Installed my bypass filter today..PICS!! - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 09-09-2008, 06:23 PM   #1 (permalink)
Post Installed my bypass filter today..PICS!!
Installed my bypass filter earlier today. Pretty straight forward job that took me about 1.5 hours taking my time. I used the amsoil kit and made a bracket out of aluminum angle to mount the filter too. I switched to synthetic oil and will start doing a UOA to see what is going on with the motor. ANy ideas on what my oil change intervals will be now?
2005 F-250 6.0
2004 Excursion Limited 6.0L sold
1990 F-250 7.3 IDI--SOLD
Myrtle Beach, SC
jdw1222 is offline
Old 09-09-2008, 09:06 PM   #2 (permalink)
sootieoil's Avatar
you will be pleased to know that the bypass filter can stay in place for years, as long as it takes to 50,000 miles, the full flow will last 25,000 miles
I would take oil samples at 20,000 mile intervals. that is only because you probably dont have the nerve to wait 40,000 miles to do a oil sample.
let me ask you this question, how long will you actually keep your truck?
I know for a fact the oil now in your truck will out last your tires...
dont worry anymore about silly lil oil changes, if you pay attention to your oil samples you will find that oil changes are for gubbmment workers
when ford ask you for oil change invoices you hand them one oil sample sheet.
to buy Amsoil please contact TDS Amsoil site Sponsor DieselManor,Dieselsite,
sootieoil is offline
Old 09-09-2008, 09:08 PM   #3 (permalink)
expertrider's Avatar
It looks good.
The filter that I got with my Amsoil Bypass kit is much taller than the one you have in your pic.
I mounted mine on under the truck on the frame rail.
I went by a local aircraft hose shop and had them make up 2- 8 foot hoses with stainless braided steel lines and red anodized fittings. It's $130 for the hoses!
Your oil bypass filter is mounted is the same place as the coolant filter kit recommends.
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 W/eXtreme tunes from Innovative,
but staying stock for now!
ARP studs installed-and new heads
EGR cooler FIXED for good!
Sneaky sneaky!
Coolant Filter
MBRP 4" Turbo Back
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
FICM REPAIR MOD
Upfitters w/ high-idle mod
40 gal aux fuel tank
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
Jimmi Jammers
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Grover Emergency Air Horns
Viair 200psi air system
Bed cover
expertrider is offline
Old 09-09-2008, 09:52 PM   #4 (permalink)
jerzydiver's Avatar
Anyone wanting a bypass kit pm me and i will be more then happy to get you what you need for a complete install at a good price.
06 F350 XLT Crew Cab LWB FX4, power Captain Chairs / Snow Plow Packsage camper package / tow command / Amsoil oil bypass filter/ Billet Badges / A Pillar Quad gauges / overhead quad gauges / ExtremeAir compressor / Trian Air Horns / FX4 package / High Idle/Aux switch mod / Go Rino Push Bar / Go Rhino Rear hitch step / Hella Black Magic Driving Lights / Rhino Lining bed liner./ MRBP Cool Duals / KC 6x9 Long Range lights mounted to Third Brake Light / Pro Comp 305 x70 R18 Xtreme Mud Terrians</p>
jerzydiver is offline
Old 09-09-2008, 09:59 PM   #5 (permalink)
jerzydiver's Avatar
Steve I am glad everything worrked out for you. Your filter is larger cause I included the largest one of the three in the kit I provide as the work longer.
Originally Posted by expertrider View Post
It looks good.
Old 09-09-2008, 11:21 PM   #6 (permalink)
It will definitely keep your oil clean but it won't help with viscosity breakdown.
2005 F-350 LARIAT 6.0 PSD SRW AUTO FX4 (removed) CC SB White, International emblems, Tow Command, Upfitters, Line-X, ScanGauge, Pioneer Appradio, Banks Technicooler and intake w/Zoodad, Dieselsite coolant filter (w/RMI-25), braided 4x4 lines, Mag-Hytec trans pan & diff covers, Fumoto oil valve (Motorcraft 15W-40), Knurled HFCM drain plug, Britebox, EZ-Down tailgate, BedStep, MBRP 5" cat-back (6" tip), Putnam class V hitch with 1upUSA bike rack, TransferFlow 30 gal toolbox tank + 46 gal midship tank = 76 gals total with Stanadyne Performance additive and FPPF cetane improver... the rest is all stock you nig-nogs. 64k miles, 1600+ hours.
