which fuel pressure gauge? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 03-19-2010, 10:59 PM   #1 (permalink)
wldwilliam's Avatar
I have the Insight to monitor almost everything else but would like to monitor f/p in the cab as well...
mechanical or electric? - leaning toward electric as I had a tough time with an isolator on a previous truck
is 0-100 psi the range needed? - I have seen some guys mention their f/p some times goes above 60 on a stock system...
what brand is prefered?
why are the electrical f/p gauges so freakin' expensive, $200+, compared to oil pressure units?
Thanks,
2005 F350 | Lariat | CrewCab | 4x4 | 6.0 | 5 spd auto
Edge Insight & ScanGauge II monitors | Autometer FP gauge | DieselSite Coolant Filter | DR 2.5" level
18x10 Weld Evo Cheyenne 8 | 325/60r18 ProComp XAT | Upfitter Switches added | Extang Trifecta Tonno
Amp Research PwrStp | high idle mod | Ford F/P reg mod | latest EGR valve
03/06, 9K miles
oil leaks (r&r rear main seal and cam sensor), recall 05E16 (ECM recalibration), recall 05B32 (de-gas bottle fill level label applied & coolant level adjusted)
06/07, 22.5K miles
no 4x4 (r&r left side vacuum hose), e-brake malfunction (r&r parking brake ratchet assembly)
01/10, 30K miles
oil leaks (r&r bed plate, rear main, rear cover gaskets & o rings), CEL (r&r reman turbo, drain tube, update processors)
03/10, 30.5K miles
EOT +15°>ECT (r&r oil cooler, egr cooler, degas bottle & cap)
[all under warranty]
wldwilliam is offline
Old 03-20-2010, 07:14 PM   #2 (permalink)
Rollin Smoke Diesel's Avatar
The Isspro electrical fuel pressure gauge is around $135. I prefer electrical over mechnical as you will need a isolator and will be running a 50-50 mix of anti-freeze through tubing into your cab unless you go bareback and run straight diesel.
James
RSD
Your Powerstroke Diesel Performance Store
Fast, Honest and Friendly Service
219-851-1195 M-F 9am-5pm CST, Online Ordering 24/7
Authorized H&S Performance, Innovative SCT, Spartan, Elite Diesel, FASS, Casserly Injectors, Edge, SBC, S&B, AFE, Isspro, DDP, Flo Pro, Trusted Performance, MBRP and many of the leading names in the industry!
Rollin Smoke Diesel is offline
Old 03-22-2010, 12:38 PM   #3 (permalink)
Isspro
James
RSD
I am also thinking of installing one, the Isspro EV2 Fuel Pressure Kit 0-100PSI, Includes 1/8"NPT Pressure Sensor $132.91. Is there anyone useing the Dieselmanor Bullet Aluminun fuel filter cap or one like it with 1/8" sender port on the top of lid. This looks like it would be an easy install.
2 Stroker is offline
Old 03-22-2010, 05:35 PM   #4 (permalink)
teamroper60's Avatar
Taking a fuel pressure reading from the fuel filter cap is on the wrong side of the filter.. You need to put the sensor into the fuel pressure test port next to the return line.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 03-22-2010, 11:41 PM   #5 (permalink)
prohydroracer's Avatar
What TeamRoper said.
And go electrical gauge, no need for chemicals in the cab, especially 60psi of diesel fuel
2004 F-250 Lariat Ex-Cab Long Box
  • ARP Stud's
  • MBRP 4" Turbo Back
  • Oil and Coolant Bypass Filters
  • SCT w/Custom Tunes
  • Fuel Pressure, HPOP Pressure, Boost and EGT on the A-Pillar
  • Edge Insight monitors EOT, ECT, Tranny Temp
  • Full Security with Remote Start
  • Anti Hi-Jack Device by GLOCK!
prohydroracer is offline
Old 03-23-2010, 12:28 AM   #6 (permalink)
test port
teamroper60
New to this 6.0 stuff and trying to do it right and only 23000 miles on a 06, the test port it is, just have to find it. Do you have any pic or sights where I can see what you are refering to. You guys are the best when a person needs help. Thanks 2 Stroker
Old 03-23-2010, 12:44 AM   #7 (permalink)
teamroper60
Do a search for fuel pressure gauge, there are tons of pics on here. The test port has an allen plug in it. It is near the bottom of the filter/regulator housing facing toward the front of the motor. You can see it without removing anything.
