i am not a mechanic, but my dad is a retired one. he looked over my shoulder as i did the spring changeover. if i can do it, anyone can; he just sat there and listened to me talk to myself. the only trouble i had was getting the nut on the fuel return line to break free. i applied just a little heat it and popped loose. i had the HFCM drained, and the upper fuel bowl empty as well. took me about an hour to replace the spring and the plate, etc.
as teamroper said, i guess you can do the spring without removing the line, just don't replace the plate. replace the spring only. then the job would be like 30 mins. or so max. i think. biggest pain was the radiator hose for me.
2006 F350 4X4 6.0L Lariat Crew Cab FX4 SRW
Edge Insight with EGT probe
Autometer Fuel Pressure Gauge / ITP Adapter Line
DieselSite Coolant Filter
Amsoil EaBp 100 ByPass Filter
Ford Fuel Pressure Blue Spring Kit
ITP HFCM Brass Drain Plug
Fumoto oil drain valve
born 10/2005, in service 8/2006
bought by me Jan 27th 2010 with 54K miles from first owner; Bill, RIP.
just rolled 110K miles DEC 29th 2011
