Upgrades and Aftermarket - 6.0L EngineUpgrading or adding OEM or aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
In the cooling flush write up he says to use an o-ring in place of the gasket. Does anyone know what o-ring to use?
2006 Amarillo CC 4X4
Magnaflow Turbo Back Duals
Superchips Flashpaq
AccuFab Power Elbow
Sinister Coolant Filter
Frantz Bypass Filter
Ready Lift 2.5"F 2.0"R Lift
Rancho RS5000's Shocks and Stabilizer
TOYO 35x12.50x20 Open Country MT
2008 Job2 Air Dam
Blue Spring FPR upgrade
ATLAS 40 FICM from Ed at FICMREPAIR
5/8" id x 3/32" or 1/8".3/32" or 1/8" is the diameter of the rubber axial cross section
Thanks 05harley
Superchips Flashpaq
AccuFab Power Elbow
2008 Job2 Air Dam
I'm a little confused on these. What model should be installed in the engine block for draining?
What model should be installed in the Radiator?
What model is for the oil drain?
Thanks Guys!
2005 F-250 Lariat SuperDuty CrewCab 4x4, Dark Shadow Gry, 6.0L PSD W/TorqueShift Auto, Moonroof, Power Rear Sliding Window, and with every other option!
"If you want to kick the Tiger in his A_$_$, you better have a plan for dealing with his teeth" - Tom Clancy
"A law is valuable not because it is the law, but because there is right in which it was written."
"The best of all governments is that which teaches us to govern ourselves, for the goverment is us; we are the government, you and I."
