Upgrades and Aftermarket - 6.0L EngineUpgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Took some time this weekend to install the Fluidampnr. Using hand tools I was able to complete the install in 3 hours including the test ride. Initial findings: smoother acceleration, smoother sounding motor and really climbs into the RPMs. After a longer drive this morning I found that on some hills the cruise control doesn't need as much input to maintain the speed when traveling up hill. Before the CC would just put the pedal down with a BIG power surge to go uphill, now it seems to be using less input to be able to maintain the speed uphill.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some "deleted" stuff.....
How hard was it to install? Did at home or do you have access to a garage? Would like to do the same, From what I can see it looks like you have to pull everything to get at it, what short cuts did you take? Thanks
__________________ Sabre 6
2006 F250 6.0L PSD 4x4 Crew Cab SB SRW
Amarillo Pkg "Scream'n "CAV" Yellow" Black Interior
Accufab Intake Elbow, Zoodad Mod, Fog Light Overide Mod,
Harpoon Mod, RECON Cab Lights, Fumoto'd
Work In Progress:
Aux Backup Light Mod
Bypass Oil Filter
Lift & Tires
Too much more to list...
Army~Air Cav/Attack Pilot OH-58/AH-1/AH-64 "You Can Run But You Can't Hide..." Gary Owen!!! Fast Guns!!!
Everything was done in the driveway with a creeper and hand tools. I drained a gallon of coolant, removed the coolant hoses, removed the fan shroud, left the cooling fan in place, and removed the harware for the secondary shroud. I used some bolts to help keep the balancer from turning when I R&I the balancer. I just went slow since I didn't have air tools...worked out just fine. Let me know if you need some help, I'm in the Richmond/Tidewater/Northern Neck area.