You will need a 12mm x 1.5 thread pitch adapter to get to 1/8"npt. I would recommend using the hose that ITP Diesel sells, it make's it quick and simple.
  • ARP Stud's
Old 03-23-2010, 12:46 AM   #8 (permalink)
You can see the location of the fuel pressure test port in the top pic here.
pics
#43
Old 03-23-2010, 02:01 AM   #9 (permalink)
port
You guys are the best, thanks for the heads up. Like to do it right the first time. 2 stroker
Old 03-23-2010, 02:23 AM   #10 (permalink)
hose
Is this the hose that you are thinking of from ITP. I wish I new more about this but the only way you learn is to ask.
6.0L Fuel Pressure Adapter 2 stroker
Old 03-23-2010, 04:48 PM   #11 (permalink)
Yep!!! That is the one. If you buy this hose, it comes with the metric adapter you need to fit your regulator housing, and gets the sensor away from the heat and vibration of the motor.
  • ARP Stud's
Old 03-24-2010, 01:41 AM   #12 (permalink)
mittto's Avatar
Ditto to what Roper says, I went with the IssPro 0-60 Gauge and the ITP adapter. They do seem to be expensive but all done all through it is not but a couple of bucks more than one injector.
My 2 cents
Torey
'05 F350 CC LB Lariat 3.73's
DieselSite Coolant filter
K&N Intake
Accufab Intake Elbow
FoMoCo Updated regulator spring
4" MBRP Turbo Back
Edge Juice W/Attitude
Isspro F/P and Tranny temp gauge
35" Toyo MT's
Bushwacker "Extend-A-Fender" flares "Thanks to Matt and the Bushwacker crew!!" Painted to match by my good friend Brandon @ Sandy AutoBody.
Firestone Ride-Rite air bags
Mag-Hytec Diff covers
Killer Sound System
BulletProof EGR cooler, new factory oil cooler, ARP Headstuds, factory HG's, STC fitting update, Updated Turbo drain pipe, Turbo rebuild, Injectors tested and new o-rings, all @ 109K.
mittto is offline
Old 03-25-2010, 02:44 AM   #13 (permalink)
Thanks everyone , I know what I need now, more $$$$$$$$$$$$$ Thanks
Old 03-25-2010, 06:53 AM   #14 (permalink)
i am using the billet aluminum cap on the fuel filter housing with a sender on top. i am getting readings between 48 and 53 all the time, cruising when under load or not almost always at 50. why is taking the reading from this top port incorrect ? it is showing a lower pressure or higher pressure ? thanks in advance for the reply. i was told that using the billet cap was the easiest and cheapest way to go.....
2006 F350 4X4 6.0L Lariat Crew Cab FX4 SRW
Edge Insight with EGT probe
Autometer Fuel Pressure Gauge / ITP Adapter Line
Amsoil EaBp 100 ByPass Filter
Ford Fuel Pressure Blue Spring Kit
ITP HFCM Brass Drain Plug
Fumoto oil drain valve
born 10/2005, in service 8/2006
bought by me Jan 27th 2010 with 54K miles from first owner; Bill, RIP.
just rolled 110K miles DEC 29th 2011
willingtonpaul is offline
Old 03-25-2010, 08:22 PM   #15 (permalink)
Measuring pressure at the cap gives an indication of inlet pressure to the filter housing. The reason that pressure needs to be monitored is so that you have an indication of what pressure that fuel is delivered to the fuel injectors at. Some pressure drop occurs as fuel flows through the filter and as the filter accumulates more dirt the difference from inlet to outlet gets higher meaning that outlet pressure lowers.
2007 F350 XLT 4x4 SC 6.0 PSD No Mods *Traded*
2011 F250 XLT/FX4 4X4 CC 6.7L PSD
johnny87 is offline