Waiting for "BigTurbo" to help me install: Dieselsite Trans filter kit.
ljr869 is offline
Old 09-10-2008, 09:23 AM   #7 (permalink)
thats kind of what I was thinking since the 6.0's are so hard on oil. Guess I will get a UOA and see what going on with mine at 7500 miles
2005 F-250 6.0
Myrtle Beach, SC
jdw1222 is offline
Old 09-10-2008, 10:05 AM   #8 (permalink)
How long, depends on what oil. I would do my initial check at 5k, another at 7.5k, & one more at 10k. If all looks well, OA's every 5k. I'd change the factory filter every 7.5k & the by-pass every 15k, with make up oil as required. To my knowledge, the two best long-range oils (the most shear stable) are Schaeffer's 9000 & a Redline product. Most others (including AMSoil & other syns) shear in the first 3k, and then stabalize at a low 30wt.
I have no problems running DELO 400 to 7.5k, but I would go beyond that even with bypass due to the shearing.
OMC
OMCUSNR is offline
Old 09-10-2008, 10:35 AM   #9 (permalink)
I am running rotella Synthetic
2005 F-250 6.0
Myrtle Beach, SC
jdw1222 is offline
Old 09-10-2008, 07:50 PM   #10 (permalink)
Originally Posted by OMCUSNR View Post
To my knowledge, the two best long-range oils (the most shear stable) are Schaeffer's 9000 & a Redline product. Most others (including AMSoil & other syns) shear in the first 3k, and then stabalize at a low 30wt.OMC
OMC,
Do you recall the origin of this info? I seem to remember the same. In 2007, the Turbo Diesel Register performed an excellent study on both dino and syn oils (Issue 56 and 57). Unfortunately, since the study was specific to the Cummins, it's impossible to draw any conclusions about shear properties. Redline was one of the top performing oils in that test. However, at a whopping $35/gal., the thinking was that there were other good oils that were more economical.
Sorry...didn't mean to hijack.
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
Stewey is offline
Old 09-10-2008, 10:23 PM   #11 (permalink)
Originally Posted by Stewey View Post
OMC,
Seems like it was bobistheoilguy or maybe just here on the forums. I have seen a OA (but I don't remember where of Schaeffer's @ 10k, & it looked good).
The cost why I can't see using synthetic, at least in my situation. It doesn't get cold here, and I have no surging problems. At twice the cost of DELO, I'd need to get at least 15k out of it. If it shears to 30wt in 5k & you have to change it as often as dino, its not worth it. If however, you can go out to 20k & change annually, it would be a good investment. Or, if you're in an extreme cold area, the cost might be mitigated by the ease of starting.
Fleets use OA, bypass & extended OCI's for the cost savings. It can be done, just remember to use science, not old trucker's tales to tell you when to change.
OMC
OMCUSNR is offline
Old 09-10-2008, 10:43 PM   #12 (permalink)
RatherBNtheWoods's Avatar
If you have an "internally lubricated part"(warranty talk) failure and Ford asks for receipts to show oil changes every 5000-7500 as recommended, an oil analysis report won't suffice!
Our Raptor RV
2006 F350 CC LWB Dually XLT Oxford white manual 4x4 6.0 PSD 6 speed. 4.10 LS front and rear, Built May05. 4" turbo back, 55 gal aux fuel tank. A real pig from a stop, give me 15' and she'll slowly come to life, then watch out!
165K miles, 12 injectors, EGR cooler, Fuel pump, 8 glow plugs, GPCM, FICM rebuilt FoMoCo engine at 150K under 7/200 warranty.
RatherBNtheWoods is offline
Old 09-10-2008, 10:49 PM   #13 (permalink)
I beleive Ford will test the oil, not ask for oil change receipts
2005 F-250 6.0
Myrtle Beach, SC
jdw1222 is offline
Old 09-11-2008, 10:18 PM   #14 (permalink)
I believe you are mistaken. Mine was in the shop 2 weeks ago for injectors, and the Ford tech hotline required the service manager to get receipts from me and fax to them, before they would give the go ahead to replace more than 3 injectors.
Our Raptor RV
Old 09-12-2008, 03:55 PM   #15 (permalink)
Expertrider? Any pictures o your install??
Legend41 is offline
