injector upgrades...how big??? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 11-10-2009, 02:49 PM   #1 (permalink)
Unhappy injector upgrades...how big???
Hey I got a 06 F-350 sw crewcab auto. it has a 6inch lift and 35s
it has a 4in exhaust and banks air filter and six gun tuner....
what happened is I drove it a little to hard on the insanity and blew my head gaskets and ford says my injectors are shot too.
so I'm planing to rebiuld it even better.... bigger injectors, head gaskets with studs, Egr mods and larger fuel pump....
I'd like to add a turbo sometime in the future so the question is how large of injectors can I put now without adding a turbo? I'd like to make about 600hp eventually. any thoughts on this?
I"m planing to get most of this stuff a river city diesel.
dieselmanwithatan is offline
Old 11-10-2009, 08:51 PM   #2 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
biggest injectors are most likely 180cc.. then backing the fuel off the fuel. 150cc are better but will still giver some high egts
are you running a banks tuner or custome tunes? to make 600 hp i would think at leat a 190cc injectors but with that you looking at a minimum of a 64mm turbo and a upgraded fuel system. i wont swear that will make 600 rwhp though probably pretty close though. trying to make that kind of power is going to kill any towing ability though unless you can find a good compound setup
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 11-10-2009, 11:20 PM   #3 (permalink)
yes I'm planing to put a larger fuel system in right away and right now i'm thinking the airdog FP150 would be good.... does anyone have one of these?
with the injectors what I went with a 205 mm but kept the stock turbo what would happen? is there a way I can turn down the injectors with the programer? then when I got the turbo it would be perfect.... I'm be all set to make big power....
I'm just running banks tunes now... I haven't changed anything or downloaded anything different on it yet. I have the PDA version so I have all the gauges i need right there.
Old 11-11-2009, 06:46 AM   #4 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Ditch the Banks so you can use the SCT to flow those injectors. Injectors over 190cc should be run with an upgraded turbo to flow properly.
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
