Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
I was driving home yesterday and was thinking about getting an exhuast system, then I thought why not just replace the muffler with an MBRP muffler and put a nice tip on it. I was looking at some mufflers online and noticed they all have the 4'' inlet and outlet. If I take it to a shop and have them install it would that work or would that extra half inch diameter mess me up. The reason why I'm thinking this way is I can't afford a full system. Also will it sound good? Im sure I wont improve in mileage but Im not to worried about that. I really just want the sound.
I dont know much about diesels so im going to ask more than likley a stupid question but, I saw a truck the other day and when he took off it sounded like a blue angels jet taking off, is that the exhuast or someting more?
Thanks!!!
04 F-250 Superduty
6.0L Diesel
305/75R16 Maxxis Buckshot Mudders
Black Huskey Deep Toolbox
Yeasu ft-2800 Ham Radio
Roof Mounted Antenna
2 Door Dogbox W/ Tower
The MBRP (and most aftermarket performance mufflers) are a "straight-thru" design. Meaning the inlet and outlet are in line with each other, so the exhaust flow runs in a straight line from the inlet to the outlet. Your factory muffler is not like this at all (take a look under your truck and it will be apparent). So to put a straight-thru muffler on there will take some fabricating. Furthermore, if you put a 4" muffler into a 3.5" exhaust system, you are going to create turbulence/backpressure in the exhaust system (a bad thing). The turbulence is a result of the gases entering the muffler expanding from 3.5" to 4", then being forced to reduce again to 3.5". You would be better off to have a muffler shop fab you up a piece of pipe to simply replace the muffler and leave the rest of the system alone until you put on a full aftermarket system.
The "jet" sound you heard was from a truck with the 03 turbo. The 03 turbo has a considerably louder whistle to it than later models.
__________________ 2003 Toreador Red/Arizona Beige CC, DRW, Lariat, FX4, 6.0 PSD, Torqshift, born early Feb. 03; AIC; MBRP turbo-back exhaust; SCT with tuning by Tony Wildman (Total Diesel Performance) & River City Diesel; ARP studs, 155 sticks & some other work by River City Diesel; AFE PG7; Fumoto valve; B&W hitch, Di-Pricol gauges; Voyager brake controller; DIESELSITE Coolant filter; Timbrens; Rancho RSXs; Michelin XPS Traction's; a whole bunch of "bling"; Connex 4300hp; Pioneer DEH6100BT, JL Audio 275w amp w/ 12" sub, Alpine door and rear seat speakers.
that makes sence, thanks for the info. I looked under the truck and its just like you said. oh well it was just a thought.
yeah that truck sounded sweet.
04 F-250 Superduty
6.0L Diesel
cheapest way would be to get a muffler shop to replace the muffler with a piece of pipe and then put you a nice looking tip on it until you can save up for a complete 4'' system IMO
2005 F250 King Ranch CC 6.0 SRW, 40,000 miles, westin brush guard, 8" 130watt lights, 5" MBRP turbo back exhaust, high idle switch, zoodad mod, dieselsite coolant filter
is the straight pipe to loud to crank early in the morning?
Depends on how hard you partied the previous night/morning.
I have a 4" straight piped exhaust and I use to live in a zero lot line neighborhood and I never had a complaint. I also just moved to a town with a noise ordinance and havent had a problem at all so your most likely going to be fine.
2006 CC F250 FX4, SCT X3 with custom tunes, MBRP 4" turbo back, EDGE Insight w/ EGT probe, s&b...
Also, shop around its easy to find exhaust systems for around $300, which is almost what your looking at spending for just the muffler, and a nice tip.
If money is the only thing keeping you from buying the kit you want PM me, I can work something out with one of my friends, and can probably get you a turboback kit without a tip for under $200 bucks.
2006 F250 Lariat CC/SB
Hypertech hyperpac, Studs, rough country 4-link 8" Lift, 38"x15.5" Dick Cepeks, 20x12 Rockstars, 4" Dual Exhaust, Ranch hand bumpers Front & Rear
