Upgrades and Aftermarket - 6.0L EngineUpgrading or adding OEM or aftermarket equipment to your 2003-Up Super Duty or Excursion with 6.0L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.0L Power Stroke engine.
So I have an 04 f250 6.0 PSD with a SCT X3 Custom tune from Innovative Diesel. I installed the Edge Insight for a monitor and the Insight doesn't allow me to select Ford Specific PIDs from it's setup display. I talked to edge and they re-flashed my Insight. Still had the same problems. They sent me a new Insight with but i continue to have the same problems. They don't know what it is. I asked 4 different techs when i called in if the SCT Custom tune would cause any problems and they all said no. so just for the heck of it I returned my tune to stock and now the Insight shows Ford specific PIDS and works as normal.
I'm sure there are other people out there that have a SCT custom tune and an Edge insight? Just wondering if anyone has had the same problems or any insight (ehhhh) as to what the problem may be.
2004 f250 CC 6.0 PSD, SCT X3 Custom Tuned from Innovative Diesel; Econ, Street, Extreme Street. Edge Insight Monitor, Zoodad Mod, High Idle Mod, Tough Country front leveling kit, 1" rear lift block, MBRP Turbo back off road exhaust kit......aka the Jet Engine!
There are a lot of people running this combo. Might have to try a different forum though. Pm me if you need info on them. I don't have the insight but I can shoot you in a good direction
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
So I talked to Edge and they said that i must be the programmer since it works when the program is returned to stock. kinda figured they'd say something like that now...even though the first four techs it shouldn't.
Talked to Innovative diesel and they confirmed that they have hundreds of setups that are running an SCT custom tune and an Insight. They have never seen this issue before. I tried another custom tune (Extreme Street instead of Street) to see if it was something wrong with the specific tune...still no luck on getting Insight to display Ford Specific PIDs in the setup.
Any ideas....
I'm still working with IDP and Edge too trying to figure this out.
Any ideas....
What did you ever figure out? I just got the Insight and I am having the same problem. In fact mine won't even communicate with the truck if the ID Tunes are installed. And I already removed my A-Pillar Gauges, so now I don't have any gauges.....Any help would be great! Thanks
__________________ 2004 F-250 Lariat Ex-Cab Long Box
ARP Stud's
MBRP 4" Turbo Back
Oil and Coolant Bypass Filters
SCT w/Custom Tunes
Fuel Pressure, HPOP Pressure, Boost and EGT on the A-Pillar
