Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
I was wondering something. I like the compatibility of MBRP Systems and I like the way the Hog Performance exits the truck. Does Hog offer a cat back? Muffler Delete? I could buy a down pipe from MBRP and Cat Delete and merge it all together. The factory compatibility of MBRP and the look of Hog as it exits. Just a thought, Chris
2004 F350 Regular Cab Long Box XLT, FX4, 6.0L and TorqShift, Manual Transfer Case and Hubs, Dark Shadow Grey Metallic, Keyless Entry, Factory Idle Control, 8 1/2' Fisher MMII, XL Steel Wheels painted Black with 285/75R16 ProComp A/T's, Rough Country 2.5" Leveling Kit.
1991 VW Jetta 1.6L Diesel 5 Speed.
Displaced '97 F-350 Powerstroke XLT, auto, 355 gears, and LT285/75R16 Cooper Discover LT's. I have a Stan's Headers downpipe. Custom built cat delete pipe. 4" exhaust exiting at a 45 in front of the rear wheel, chrome of course. Homemade open element with a K&N Filter. 8' Fisher Minute Mount SnowPlow.
You could do that if you want to get into welding and cutting to make it all fit and work etc. If you like the exit of the hog, you could easily change the angle of our tail pipe with one cut and and one weld which would be a whole lot easier that making the cat and down pipe mixed system to fit correctly etc.
As an aside I didn't think their tail pipe exit was much, if any different than ours, so you will probably find that once it's installed you'll like it and leave it as is.
Call us if you have any questions etc.
Mark @ DPPI
DIESEL PERFORMANCE PARTS INC. 1-866-455-7788 www.DIESELPERFORMANCEPARTS.COM GUARANTEED PRICES DISTRIBUTOR of MBRP & AFE EXHAUST, EDGE PRODUCTS, SMARTY, AUTO METER, ISSPRO, & DiPRICOL GAUGES, SUPERCHIPS, PREDATOR by DIABLO, AFE FILTERS & INTAKES, PML TRANNY PANS & DIFF COVERS, ARP, FLUIDAMPR, POWERSLOT & HAWK, TS PERFORMANCE, BULLY DOG, AIR DOG FUEL SYSTEMS, BOSCH, SUNCOAST, STANADYNE AND MORE.
That's true. I like that theirs exits the truck much like your dual system, at an angle at the edge of the bumper. The stock single MBRP exits pretty much perpendicular to the side of the truck. I just like that swept look at the corner of the bumber. I wish I had a welder I would make it happen, lol. I might be able to cut that final bend of the tailpipe and get a longer tip. So many options. Thanks again, Chris
The duals do exit a little further to the rear, but the singles are quite a bit to the rear as compared to the stock system. The stock system is basically in line with the axle, the MBRP single is angled back approx 20-25 degrees to the rear.
Mark @ DPPI
