Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 07-25-2007, 12:28 PM   #1 (permalink)
My Photos: (6)
Fixed Blown Head Gasket, Should I run a tuner?
6 months ago, I found out my head gaskets were blown. Thought I would be out the $4,000 for having the dealership fix it. LUckily I posted and I talked to quite a few people from the site who also had the problem and with there advice had it fixed under warranty.
Now I am deciding if I should put the tuner back in. I installed arp studs and have heard that the head gaskets should not blow. I have the superchips programmer and the banks system w/ speed loader and pda system. I will most likely just run the superchips programmer as it is easier to install. (I have yet to hook the truck up with the banks system).
I guess my real question is, I didnt realize that the headgaskets would blow using a tuner, what else do you guys think will go wrong? I dont get on it too much, and the superchips programmer seems to be the tamer of tuners. The banks system might be a different story. Any comments, thoughts, or advice will be appreciated once again.
2005 YELLOW Ford F-350 Lifted 35 inch Mickey Thompsons Arp Head studs, Buswhacker Flares, Four Real Steel Light Bar, 4 Piaa 525 series fog lights, K&N Air Filter Kit, Cowl induction hood by Reflexxion, Solid billet grille $$... Sct Xcal3 w/ Xtreme Tunes, T409 cat back mbrp exhuast from Innovative. Amp research electric power steps with led light kit
All running on 100% Home-made Biodiesel! .70 a gallon! If interested in biodiesel drop me a pm.
Brentsbg is offline
Old 07-25-2007, 04:54 PM   #2 (permalink)
ebusa's Avatar
Re: Fixed Blown Head Gasket, Should I run a tuner?
I would run a Superchips Flashpaq 1805 on the Economy Setting. Do you have stock exhaust?? With a tuner, I would install at least a 4inch Turbo back system and a Pyro.
-Evan
2005 F350 Crew Cab LB FX4 Lariat
Loaded-Leather, Sunroof, Chrome Mirrors,Tow hooks
5'' Tuff Country Lift
35'' Toyo MT on Race Line Renegade 20's
AFE Magnum Force Stage II CAI
CFM+ Black Powder Coated Intake Elbow
MBRP 4'' Exhaust Turbo back, no Cat
SCT X3 Tunes by DFuser, DJ's and Innovative Diesel
Quadzilla Recon XZT Monitor (EGT,Boost,Trans)
12 Running Board Lights
Alpine CDA-9857 Head Unit w/Memphis 6x9's
Pioneer Shallow 10'' Sub speaker in UD-SW10B Box
"Driving a Superduty makes me feel funny inside"
ebusa is offline
Old 07-25-2007, 06:27 PM   #3 (permalink)
How much money did Banks give back to you for the blown engine?
'06 F-350 Lariet,CC,SB,6.0L,AT Bone Stock
colonelaberilla is offline
Old 07-25-2007, 07:58 PM   #4 (permalink)
With fresh gaskets and studs? It should be on! Get more fuel into it, raise the boost, get injectors, go run 12s. Seriously, you're good. Guys are running 50+ PSI with stock head gaskets and studs without failure. With a tuner and stock turbo the most you're going to see is 35 or less.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ Insanity Tune, FASS 195 pump, 14.2 @ 94MPH on a 1.91 60ft
'02 WRX - Outback rear disc swap, EBC green pads, pillar vane front rotors, 14.5 @ 95 on a 2.00 60ft
'87 K5 Blazer - undergoing major rehab, 383 (Edelbrock heads, Crane roller valvetrain, many tricks), Pro-Built 700R4, 2400 converter, NP208, 10-bolts (4.88s, ARB front, Detroit rear, 4340 shafts, full float rear), 4-wheel discs
'86 IROC - 350TPI (headers & bolt ons), T56 swap, 10-bolt (3.73s, LSD) 14.8 @ 98MPH on a 2.35 60ft
TKOPerformance is offline
Old 07-25-2007, 10:16 PM   #5 (permalink)
My Photos: (6)
If anything it was most likely the edge system in it before I got it, later to find out, he was a hot head. It wasnt until later I added the superchips progammer, I have not added the banks kit, I just have it in hand, debating on putting it in or just re-selling it on ebay.
Brentsbg is offline
Old 07-25-2007, 10:35 PM   #6 (permalink)
Resell it and go sith the SCT with a street tune. Your heads are fine with ARP's installed.
2003 F-250 CC FX4, RED, Casserly 190 injectors, Beans Turbo, John Wood tranny, Intercooler, NX nitrous kit, Dipricol gauges, SCT, stacked with a TS MP8, and a TS MPD with Heads up display.
pictures
DALPilot is offline
Old 07-25-2007, 10:47 PM   #7 (permalink)
Wanna bet ? I never could catch a pic with the needle straight down...but it happened all the time with the tune I was playing with at the time.
