Go Back   Diesel Forum - The Diesel Stop.com > 1999-2007 Super Duties > Upgrades and Aftermarket - 6.0L Engine
Upgrades and Aftermarket - 6.0L Engine Upgrading and adding aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
Old 11-27-2006, 09:29 PM   #1 (permalink)
Head Studs; Need a Shop/Dealer! Please Help
Hi All,
I have an ’05 6.0 F350 with approx. 10k mi. and need a bit of help. I plan on adding a Banks Technicooler, Power elbow and Monster Exhaust with an SCT Xcal II custom tune.
I would like to know how prominent the loss of head gaskets are among 6.0’s and if I should worry with installing head studs and fresh gaskets. I don’t know that they are worth it at this power level, or if they are more for piece of mind.
In any event, I am looking for a competent dealer or independent shop in the Southeast. I would like to have head studs installed in my 6.0 and want it done right. I also am looking to have some fittings in the oil pump replaced to prevent future failure. Ideally, I would like to have someone that is both proficient in the 6.0 and is used to removing the body to do the head studs.
I would prefer to find a highly competent/laid back dealership that is mod friendly and could perform the stud install, as well as total service.
Any Ford dealerships in AL/MS/GA/So. TN or the panhandle of Florida, will be considered. Please inform me accordingly. My local dealers are used to doing quick fixes on company trucks in my area.
Also, for all of you that have installed studs/gaskets, please let me know what you used and what combo seems to be working the best.
Any suggestions would be greatly appreciated.
mblgjr is offline
Old 11-28-2006, 11:04 AM   #2 (permalink)
Re: Head Studs; Need a Shop/Dealer! Please Help
The Navistar service package is the best out there as far over the counter parts. The Ford kit does not use studs and nuts. Ford dealers did have an option to use the Navistar kit but that was because the Ford part was on National Backorder. If the supply chain has caught up with demand they may not have that option any longer.
2006 F-250 FX4 Crew
Bully Dog PMT with Clint's Magic Tune
Bully Dog RFI
MagnaFlow 4" Polished SS Exhaust
Top Gun Bumper Replacements
Eagle Wheels w/Nitto Grapplers
2007 Mustang GT Convertible
SCT Livewire
Corsa Axle Back
Ford Motorsport CAI
"Mom likes it"
New Grandkids Hauler!
2008 Expy Limited
SCT XCal3 w/L&L tune
MagnaFlow Exhaust
Cannonball Run in the rear DVD
Some Guys need Viagra, Diesel Smoke works for me!
LariatTrucker is offline
Old 11-29-2006, 09:39 AM   #3 (permalink)
You have two choices. You can do all your performance mods and just drive the truck, if you do encounter a problem with coolant then at that time you can put studs and gaskets in. The other option would be to put the studs in now before you have to do gaskets. Your options for install are either lifting the cab off, pulling the motor and doing the studs externally, or pulling the A/C evaporator box and doing it in the chassis.
Tadd
Elite Diesel Custom Tuning www.elitedieseleng.com
tadd@elite-diesel.com
1-866-631-8518
Elite Diesel SCT Tuning for 6.0 and 7.3's with Cylinder Pressure Adjusted tunes, Programmers or 6-position chips, Custom 6.0 Injectors, 2 Stages of 6.0L Fuel Systems, H-11 Head Studs, Fire Ring Kits, Single and Compound Turbos for the 6.0L, Engine Internals
04 F350 XLT SPORT CC DRW
Elite Diesel SCT Tuner,AFE Stage 2, 345cc Injectors, 6" Stacks, S400 turbo. 701hp on #2
Look in the september issue of Diesel Power Mag.
Ford Senior Master Technician
TaddL is offline
Old 11-30-2006, 04:20 PM   #4 (permalink)
Thanks guys.
What Navistar service kit are you in reference to?
mblgjr is offline
Old 11-30-2006, 04:28 PM   #5 (permalink)
Navistar makes a service kit for 6.0L engine head gasket issue. I think someone actually posted the part number on here in the last month or so.
