head studs - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 07-29-2007, 08:04 PM   #1 (permalink)
fdny136's Avatar
head studs
I am going to pull my cab this weekend and do head gaskets and studs.some say do one at a time and you will be fine?this truck is a 2006 wont puke stock but with insanity tune it whistles and pukes.any tips or procedures.should I go to ford and get stock gaskets ? should I go arp or h11 ? who has a good price on these items?thanks
1999 f350 cc dually 4x4 (sold) - 2002 f250 cc 4x4 (sold) 2004 f350 dually 4x4(sold) 2006 f250 king ranch cc 4x4 . 6.0(sold) 2011 f250 lariat cc 4x4 rhino liner,titan tank,coastal lockpic,hid projector retrofit,icon 2.5 lift, rear blocks adjust trackbar and icon shocks
fdny136 is offline
Old 07-29-2007, 11:04 PM   #2 (permalink)
Smiley1's Avatar
Re: head studs
Stock or not, if it whistles and pukes I would change the head gaskets. If your going to change the head gaskets then you need to check the flatness of the heads and block. I am pretty confident that you will be doing it over again if you dont do it right the fist time.
JMHO.
2004 F250 CC FX4 / 46g Transfer Flow / ARP Studs / Coolant Filter / CCV
2004 Surf Side 30' pull trailer
1999 Pontiac GTP modified
1968 Pontiac Firebird (restored)
Smiley1 is offline
Old 07-29-2007, 11:34 PM   #3 (permalink)
Re: head studs
ARP studs were $540 from Summit Racing shipped. PN is ARP-250-4202. If you already have a blown gasket I'd get Ford to do the repair. The rumor is that the new TSB regarding blown head gaskets is calling for head replacement. Apparently they have found that many trucks that have blown head gaskets also have cracked heads.
If you're out of warranty then I would pull the heads and have them maged for cracks. If they pass make sure the decks are flat, if not have them milled.
Stock gaskets and studs are good to over 50PSI, so I think you're good with that combination as long as everythign is flat and nothing is cracked.
'06 F250 4x4 - 5" Flo Pro exhaust, SB Filter intake, Accufab elbow, Edge Evolution (monitoring only), SCT w/ Innovative Diesel custom tune, FASS 195 pump, 14.2 @ 94MPH on a 1.91 60ft - Eric swears it'll run 13s with the new tune, but haven't made it to the track yet
'02 WRX - Outback rear disc swap, EBC green pads, pillar vane front rotors, TXS UP, TXS TBE, TXS TMIC, Perrin lightweight crank pulley, PPG billet steel shift forks, ACT Streetlite flywheel and clutch kit, K&N filter, STi Group N motor/tranny mounts, TiC/Kartboy rear diff mounts/subframe lock bolts/outrigger stiffeners, Kartboy SS & all shifter bushings, custom PDX tune loaded via Cobb AP - went 14.1 on a terrible 60ft before most of these mods; shooting for 13.50s
'87 K5 Blazer - undergoing major rehab, 383 (Edelbrock heads, Crane roller valvetrain, many tricks), Pro-Built 700R4, 2400 converter, NP208, 10-bolts (4.88s, ARB front, Detroit rear, 4340 shafts, full float rear), 4-wheel discs
TKOPerformance is offline
Old 07-29-2007, 11:41 PM   #4 (permalink)
Re: head studs
540 shipped?
Holy crap...call Doug at gogodiesel
954-275-6801
...coming soon...
2004 Twin Turbo 5.9 F250
Hellmann Performance
Direct Injection Performance
TS Performance
DI Performance
Greg Hogue
Grand Rock Exhaust
Dynomite Diesel
DC Customs
UNBROKEN is offline
Old 07-29-2007, 11:46 PM   #5 (permalink)
Re: head studs
Why? Significantly cheaper?
Old 07-30-2007, 11:13 AM   #6 (permalink)
Re: head studs
hey check out ebay. i got mine new and paid 470 plus shipping.
safety20 is offline
Old 07-30-2007, 01:04 PM   #7 (permalink)
Re: head studs
Can someone shed some light on the difference between ARP studs and the H-11s elite offers? I see the H-11s have higher strength and are more expensive. Is the added strength worth it?
2006 F-350 172" WB (crew cab) 4x4 Lariat White
MBRP 4" "Cool Duals"
SCT from ID - Tow Aggressive, Street and Xtreme Street
Anvil II train horn and air system by Siege Engineering
Autometer gauges (EGT, Trans, Boost)
Intake elbow
3.73s
Ford4Eva is offline
Old 07-30-2007, 07:03 PM   #8 (permalink)
Re: head studs
The H-11 studs may have a higher tensile strength. Personally I've used ARP fasteners is every engine I've ever built and never had a failure of any kind with their products. That's reason enough for me to go with them in my 6.0.
Old 07-31-2007, 12:45 AM   #9 (permalink)
Re: head studs
so what is the tourque spec on the arp studs?
superdoody is offline
Old 07-31-2007, 07:50 AM   #10 (permalink)
Re: head studs
The studs themselves will go in hand tight, and then backed off 1 to 1.5 turns. They are actually left slightly loose. Then the nut is torqued down. I will post back with the spec when I get my studs, probably Wed or Thurs of this week.
Old 07-31-2007, 02:13 PM   #11 (permalink)
sootballz's Avatar
Re: head studs
I belive its 265 ft lbs.
2004 for CC SB white leveling kit plus alittle. 35 toyo'MT's on 18's, Fox 2.0 res. shocks,Air Bags, Edge Juice Attitude Platinum "hot", Dual diamond eye exhaust, Afe stage 2 Intake, ATS tripple loc TC,ATS input shaft, Red Eagle clutch upgrade, transgo shift kit, Shift pressure with HP on the Platinum, Bypass oil filter, FASS fuel system, 90 Hp DDP injectors. ARP head studs. Stage threee fuel system upgrade. 03 turbo...gota love the whistle.
1989 Ford F800 5YD dump truck, 6.6L inline 6 brazilian Diesel, ddp injectors, 5 inch exhaust.
sootballz is offline
