11 AM   #1 (permalink)
taztruck's Avatar
exhaust manifold removal
Has anyone removed the exhaust manifold to drill and tap for the pyrometer? Anyone have any helpful tips for removal and re-installation? I thought it would be safer to remove it for drilling and tapping, but now I am worried about the bolts sticking or breaking off on removal. I have also read the you should replace the studs with brand new SS hardware for re-installation. Now it seems to be more of a PITA to R&R the manifold to keep all the shavings out of the turbo than just drilling and tapping it in place!
2003 F-250 (Built 1-03, Engine built at Huntsville plant on Sept. 20, '02), 6.0L, 4x4, CC, Moonroof, Pwr Pedals, FX4, King Ranch, DRL, Leer 100XL cap, Bed Rug, AIC, Prodigy control, Delphi Skyfi XM radio with line input to OEM 6 CD changer using P.I.E. FRDN-AUX Auxiliary Input Converter and Auto-Power On Adapter for SkyFi, Centramatics, Putco Virtual Vertical Grill, Fumoto Drain Valve, AFE ProGuard 7 Intake, B27.9 Flash, BD X-Monitor with Cool Engine Shutdown Module. Dieselsite coolant filter and Oilguard by-pass filter.
2001 5.4L F-150 7700, 4x2, SC, Bi-Fuel Propane, Westin Bars, DRL, Fumoto Drain Valve
Photos
taztruck is offline
Old 08-13-2004, 09:24 AM   #2 (permalink)
Re: exhaust manifold removal
The majority here drill and tap in place with no issues to report. Just be careful and make sure to vaccumn the hole well and BTW , I believe using grease on the drill bit and tap are not a good idea for the simple fact that if shavings do end up in the manifold it would be impossible to vaccumn out. Take it for what its worth. Just my opinion. It worked well for me.
jward is offline
Old 08-13-2004, 10:15 AM   #3 (permalink)
My Photos: (13)
If you do decide to remove your manifold, use an air wrench. Start with the torque setting on low and turn it up until you have enough torque to remove the bolts/nuts. The pounding action of the air wrench helps break loose any rust that may have developed. I never attempt to remove exhaust bolts/nuts without the use of an air wrench. (I've never broken a bolt yet while using one)
Good luck!
Brian.
2004 F250 Lariat, Diesel 6.0L, 5spd auto,4x4 FX4, True Blue/Med Parchment, Camper Package, Cab lights, Dual Alternators, AIC, Power Sliding Rear window, 12.5k receiver hitch.
Add-ons: Headache Rack, Brush Guard, B&W Hidden Hitch & Daytime Running Lights, PIAA 520 series driving lights, boost/tranny gauges, Dahl 100 fuel filter/water separator, Prodigy brake controller, air horns.
In-the-works: Onboard air, Aux. fuel/Toolbox combo, Thermocouple installation.
Ordered on: 03/29/04.
Arrived on: 04/28/04.
SIGNED: 05/01/04 Whoop!
Recall 04B24: Installed 02/15/05.
My Pics
6.0L Bible
PoppaSmurf is offline
Old 08-13-2004, 11:48 AM   #4 (permalink)
My Photos: (11)
Good luck!
Brian.
Using a impact/air tool to remove these was what I was told to do after I twisted one of the bolts in two that holds the up pipe to the turbo at the manifold. This was on my Van that was only 3 month old. I believe these are class 8 bolts and after being heated and cooled many times are easy to twist in two.
Larry
keeper of the <font color="blue">"little secrets" </font> CLICK HERE [img]/ubbthreads/images/graemlins/smile.gif[/img]
<font color="green">MY PICTURES - Look around ... lots of good stuff </font>
2001PSD(PCM:HPI2)SD E-350,Dk Emerald Grn,4.10LS, <font color="blue">Mustang dyno - 183.9/400.4 stock</font> [img]/ubbthreads/images/graemlins/smile.gif[/img], BTS w/Schaeffer's ATF[img]/ubbthreads/images/graemlins/biggrin.gif[/img] , ITP 3.5"/4" exhaust w/Magnaflow & Aeroturbine,Dieselsite 203* T-stat/Zerex G-05,F.Pwr, Ext/Int. Upgd. pkg,R. Bds,AIC,Tow Pkg, Rear & Slider windows,<font color="red">AMSOIL air, oil-bypass & rear end 75w-140 fluid ,<font color="blue">3/8" fuel sys w/10µ Dieselsite DAHL100 & fuel manifold/sight glass</font>,6 way dr. pwr. seat, Magnefine trans/P.S. filters</font>, husky mats,<font color="red">5 gauge A-pillar ISSPRO EVs w/Grn mkr illum. + air & fuel restriction gauges</font>,Dieselsite coolant filter and zinc electrode, manual GPR switch & GP LED, blinking security LED, weathertechs, a few other "Gadgets" [img]/ubbthreads/images/graemlins/smile.gif[/img], & a 1981 26' Prowler TT(26Y)
Larry M is offline
Old 08-13-2004, 12:20 PM   #5 (permalink)
My Photos: (26)
Good luck!
Brian.