This is the best I ever caught on film:
http://www.competitiondiesel.com/for...0966Medium.jpg
...coming soon...
2004 Twin Turbo 5.9 F250
Hellmann Performance
Direct Injection Performance
TS Performance
DI Performance
Greg Hogue
Grand Rock Exhaust
Dynomite Diesel
DC Customs
UNBROKEN is offline
Old 07-25-2007, 10:52 PM   #8 (permalink)
darsey715's Avatar
you're fine now with studs. I would recommend the xcal2 though. duuhhhhh.
darsey715 is offline
Old 07-26-2007, 09:20 AM   #9 (permalink)
OneTonHillBilly's Avatar
Pick the tuner you want and TUNE IT EXTREME, RACE OR WHATEVER THE HIGHEST SETTING IS! I tow HEAVY DAILY with mine and been on EXTREME TUNE for a long time. Pukes coolant but always has.
*2007 F-350 CC*
HG's
EGR Cooler
3 Degas Bottles
Driver & Passenger Seat Leather
Trailer Brake Control System
Steering Wheel & Controls
Driver and Passenger Window Assemblies
Steering Column and Gear Shift
All Emblems Twice!
Shocks
OneTonHillBilly is offline
Old 07-26-2007, 12:05 PM   #10 (permalink)
The question is "Which tuner should I run?" not "Should I run a tuner?"
The answer is: go with a custom tuned SCT. You will love it.
Much better on the engine and tranny than say ANYTHING else.
There will be some guys that will chime in and say the Edge is just as good...but most of them have not tried the SCT.
SCT tuners can custom build your tune specific to your truck.
Roger
2004 F 250 Lariat 4x4 6.0 PSD
January 2004 Born on Date
-4 inch Magnaflow turbo back exhaust
-SCT by DJ Diesel Performance
-Quadzilla Commander
-Black 17x9 Moto Metal 951 wrapped in 295/70R17's Nitto Terra Grapplers
-Accufab Intake Elbow
-AFE Replacement Dry Filter
slow6oh is offline
Old 07-26-2007, 01:32 PM   #11 (permalink)
You are playing with fire my friend [img]/ubbthreads/images/graemlins/wink.gif[/img]
<font color="red">[b] 2003 F250
6.0 PSD XLT, 4x4 SC FX4 LT265's 3:73 LS/Torqshift
LineX Bedliner Hog Catback Exhaust Virtual Billet Grill Tranny tune by ID
<font color="blue">05/05/03 Build date
<font color="blue"> Anchors Aweigh
tincan is offline
Old 07-26-2007, 04:44 PM   #12 (permalink)
My Photos: (6)
Im the kind of guy who just wants to push and play. I dont want to have to tinker, would the sct be for me?
I already have the banks kit, should i resell, keep using the superchips, or sell both and get the sct?
Brentsbg is offline
Old 07-26-2007, 04:53 PM   #13 (permalink)
Can you do a favor for me and take a picture of your engine bay?
I've been losing coolant, but it doesn't just sit and puke fluid on the ground, it just has residue all over the driver side of the engine bay.
2006 Job 2 F-350 Crew cab King Ranch single wheel 4x4 92k
2007 Dodge 3500 6.7 4x4 14k
Former diesels: 91 D250, 93 D350, 95 F350 PSD, 96 Dodge 3500, 2000 F350, 05 D-max: Fire, 2004.5 Dodge 3500, 2005 Dodge 3500
TXGooseneck is offline
Old 07-26-2007, 04:57 PM   #14 (permalink)
I like the power on the SCT, but having to stop and change programs is frustrating for me.
My tst on my dodge was great because I could tune up or down on the fly.
Old 07-26-2007, 05:09 PM   #15 (permalink)
InnovativeDiesel's Avatar
I agree. When we could chip the trucks, like the 7.3L, you could change settings on the fly..including transmission settings.
However, changing power on the fly is a thing of past. Ford stopped installing a port that chips could be installed, so now programming is the only way. All of the modules and boxes out there don't do anything for the trans, so it's necessary to program. Even the Dodge and GM trucks have trouble with shifting now that they are fully electronically controlled.
The only other option is to use a module for power and a programmer for the transmission. It's a much more expensive route and there are drawbacks to adding power without the truck having time to learn.
Innovative Diesel Performance
410-620-3020
http://www.innovativediesel.com
The Original SCT Custom Tuning Dealer!
We are the first and most experienced custom tuner for the 6.0L truck!
*No gimmick's and no marketing ploys.*
Only the best custom tuning, from stock to highly modified trucks. We have a proven track record and tune the fastest and most powerful Ford vehicles in the industry.
IDP thrives on carrying only the best parts and great customer service. Over 5000 parts ready to ship for your diesel truck!
InnovativeDiesel is offline
