How to remove the back of the mirror - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 07-31-2003, 01:48 PM   #1 (permalink)
OK, I admit. I broke one of those lights on my mirrors.
I bought a new back for the mirror (of course you knew you couldn't just replace the lense didn't you [img]/ubbthreads/images/graemlins/rolleyes.gif[/img]!!!), but I cannot figure out how the old one comes off. I don't just want to pull on it because I figure it'll break some stupid tab the new one needs.
Please help. Thanks.
Delivered 3/6/2003: 2003 F350 6.0 True Blue CC Lariat with Sunroof, auto
newjeepr is offline
Old 07-31-2003, 06:24 PM   #2 (permalink)
Re: How to remove the back of the mirror
I hope this helps.
Removal and Installation
Tilt the exterior mirror glass away from each of the four corners one at a time, and insert a flat-blade screwdriver into the clip slot and release the clip while exerting finger pressure on the exterior mirror cover.
The small overlap ledge between the case front and the case rear can be used to prevent the clip from returning to the clipped position.
Remove the exterior mirror cover.
Disconnect the turn signal module electrical connector.
To install, reverse the removal procedure.
__________________________________________________
Y2K F250 Crew Cab, SRW, Short box, 7.3PSD, Lariat 4X4, Woodland Green, Loaded <font color="red"> Sold </font>
'04 F350 Crew Cab, King Ranch, Estate Green, SRW, 6.0('03 version), Fx4, ESOF, Short Bed, Moonroof, Tow pkg., AIC, X Monitor, CATZ Hi/Low HID Headlights, Rhino Liner, CATZ MSX Driving Lights, Pace-Edwards BedLocker, Viper 791Xv alarm/remote start, Sirius satellite radio, Cee Bailey's custom sun shades
CrewCabCopper is offline
