Head Studs... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 11-23-2008, 09:10 PM   #1 (permalink)
str0kin it's Avatar
Head Studs...
Just wondering about the cheapest way to have the heads studded... I can do most of the simple work on my truck but i dont have the equipment to lift the cab... anyone who has had their truck studded i'd appreciate if you told me how you had yours done, or the cheapest way to do it... for example did you just blow them and pay the ford tech a few hundred cash and sneak it in under warranty work, or did you have to pay for the labor from a shop? any help would be nice
'06 F-250 King Ranch CC 4x4 ... 8" Fabtech w/ Radius Arms... 22x12 Weld Cheyenne 8's on 37 Toyo M/T's... AFE Stage 2 ... 4" MBRP straightpiped ... custom tuned x3... KickAss stereo (4 JL 10w3's powered by 1000w JL mono amp, 4 pairs Focal KF speakers with JL 450/4 highs amp and Pioneer in-dash 6.1" touchscreen w/DVD)... Viper Security System ... And TRAIN HORNS...
str0kin it is offline
Old 11-24-2008, 12:14 PM   #2 (permalink)
jwoodard's Avatar
My Photos: (5)
Thumbs up Studs
I had my studs installed by the dealer when they were replacing the head gaskets. Most dealerships will do the studs (if you provide them) while doing warranty work at no additional cost.
2004 F-250 HD Edition 4X4, 6.0L PSD
Banks Big Hoss Bundle, SCTX3 with tunes by Eric
ARP Head Studs, Oil by pass
Pioneer AV1C with in dash Navigation system, Back up cam, XM Radio and IPOD connection, after market speakers and sub-woofer with amps
jwoodard is offline
Old 11-24-2008, 02:18 PM   #3 (permalink)
str0kin it's Avatar
thanks for the info... i figured they probably would but i dint know if they would void your warranty after doing it... thanks man
Old 11-25-2008, 03:08 PM   #4 (permalink)
They won't replace head gaskets again under warranty after the studs go in because it is no longer Ford spec. I have seen a number of posts with relatively mild trucks still puking after studs were installed because the tolerance spec Ford uses to determine the flatness of the head surface sucks. I have seen .004 variance diagonally across new Ford heads and Ford just slaps them on because it meets there spec. Anybody with any sense would have heads like that decked.
PGreenSVT is offline
Old 11-29-2008, 12:28 PM   #5 (permalink)
I Was Told By The Tech At My Dealer. That If This Happen's Again To Make Sure That I Bring It Back. And Not To Go To Another Dealer. If I Was To Take It To Another Dealer, And They Reported That The Studs Were Not Oem. My Dealer Would Have To Pay Back The Money They Were Paid For The Repair.
I AM IN NO WAY A EXPERT ON IN AUTO MECHANIC'S, BUT AFTER THREE 6.0 I HAVE BEEN WELL SCHOOLED BY MY FORD TECH. BLOWN HEAD GASKET'S, REPLACE HEADS, CHECK BLOCK FOR WARPING AND NO GREATER VARIANCE DIAGONALLY .001. I DON'T THINK ALL THE PUKING AFTER STUD'S WERE INSTALLED ARE A RESULT OF THE STUD'S. I THINK THAT THE SURFACE OF THE BLOCK WERE WARPED.
KEEP IN MIND THAT MOST OF THE TECH'S AT YOUR LOCAL DEALER ARE SHOOTING IN THE DARK. THIS ENGINE WAS OUT BEFORE MOST TECHS WERE TRAINED ON THE
6.0. AND FORD WAS JUST THROWING PARTS AT THE TECHS. I HAVE FOUND THAT IF THE EGR IS PULLED AND BLOCKED OFF. THE 6.0 ACTS LIKE A DIFFERENT TRUCK.
RACERXF250 is offline
