Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 11-09-2004, 01:20 PM   #1 (permalink)
Ford Gold Security/remote start system question
This system was installed aftermarket by authorized Ford installers. When first installed, I could leave my truck running and by taking the key fob remote with me, I could lock the doors remotely with the engine running. I can no longer do this. Is this something that can be fixed? I can do the hit the remote start with the engine running and take the key out and lock the doors trick ok.Any help would be appreciated. 2003SC
deerby is offline
Old 11-09-2004, 02:08 PM   #2 (permalink)
FamilyRide's Avatar
Re: Ford Gold Security/remote start system question
To do that you are supposed to hit the remote start button first, then pull keys, lock and leave. It then shuts off at whatever you have the remote start interval set at: 10 or 15 minutes. I forget what the manual calls is, something like "Quick Stop" feature. Either way, you should NOT be able to just pull the keys and leave it running.
2004 EB Excursion, 4x4, 6.0, everything but step tubes and 2nd row chairs, Magnaflow Exhaust, Isspro Gauges in an under cubby pod, Fumoto sitting on V Codes and Revo 285's.
FamilyRide is offline
Old 11-09-2004, 03:40 PM   #3 (permalink)
GEARJAMMER's Avatar
My Photos: (9)
How much did that cost you?
Shawn
2008 F-450, 4 X 4 with 4.30's, auto with manual transfer case with factory cup holders. All options except sunroof and nav. Line X with Extra. 24K Draw-Tite Signature Series Fifth Wheel Hitch. 65 Gallon KSH Marine fuel/tool combo in bed. Viar 480C compressor with 8 gallon tank. Hadley Air Horns hooked up to Auto Mate alarm.
PICTURES
GEARJAMMER is offline
Old 11-09-2004, 07:21 PM   #4 (permalink)
Dieselgem's Avatar
My Photos: (14)
If you need me to copy the manual and email it to you let me know. Be glad to help.
2008 F450- Truck Pictures
2008-41'CKS KZ Escalade Toyhauler
Toy Hauler Pictures
Dieselgem is offline
Old 11-09-2004, 10:15 PM   #5 (permalink)
My Photos: (9)
I have the gold remote system. To use the "quick stop" feature, you hit the lock button, then the start button, then the horn chirps. You then remove the key and you have the option to lock the doors. Sounds like you need to have it checked out if it is'nt doing this.
2004 F-250 XLT Crewcab in Dark Shadow Grey with a '04 6.0L Powerstroke born on 10/07/03 and everything on it except moonroof and FX4 pkg., has Bilstein shocks, Westin step bars, Issipro guages, Vision camper shell, Ford Gold remote starter, sirius satellite radio, Diamond and Xtreme amps powering 2 10" Diamond subs and a Kenwood excelon Navigation system. Towing a 2005 29' Keystone Outback 5vr with a Super Slide slide. My Truck
My Photo Gallery here at TDS
2000 Ford Taurus SE (My commuter) 24V Duratech engine, Auto with 6 disc Alpine changer, Interfire 250 watt amp, Orion 60 watt amp, and 1 12" Diamond subwoofer.
unchingono is offline
Old 11-09-2004, 10:56 PM   #6 (permalink)
FamilyRide's Avatar
I actually have the programming/installation manual in pdf format that I can send as well.
Old 11-11-2004, 07:05 PM   #7 (permalink)
Familyride:
That manual may help, can you send it to me?
deerby27@localnet.com
deerby is offline
Old 11-11-2004, 10:03 PM   #8 (permalink)
FamilyRide's Avatar
Familyride:
On the way...... [img]/ubbthreads/images/graemlins/wink.gif[/img]
Old 11-15-2004, 07:48 PM   #9 (permalink)
Familyride:
Familyride,
If you have already sent it, I did not get it. Can you send it again?
Thanks,
deerby
deerby is offline
Old 11-15-2004, 09:12 PM   #10 (permalink)
FamilyRide's Avatar
Familyride:
Familyride,
Thanks,
deerby
Yep, I sent it on 11/11 at 9:04 PM. I just sent it again.
Old 11-15-2004, 09:22 PM   #11 (permalink)
DO you guys have the part number on the ford gold security/remote start system, i want to stick with a stock system and this one sounds great.
thanks a lot
2005 F-250 Crew Cab 4x4 6.0L
1998 F-150 Flareside Fabtech 6inch lift
05superdutyTD is offline
Old 11-16-2004, 01:02 AM   #12 (permalink)
For the 2005 units it is called the PowerCode - Remote Start, Keyless Entry, Vehicle Security. Ford part number is 2W7Z-19G364-AA. MSRP is $272.70 from Fords accessory web site.
Hope this helps.
Bill
Received from Bobby @ Sunrise...
2005 F350 CC Lariat LWB, 6.0L, AT, 3.73 LS, Lariat Luxury, Chrome Cab Steps, Block Heater, AM/FM 6 Disc, Stablizer Package, Rear Vehicle sensor, 12.5K Hitch, Towcommand system,Adjustable Gas/Brake. ARE K Series Cap with Bedrug bedliner.
BillD is offline
Old 11-17-2004, 01:35 AM   #13 (permalink)
thanks a lot bill im gona see if i can order it i know dealer cost is 189.00 now that i got part number so i gona see how cheap i can get it [img]/ubbthreads/images/graemlins/smile.gif[/img]
Old 11-18-2004, 10:49 PM   #14 (permalink)
Can it be had cheaper than MSRP? If so where?
If you can read this, thank a teacher, THANK A VET. it's in English: 04/04 F350 6.0 PSD Lariat CC 4X4 LB SRW Auto 3.73 rear end. All options except:moon roof-PTO-roof lights. Mods... MBRP,Line-x, White nite, Windows double tinted, 3 DVD system, Highway products 5er box, Pro-comp leveling kit, Pro-comp wheels/tires, MX-6 shocks,Viper 791XV remote start security system,Line of fire,Fumoto oil drain plug,Alaska tent and tarp bug screen,Rapid hitch drop hitch,Cobra 29 CB, Norcal Powerstrokes Member #5 http://www.norcalpowerstrokes.com/Events.html
SAVAGESAM is offline
