Installed DPPI cat-back system - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 07-05-2003, 03:43 PM   #1 (permalink)
teamroper60's Avatar
After much deliberation, I decided to go with the DPPI cat-back system on my truck. I called Mark and got it on order. It arrived right on time. I jumped right on it, thinking, based on what George C had said, that it would be a snap..... my mistake....taking the old system off was a real bear!(here's a hint for any considering the removal of the factory exhaust: get your hands on a sawzall, it'll save you a ton of time!). It took me almost an hour to get the dang thing off! Once I got it off, putting the DPPI system on was pretty easy. I'd say it took no more than a half hour for me to do it and I was working by myself. The pieces fit together very nicely and everything bolts right up. Fit and finish were great.
So... now I'm done putting it on. I anxiously stick the key in the ignition and fire it up, expecting to hear a nice throaty rumble...... well, I was a little disappointed to be honest. When it initially fired, I heard a real nice rumble, but that was followed by quiet. Maybe even quieter than the OE system. So, I blip the throttle, thinking I'd hear it then..... nope, only new noise was the turbo whistle. So now I'm a little bummed, though not bad, after all, I didn't want loud. (I was hoping for a little rumble though.) Anyway, 2 long highway trips later and YES!!!!!!! it now sounds just as I had originally hoped it would. I guess it just needed to get good and warm a couple of times to get there. As an added bonus, it still is nearly as quiet as stock inside the cab (you almost feel it more than you hear it, if that makes sense.)
Now I'm a happy camper and glad I got the system from Mark. I'd highly recommend this system to anyone who wants just a hint of the throaty rumble a big block gasser has, without the obnoxious roar in the cab. Thanks Mark!!!
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 07-05-2003, 04:27 PM   #2 (permalink)
Re: Installed DPPI dat-back system
have you felt any power gains??
2005 F-350 Loaded
2004 Titanium 28E33SB Loaded
2004 Ford Ranger Edge
2004 Baja 242 Islander
2004 Polaris Predator 500(mine)
2004 Suzuki LT-Z 400(wife)
2005 Polaris Phoenix (daughter)
2004 Yamaha Raptor 350 (Daughter)
mustang02 is offline
Old 07-05-2003, 05:37 PM   #3 (permalink)
It might be just a bit quicker accelerating from a dead stop, though that's strictly feel. I didn't buy a CC dooley to drag race, so I don't figure to really notice any gains until I tow and didn't have a chance to do that yet, so I can't really say. I also noticed an increase of about 2 tenths of a mile per gallon since the last time I checked it, but that may just be because I have about 2,000 more miles on it since the last time too.
pics
#43
Old 07-07-2003, 07:52 AM   #4 (permalink)
George C's Avatar
TR,
It's the wrestling with the stock system that takes the time if one chooses to do so.
I didn't have a lift, so I cut off the tailpipe from the muffler.
It all fell apart in minutes.
Check your PM...
My 2008 F-350
KEM 345 tuned
2011 Chevy Silverado
2010 Chevy Tahoe
http://community.webshots.com/user/GeorgeC1959
George C is offline
Old 07-07-2003, 09:21 AM   #5 (permalink)
TR,
That's what I ended up having to do too. I cut it right behind the muffler and then it came apart pretty easy. (I don't have a lift either, so I did all of this lying on my back under the truck. I also noticed it was much easier to do after I dropped the spare tire.) If I'd cut the thing with a sawzall from the get-go, it wouldn't have taken any time to get the factory system off, so those of you that decide to change yours out, take it from George and me, get your hands on one and cut that pipe right off the bat, it'll save you a bunch of time.
BTW George, I read your PM, thanks!
pics
#43
Old 07-07-2003, 11:30 AM   #6 (permalink)
Re: Installed DPPI cat-back system
Teamroper,
Yep it sounds that way a lot on cold engines. It's like Ford is using the VRT turbo to close the vanes just like they used the EVB on the 7.3's during cold or mostly cold start up to help heat up the engine quicker to lower emmissions etc. It really kills the rumble till the engine is at operating temp. Once the engine is up to temp it sounds real good, especially if you wail on the loud pedal. Glad you got her all buttoned up and call us if we can help.
Mark @ DPPI
Mark Craig is offline
Old 07-07-2003, 11:18 PM   #7 (permalink)
Thanks again Mark,
The more I listen to it, the better I like it. It has a deep sound that just flat says to the world "I can move a mountain if I'm asked to". Except for the turbo whistle, the sound is almost more of a feel than a noise. It seems like you feel the deep note in your chest, more than you hear it with your ears, if that makes sense. I think it's way cool! You have to really listen to hear/feel it at all inside the cab with the windows up, cruising at highway speed, which is a plus if you are trying to listen to the radio or carry on a conversation. (Of course, if you go to WOT she'll talk to ya!)
I highly recommend this system to anyone who's looking to upgrade their exhaust. The installation of the DPPI system is a breeze once you get the old system off. The parts fit together like they should and it looks great once you're done.
