Upgrades and Aftermarket - 6.0L EngineUpgrading or adding OEM or aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
i have about 4-5 thousand dollars to spend on my truck for reliabilty and performance..including labor. i have a bullydog tuner on the truck but it broke and is now stuck on the tow tune. had a guy try replace an injector for me and made the problem worse. at first it just sputtered until it warmed up and now it blows blue smoke and u can here the turbo more then normal.. i also at times can feel the transmission slip when the tranny get hot from having fun wit power.
my question is what are the upgrades i should do to my truck for more reliabilty and performance..
06 ford powerstroke 2"inch lift xd series dick cepek fc2 w/ sct custom tunes, 4" turbo-back mbrp exhaust.
Get rid of the bully dog programming. Head studs and an EGR fix. Wish i had the cash for those...
'05 F250 6.0l Lariat Crew Shorty Dark Stone FX4
AFE, MBRP single 304 4"w/ Cat test pipe,
Overhead Auto Meters
Diesel Site coolant filter, Leveled
35x12.50x20 ATZ's on Ultra Mako's
Innovative Diesel SCT X3
Running Eric's X Street tune
i wouldnt use diesel power to guide you. if it were me i would get the tranny issues figured out asap. next i would get the truck operating properly as dumping money into a broke truck with out fixing problems will be a real waste of time. if you want longivity then what you need to do is a coolant filter, remote oil cooler, ccv mod. if you are looking for power then you want to get a proper tuner (sct or spartan phalanx) any box tuner will not be able to compensate for larger injectors and turbos later down the road. given the issues that you stated you are probably looking at 4-5 grand to fix the exisitng problems. there are alot of good articles on what color smoke and what is the cause if you search. i know the power bug is bad but adding power to a broke truck is a expensive lesson
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
iam trying to fix the truck with aftermarket parts.. i know that number 4 and 6 injectors are dead. so that where my money will be going first to replace them. should i rebuild them or get aftermarket replacement injectors?