2006 F-250 FX4 Crew
Bully Dog RFI
SCT Livewire
Corsa Axle Back
Ford Motorsport CAI
"Mom likes it"
2008 Expy Limited
MagnaFlow Exhaust
Old 11-30-2006, 04:32 PM   #6 (permalink)
Yeah I work for Bully Dog, enjoy the view!
view of you in my rear view??? Sorry i had to jump on that one lol lol
robert
ELITE DIESEL
join the elite
04 F-350 CC DRW, Black outs, gn hitch, Elite custon tuning, Elite stage 4 injectors, Elite fuel system, One big turbo, 2 stage NOS, 2500rpm converter, AFE Stage II intake. 12.537 at 110mph 6kfeet and 8k pounds. 13.05 #2
Tow rig
06 cc drw, fully loaded.. Elite custom tuning, exhaust, AFE intake, soon to have elite stage 3 injectors and experimental elite compounds
www.elite-diesel.com
AllDiesels is offline
Old 11-30-2006, 09:59 PM   #7 (permalink)
I will be installing Hypermax gaskets and head studs. I am going to use a coustom SCT tune.
From what the ford mech told me it takes about 12hrs to put a set of head gaskets in. He says if I buy the parts it is 50$ per hr. I thought that is not to bad. 600$ for labor. He has done them a lot so he knows what he is doing.
2003 6.0L xlt, ex cab, shortbed, 4X4.
SCT tuned from Innovative Diesel 413RWHP
jesshwarren is offline
Old 12-02-2006, 02:24 PM   #8 (permalink)
jesshwarren
From what I understand, 12 hours is a very good time for that job and a $50 shop rate is well below average. If you know the guys does quality work, I do not think you can beat that [img]/ubbthreads/images/graemlins/smokin.gif[/img].
TasMan
2004/04 Engine,King Ranch,F-250,4x4,SWB,3.73 LS, Adjustable pedals,Reverse sensor,Moon roof,clearance lights, Power rear window,Heated seats,Bedliner, DPPI T-409 Turbo Back, AFE Pro-Guard7, C-Bet'r mirror, Fumoto drain valve, AIC, Extange Tonneu, Lund SS Interceptor, Siver Star Bulbs, Harpooned tank, SUV double wiring harness, Bright Box, Clifford RS 3.5 alarm, 3" Edge Plush Ride, Bilstein Shocks, Westin Sportsman CPS Grille Guard, XM Commander wired in with a PIE Adapter, Eagle 137 series rims and Bridgestone Revos 285/75-16, Husky Liner Mud Flaps.
http://community.webshots.com/user/tasman3721 UpDated 27 October 2005
Retired Chief Warrant Officer 4
tasman is offline
Old 12-02-2006, 09:42 PM   #9 (permalink)
Yea thats what I thought. He says a day and a half that should be close to 12hrs, I plan on 800$ at the most for labor.
I known him for like 5 years he is the only guy at the ford garage that works on the diesels and knows what he is doing.
Old 12-03-2006, 03:06 AM   #10 (permalink)
and your gonna share his name and dealer so we know if we need to see him right?
HideOut is offline
Old 12-03-2006, 08:36 AM   #11 (permalink)
HA!
Yea if you are close to NW PA. I'll let you guys know how much it runs once it is done. It should only run like 600$ according to him for labor. I will know for sure once it is done.
BTW shouls I go with hypermax or the updated headgaskets.
Old 12-03-2006, 09:17 AM   #12 (permalink)
I'm close enough to N.W. Pa. that I am real interested in his price.
2005 Ford Excursion 6.0 PSD, Rancho 9000 Shocks Timbrens
2003 Ford Expedition
Sunnybrook 3310 Bunkhouse Hensley Hitch Yamaha YG2800i
Clevelandjim is offline
Old 12-05-2006, 03:24 PM   #13 (permalink)
Anyone have suggestions for someone a little further south?
I'm in Birmingham/central AL.
mblgjr is offline