Oh, and BTW, did I mention it sounds/feels way cool?? [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
pics
#43
Old 07-08-2003, 12:05 AM   #8 (permalink)
Now the next question for Mark is when will a turbo back be available for an '04 - considering this apparent new turbo mounting bracket and downpipe design?
Mark, if you want to take a road trip North, I'll supply my truck for proper fit and finish refinments. At a small discount of course. [img]/ubbthreads/images/graemlins/warmsmile.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]Hint,hint,nudge,nudge [img]/ubbthreads/images/graemlins/wink.gif[/img]
Kerry
Work Supplied: 2007 F350 XLT Ext. Cab 4x4 SRW 6.0L - solid truck, pulls great on the highway, but bush roads at low RPM, put on your Fintstone shoes to help her along.
Current:2007 Khaki Dodge 3500 SLT MegaCab SRW 4x4 5.9L CTD 6-speed handshaker, smoked cablights, front & rear Timbrens, Pacbrake, Bilstein 5100's, DSS, Recon LED's, 'E'-rated Toyo Open Country AT's 285/70 R17's, gutted cat & straight piped, modded airbox & AFE torque tube, aluminum front bumper, remote controlled aux. lighting, neoprene seat covers, Husky floor liners, Commander and XZT, AD150, 2" Leveling Kit, 80% debadged, & some bling.
Karebear is offline
Old 07-08-2003, 09:48 AM   #9 (permalink)
Karebear,
Well you have caught me off guard!! I haven't heard of a new turbo mounting set up etc. Fill in the blanks for me please, I guess I have been out in the south 40 or something.
Mark @ DPPI
Old 07-08-2003, 01:10 PM   #10 (permalink)
Mark, according to the what's new for '04 brochure, the down pipe has been redesigned to cut out some of the turbo whistle and a bracket has been added to cut down on the drone noise when at certain rpm's. I don't think there is any physical change to the demensions are mounting of the turbo itself.
Specularius is offline
Old 07-08-2003, 03:06 PM   #11 (permalink)
Mark, Spec. replied first, but to add: (It's a PDF file - may take some time to upload)
On top of page 19 of this What's New For 2004 Guide (page 20 of the PDF file), there is some information on turbo and downpipe revisions. I'm not sure if they're changing the downpipe dimensions, but it may be a possibility as they're changing the turbo mounting bracket and some angles, etc could be different.
Under the F-series trucks, starting on page 17 I believe, there is some info. on the new ICP sensor location, high pressure oil rail, etc. I don't know enough of the underhood space allocation for these parts to say whether or not their location change will change the turbo and downpipe placement even ever so slightly. However, one might be prudent to say there is a possibility....or not.[img]/ubbthreads/images/graemlins/shrug.gif[/img]
BTW, Mark, you could call it a holiday. Good hunting, fishing, and of course beer up here. [img]/ubbthreads/images/graemlins/wink.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Kerry
Karebear is offline
Old 07-09-2003, 08:30 AM   #12 (permalink)
Spec & Karebear,
Great info guys, thanks! Looks like the same system we currently have will still fit and operate like it does now. The turbo outlet and location look to be the same etc, but we'll have to keep a watch on ole man Ford to make sure. Also sounds like they are going to do what they did in late 1999 and ruin the turbo's efficiency for producing boost and possible start the surge problem that occured after the late 1999 turbo wheel change. Hope not but to quiet a turbo you have to change the blade pitch/blade quamtity and that in the past ahs reduced efficiency in the name of making it quiet. Hope I'm wrong, mine made 25 psi stock on the dyno!!!!
Mark @ DPPI
Old 07-09-2003, 09:43 AM   #13 (permalink)
George C's Avatar
I agree Mark.
I had an early 99' with the loud turbo, and it ran much stronger than my buddy's 99'5.
Time will tell, but I believe those of us with the 03' turbo will make more power than the "improved' 04' version.
It will certainly sound better for those of us who are true diesel lovers.
My turbo will make a steady 28lb stock, and 30 while towing in stock mode.
Last week while running in the 115 mode (as usual) and towing, the turbo blew the hose off of the boost gauge inside of my truck. [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]
Almost pooped my pants wondering what happened!
Over 30 lbs and pegged the gauge.
That must have led to the hose popping off.
My 2008 F-350
KEM 345 tuned
2010 Chevy Tahoe
George C is offline
Old 07-09-2003, 09:52 AM   #14 (permalink)
othrhog's Avatar
My Photos: (6)
Carefull George, You will be ordering head gaskets [img]/ubbthreads/images/graemlins/biggrin.gif[/img] Rick
2003.25 F350 SUPER CREWZER, 6.0, Lariat CC Shorty,4X4, Black with all the toys. Quad Capt seats,Chrome tow hooks. All Mod's by PRP Diesel Performance in Cincinnati, OH. More to come. I'm A Junky.
President of FOKISD http://www.fokisd.org
othrhog is offline
Old 07-09-2003, 09:59 AM   #15 (permalink)
George C's Avatar
No kiddin'..... [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
I saw that some of the really crazy NOS guys have run 45+ lb's, so I think I'm safe..
My 2008 F-350
KEM 345 tuned
2010 Chevy Tahoe
George C is offline
