How to access turbo up-pipe? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 10-24-2008, 11:43 PM   #1 (permalink)
After crawling around over/under/all around my engine I've finally given up and thought I'd post here for a solution...
I want to access the area where the exhaust comes up from the manifold and goes up to the turbo on the passenger side. Specifically the exhaust up-pipe to EGR cooler flange. I looked and it seems the only way possible might be to remove the passenger side inner fender well and tire and get in there from the side. Has anyone accessed this or replaced an up-pipe that could give me some pointers. I just don't feel like spending a weekend removing the turbo, etc... just to get in there.
And no, I don't need to remove the up-pipe completely. Just loosen it a little. Now that I'm out of waranty, I just have something I need to install in there.
Thanks in advance for the help.
2003 F250 Lariat CC SRW 4X4, 6.0, Auto
dacunn is offline
Old 10-25-2008, 08:16 AM   #2 (permalink)
HeavyAssault's Avatar
My Photos: (6)
You got the right idea for access to the pipe. You will need all the extensions you can find to help make it easier to get to the top of the pipe. I would suggest your plans include some welding.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 10-25-2008, 01:15 PM   #3 (permalink)
Welding even for just the disk? I was told it just fits in the recess of the tube where it Y's off the the coler, and bolts back in place. I have an 03, so I don't have the restrictive diverter thing inside the tube...
dacunn is offline
Old 10-25-2008, 05:00 PM   #4 (permalink)
My Photos: (6)
It will still allow some heat to enter the EGR cooler so welding has it's advantages.
Old 10-25-2008, 05:43 PM   #5 (permalink)
soflasmoker's Avatar
My Photos: (9)
Feedback Score: -1 reviews
Yeah i would weld it in.
00 f250 xlt crew cab 4x4 7.3 psd
sct programmer, 4in banks turbo back exhaust, 6in suspension lift with 35in terra grapplers on 18in 05 king ranch rims SOLD!!!
05 F250 Lariat Crew Cab FX4 6.0, SCT Xcal2 with custom tunes from Direct Injection Performance, bullydog outlook monitor, 4in MBRP turbo back aluminized exhaust w.5in chrome stack off centered, AIRAID air intake, 4in fabtech suspension lift, 35in procomp xtreme all terrains, 20in black & chrome ULTRA rims, 2 jbl 12s, 600watt kenwood amp and kenwood ddx-712 double din head unit, 8k HID's, 2008 Tailgate, Shiny new Rapid Hitch, 08 Diff Cover (No more RTV for me check out LUBE LOCKERS), Omega train horns, viair 380c compressor, 10gal air tank and a quick connect fitting on tow hitch.
1-STC Fitting
3-EGR Coolers (And somehow its gone now)
2-EGR Valves
2-Oil Coolers
8-Injectors
1-IPR Valve
1-HPOP
Its Drinking Coolant like a mofo but oil is black as could be and no white smoke on startup?!?!?!?
soflasmoker is offline
