How much time to install gauges and 86 door chime - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 07-22-2003, 05:50 PM   #1 (permalink)
Going to install my Isspro gauges from DIS tommorrow. wondering how much time and beer it will take to get the job done? If any one has any tips or tricks that would be great. Also why I'm in there I would like to disconnect the door chime has anyone done this on the 6.0 yet? Thanks for your input.
STOLEN 2000 F250 PSD CC 4X2 LARIAT( New 6.0 Lariat on order)Arrived April 2003
jercdevil is offline
Old 07-22-2003, 06:22 PM   #2 (permalink)
guardrail22's Avatar
Re: How much time to install gauges and 86 door chime
see my album
took me about four hours
had to take time with the drilling and tapping and you can't rotate the tap wrench on the exhaust manifold.
I took the intake elbow off to tap it.
New Truck
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
____________________
2008 Carrilite XTRM5
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch,
Delivered 11/27/2002
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
guardrail22 is offline
Old 07-22-2003, 09:08 PM   #3 (permalink)
My Photos: (12)
Took me about two minutes to kill the door chime. Just pull out the key/ignition switch from column and place a piece of electrical tape over shiny metal strip on ignition switch, re-install and your done. I haven't tackled a guage install project so no input there. Good luck.
Lil_R [img]/ubbthreads/images/graemlins/smokin.gif[/img]
'08 F-350 Lariat CC LWB 6.4L PSD 4x4 Dark Torreador
'96 F-350 XLT CC LWB 7.3L PSD White/Gray
325,000+ miles
Lil_R is offline
Old 07-23-2003, 12:03 AM   #4 (permalink)
How do you get the ignition out?
Old 07-23-2003, 08:54 AM   #5 (permalink)
My Photos: (12)
On the underside of the steering column, below the ignition there are some holes. most of them are screw holes and you can see the head of the screw if you look. One of the holes is the release pin access hole. You can kinda figure it out because the correct hole seems out of place for an attachment point.
put the key in the ignition and use a stout wire (I used a large paperclip) to push the button in that hole and turn the ignition cyclinder and pull it out.
Keep in mind you can miss the release tab in the hole with the wire so feel around and go straight in. Its not too far into the hole.
This was one of the best mods I did [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2004 CrewCab 2500HD 4x4 D/A
2005 F-350 CC DRW! Tan over Black
~Hope the 6.0 is better now! [img]/ubbthreads/images/graemlins/wink.gif[/img]
bikenut is offline
