exhaust option 04 6.0 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 08-27-2004, 09:57 PM   #1 (permalink)
Hello I was woundering if any of you guys could tell me if there is a SS 4in down pipe, 5in out, with or without the cat exhaust that I could get for my 04 6.0 SC 6sp
Thank you
troi is offline
Old 08-28-2004, 11:50 AM   #2 (permalink)
Re: exhaust option 04 6.0
qwertyuiop,
Originally the systems we have were designed with a 4.0 down pipe, after a ton of looking at different Ford dealer inventories we saw that approx 20% of the trucks would have a firewall interference problem with a 4.0 so we all of ours at 3.5 and then the system opens up to 4.0 just after the cat connection. Having had both on my truck I could not see any difference in EGT's or performance either way, just a major potential problem if you happen to own one of that 20% of the trucks where it could interfere with the firewall. To date we have the ONLY no modification system that keeps the cat 100% stock and in it's original form. That helps with the warranty issue and also with emmissions testing. We do have a cat test pipe for off road and racing use as well. call us if we can help you.
Mark @ DPPI
Mark Craig is offline
Old 08-28-2004, 12:19 PM   #3 (permalink)
gos
My Photos: (22)
qwertyuiop,
We have 4" down-pipe, 5" to the tip systems for the 6.0, only in aluminized steel. Also, these will delete the cat. The price difference between 4" tubing and 5" is pretty substantial so it is doubtful you will find 5" in stainless.
We also have a 'no modification system that keeps the cat 100% stock and in it's original form' in either stainless or aluminized steel. These systems would have a 3.5" down-pipe with 4" to the tip. They are also available in duals too.
Let us know if we can help. JS.
Jerry Schmidt, GOS Performance 1-800-620-4467, Wholesale Distributors for aFe,ATS,Autometer,Banks,Bullydog,CompuStar Remote Starts,Diamond Eye,DiPricol Gauges,Glacier Pumps,High Tech Turbos,Hughes,Industrial Injection,Edge Products,Mag Hytec,Magnaflow,MBRP,Pac Brake,Pro Parts,RevTek Lift Kits,KC HiLites,RCD,Rapid Hitch,Snow Performance,South Bend Clutch, Superchips, Superlift,Weather Tech
2005 Harley Davidson F350 #226 in True Blue
GOS Racings APC PT Cruiser
gos is offline
Old 08-28-2004, 01:12 PM   #4 (permalink)
Look at Hog Performance. I just got mine yesterday and it looks incredible. The entire system is 304 stainless even the hangers. It is 4" from the turbo with a 5" tip. It looks great. Good quality. You do have to make a mod to the firewall. There is a seem that has to be ported. The system came with a DVD for intructions. Basically you are just folding over the seem. Look them up. I think you'll like it.
Stolen 10-07 (Really Sucks) 2005 Harley Davidson (blue) CC,4x4,Sunroof,SCT (Tadds), AFE, Hog (no cat) & LP
2008 FX4 Fully loaded with Sunroof SCT Livewire Extreme 300 square feet of sound detinator and an insane stereo system with Nav.
edwinh3rd is offline
Old 08-28-2004, 01:13 PM   #5 (permalink)
Hi, and Welcome.........Check out the Hog Performance system......very nice stuff.
Z
2004 F-350, CC,6.0 PSD,Torqueshift,SRW,4.88 limited,Longbed, FX4,Lariat,ALL Black,Grey Flint leather,Line-X,CarryBoy canopy,blacked out sport grill,HOG Exhaust, AirAid air system, pyro,boost,trans. temp gauges,Pro Comp 8.5 lift, Airbags,37X13.50X24 Toyo M/T.
2002 Ford Excursion Limited 7.3 Powerstroke. Dynomax Exhaust, AirAid, Edge with Attitude, 4.56 Gears,Airbags, 37X13.50X20 Toyo M/T
Big_Z is offline
Old 08-29-2004, 03:02 PM   #6 (permalink)
The Banks systems are 3.5" from the turbo, but transition to 4" as they go under the truck. They fit and sound great and come with a double wall 5"SS tip.
2001 F-250 Crew, long box, 4x4, Big Hoss level-5 Chip, Turbo Air Guide (TAG-II), Ford AIS air intake with foam sleeve, Monster exhaust, Aeroturbine, exhaust Guide, 6.0L intercooler, Di-Pricol Optix gauges, IHC CPS, Premo Oil Refiner, Banks Exhaust brake, SmartLock, Banks Quick Turbo, Six-Gun.
2000 Excursion PSD limited, Banks Big Hoss level-5 Chip, Turbo Air Guide (TAG-II), Banks Transcommand, UNI 2-stage foam air filter, 4" aluminized exhaust with 4" down pipe and 2 Aeroturbines.
97 F-250 Powerstoke 4x4 Banks Power Pack etc.
2006 VW Jetta, PD TDI, not modified yet[/i]
carnut57 is offline
Old 09-03-2004, 08:54 AM   #7 (permalink)
They do emmission testing on diesels in your state? [img]/ubbthreads/images/graemlins/confused.gif[/img]
2004 SD F-250 4X4 Supercab 6.0 - TorqShift
Dark Green Satin Arizona Beige Met Accent Lariat 142" WB Styleside Pkg 608A, 3.73 LS 8800# GVWR, Electronic Shift on the fly, Telescpng TT mirr-powr/HTD, FX4 pkg, Skid Plates, Adj. Gas/Brake Pedals, Reverse Aid Sensors, Hitch Reciever 15K, Heated Seats - Ford bed liner - EGR Bug Deflector - Window vents - Billet grill - Mud Flaps - Locking Fuel Cap - Bull Ring stake pocket tie downs - Isspro gauges EGT, Trans Temp, Turbo Boost, Cubby Gauge pod - Sirius Radio - Rancho RS9000X Shocks
1995 Green Taurus SHO mini-mods
1988 Arrest Me Red Corvette 380rwhp many mods
green_mule is offline
Old 09-03-2004, 09:50 AM   #8 (permalink)
First off enjoy your ride and second you have asked one of the great questions of our time. You will find that there are as many opinions on which exhaust system is best as there are stars in the sky on a cold winters night. After an extensive search I found that the guys at DPPI were the most helpfull and knowledgeable so that's the main reason that I have purchased everything for my trucks from them. This will probably cause a dozen flaming resposes from folks wanting to defend there selections but call the vendors, talk to them and then make an educated decision.
Duke Jim
'04 F-250SD, Crew Cab, SWB, King Ranch, DPPI T-304 Turbo Back, Autometer A-Pillar w/ EGT, Boost & Tranny Temp, van Aaken smart box, with more goodies to come (My Sunday Truck) Lost in Katrina
'97 F-250SD, Extended cab, long box, 4.10, WD down pipe, WD 75 hp chip, WD Air filter, Autometer A-Pillar gauges w/ EGT, Boost, & Tranny Temp, cat-less, 296,250 loving miles, 5th-wheel. (My daily driver, 212 miles round trip to work each day) Lost in Katrina
'95 Chevy C-1500, Silverado, Std Cab, Short Bed, Preditor Custom, tricked out, 350 ci - 350 hp Chevy Crate Motor to replace the original 305 (My Cruizin Truck) Lost in Katrina
'90 Miata, Summer time fun car - Lost in Katrina
'00 Triton 22 Sea Flight w/ 200hp Mercury Offshore EFI, T-Top, & loads of electronics - Lost in Katrina
'00 26' Wildwood 5th Wheel - Lost in Katrina
Aphrodite 101 - 32'-6" racing sail boat - Badly damaged in Katrina
jag969 is offline