Larry
Lucky that was a flange bolt and not a head bolt. [img]/ubbthreads/images/graemlins/smile.gif[/img]
2004 Superduty CC SB 4x4 PSD 6.0 Torqshift|ISSPRO Gauges www.dieselmanor.com |Edge 4.5 lift|315/70/17 BFGs|17x10s|Xtreme SCT Tune by www.InnovativeDiesel.com |4" Cat-Back straight pipe|John Wood Built 5R110 www.jwtt.com|ARP Headbolts|Modified AIRAID Cold-Air Intake|ZOODAD MOD |Pioneer W/XM Head Unit|Alpine Amp|10" MTX Sub|440 RWHP
http://photos.thedieselstop.com/show...=36994&thumb=1
VegasSuperDuty is offline
Old 08-13-2004, 01:11 PM   #6 (permalink)
My Photos: (30)
If you drill and tap with the engine running I am pretty confident that there will be zero shavings going past(no scientific findings though). On my 03' the exhaust force was so strong that I couldn't see to finish the operation. I removed the filter lens from an old welding hood to allow me to finish.
It really feels like 125psi or so is coming out of that hole.
wifes truck 02' Excursion Limited PSD 4X4 -Quadzilla Xzillaraider module, Transgo shift kit.
06' VW Jetta TDI
06' F-750 CAT C-7 and CAT CX28 automatic transmission
CarterKraft is offline
Old 08-13-2004, 01:30 PM   #7 (permalink)
BA
I drilled&amp; tapped No grease or engine running. I then used a shop Vac to remove shavings. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Bill
<font color="blue"> F250 SD / PSD / SWB / CC / 4x4 /</font><font color="red"> Silver </font> <font color="blue"> / Med.Flint / TT Mirrors / RH Bullnose / </font> Dipricol gauges / <font color="green"> 315 BFG A/Ts </font><font color="blue">/ Bilstein shocks </font> <font color="black"> / Spray Liner </font> <font color="blue">/ Billet grille / Edge 2" Mini Spring Pack </font> <font color="orange"> /clearance lights / </font>
<font color="black"> </font> /MBRP / XM Radio / 24" wipers / PC Xtream 8085
BA is offline
Old 08-13-2004, 02:56 PM   #8 (permalink)
My Photos: (31)
Send a message via AIM to DshiftFF
Same as BAF250, Then I also used one of those teloscopic radio antenna looking magnet thingys up in the hole and probed around for shavings....
1995 2500 CTD
2001 2500 CTD
2006 2500 CTD
I see a pattern emerging here
http://www.newenglandturbodieselpowe...rums/index.php
DshiftFF is offline
Old 08-13-2004, 03:04 PM   #9 (permalink)
Did you get any shavings on the magnet?
maps
Just my 0.2¢ Take it for what it's worth!
________________________________
2003 F250 4x4 XLT Supercab SB 6.0L/TorqShift, FX4, Add On's: 285/75/16 BFG AT's, Remote start, RhinoLiner, Prodigy, Husky floor liners, Husky mud flaps, MBRP cat back (for now), Firestone Ride Rites #2071, fumoto valve, Weathertech Weatherflectors
[color:"blue"] Truck Pic's
maps6874 is offline
Old 08-13-2004, 03:41 PM   #10 (permalink)
Not my question but I have 1 more item to add. If you drill in 1/16" increments , the shavings are more like dust and not chunks.
jward is offline
Old 08-13-2004, 04:42 PM   #11 (permalink)
601HP's Avatar
Don't bother with the frustration of manifold removal. Leave it on the engine and try the method below.
Someone else suggested the following method for fines retrieval. I did it also and it works very well.
Take a 3" piece of coat hanger wire. Bend it to form an "L". Attach a small u-shaped magnet to the long end of the wire. Insert the short end of the "L" into the hole you just drilled, then slowly rotate the wire in a circle. Remove the wire and wipe off the fines. Re-insert the wire and repeat that process. Excellent clean-out results!
The magnet can be bought in hardware stores. They typically state a lifting power of about 5 pounds, if I've remembered correctly.
After the magnet work I vacuumed for the heck of it, but it probably was not necessary.
David
2004 F350 Lariat, CC, LWB, 4x4, Dually, 6.0L w/ TorqShift, 4.10 LS, Dark Charcoal Gray, Permatech sprayed liner, A-pillar pod with 3 Isspro gauges, windshield-mount gauge pod with 3 more Isspro gauges, AIC, Jason cap, and PIAA fog lamps, mounted as aux. back-up lights. Billet badges. Alpine radio, a bunch of JL Audio and Sirius stuff.
<font color="blue">Photos</font>
601HP is offline
Old 08-13-2004, 10:03 PM   #12 (permalink)
My Photos: (31)
[/ QUOTE ] Very little, mostlt dust particles, I think they were most likely the rust flakes coming off the outside of the manifold. I also drilled in small incriments. most shavings are dropping in your face.
1995 2500 CTD
2001 2500 CTD
2006 2500 CTD
DshiftFF is offline
Old 08-13-2004, 10:29 PM   #13 (permalink)
I drilled in the pipe right after the turbo...works great and I don't risk having any particles go through the turbo nor the engine!
stick is offline
Old 08-14-2004, 01:50 PM   #14 (permalink)
My Photos: (30)
But you end up with a pyro gauge that is far as I am concerned worthless except for determining if it's safe to shut the engine off. Pre turbo is the only way to go.
06' VW Jetta TDI
Old 08-14-2004, 02:22 PM   #15 (permalink)
FamilyRide's Avatar
And don't forget, (I have too [img]/ubbthreads/images/graemlins/laugh.gif[/img]) you can also use the clamp on style in the up-pipe! Very easy to drill and install....
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
