essentially you use the existing wire to turn on a relay that you tie into the battery. The existing wire is somewhere around an 18 or 22 ga wire, can't deliver much umph to the lights. Also there is a mod to have the low beams stay on when you put on the high beams. do a search. I no longer have the file on my computer or I would attach it. Its easy to do and there is, or were, people making the harness as a kit
03 XLT F350, CC, Toreador red/silver ,6.0, Auto 4X4, Extang Tonneau. Magnaflow xl turbo back, homemade headlight harness, VR shackles ,harpooned tank, 24" wipers, X-Monitor,FS bypass filter
