Installed my bypass filter today..PICS!! - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 09-16-2008, 08:51 PM   #16 (permalink)
expertrider's Avatar
I'll work on getting some pics....
It might be a few days, I'm a little busy this week.
2005 F250 CC 4X4 Lariet
16k Reese Slider FWH
SCT x3 W/eXtreme tunes from Innovative,
but staying stock for now!
ARP studs installed-and new heads
EGR cooler FIXED for good!
Sneaky sneaky!
Coolant Filter
MBRP 4" Turbo Back
Amsoil Bypass Oil Filter w/stainless lines
IssPro A-Pillar gages
Intercooler pipe bracket mod.
Viper remote start alarm
HFCM fuel filter drain mod!
FICM REPAIR MOD
Upfitters w/ high-idle mod
40 gal aux fuel tank
Kenwood DNX7120 Navigation/DVD/iPod/BU Camera/video sytem
Jimmi Jammers
10" flip-down rear LCD screen
18" Wheels from a 2008 F250
Grover Emergency Air Horns
Viair 200psi air system
Bed cover
expertrider is offline
Old 09-22-2008, 03:06 PM   #17 (permalink)
sootieoil's Avatar
Originally Posted by OMCUSNR View Post
How long, depends on what oil. I would do my initial check at 5k, another at 7.5k, & one more at 10k. If all looks well, OA's every 5k. I'd change the factory filter every 7.5k & the by-pass every 15k, with make up oil as required. To my knowledge, the two best long-range oils (the most shear stable) are Schaeffer's 9000 & a Redline product. Most others (including AMSoil & other syns) shear in the first 3k, and then stabalize at a low 30wt.
I have no problems running DELO 400 to 7.5k, but I would go beyond that even with bypass due to the shearing.
OMC
please post any UOA on the information you provided.
I have 6.0s in service with no shearing problems and extended service...
to buy Amsoil please contact TDS Amsoil site Sponsor DieselManor,Dieselsite,
sootieoil is offline
Old 09-22-2008, 04:17 PM   #18 (permalink)
leros's Avatar
LEGEND41, below is a link to my install on the frame rail. I am not using the Amsoil bypass system I'm using the FS-2500. The pictures are a little more involved than just mounting the filter though but it does show where I put it on the frame rail. I didn't like the way the return line was to be run on the FS-2500 (an elbow into the oilpan drain hole) so I made my own return adapter that is shown in the pics. The FS-2500 people now have something like I made available but not at the time of my install.
OMCUSNR, I also run Delo and just went 9600 miles on it. My OA came back great other than a slight trace of possible anti-freeze. I think that could have been because I didn't drive the truck long enough to get it good and hot before taking my sample. Anyway, I change the OEM filter at 5K and the bypass filter around 10K. When I change oil I replace it with 14 qts of Delo and 2 qts of Lucas. Blackstone said the oil looked great especially for oil with almost 10K on it and said for me to go to 15K next time. Personally, I'm having a hard time with going that long but I'll do another OA at 5K or 7500 to see what it's doing.
Link to pictures: FS-2500 Oil Filter Bypass System-Adapter for return line Photo Gallery by Steve Orel at pbase.com
SteveO
Lemon Lawed back to Ford on 2-25-2010
04 4WD Excursion
leros is offline
Old 09-22-2008, 11:31 PM   #19 (permalink)
Oil return line
I really like your setup. I have a high flow crankcase ventilator that goes from my intake to the oil fill cap and could use a setup like you have here with the ccv and not have to sacrafice either one. I would like to know where you got these parts so I could do the same. I have an Amsoil bypass kit but have not installed it yet since I do not want to drill holes in the oil pan. One more question.
My intake is a little off and I cant get the oem ccv tube to fit, so I have a piece I cut on there but its totally kinked and probably closed off inside. Can this cause any damage to the engine if that is blocked. I need to find a flexible type of tubing that will not kink and not have a memory so I can bend it and hook it up the right way. Please let me know. Thanks
2001 Black Ford Excursion 7.3 PSD 4x4 Limited
Jobe Performance Intake
Edge Evolution with BD tunes for the 7.3 Powerstroke
2-4 inch lift with 33x12.5 BFG All Terrains
Schaeffer's 5w-40 series 9000 synthetic
Amsoil synthetic ATF in tranny and transfer case
Amsoil severe gear in diffs
Amsoil Ea oil filter
Amsoil single bypass filter kit
BD Xhale stainless 4 inch turbo back
50watt HID in fog lights, holy crap they are bright!!
I love my Excursion
MT56POWERSTROKE is offline
Old 09-23-2008, 12:51 AM   #20 (permalink)
leros's Avatar
I don't have the answer if what you are doing will hurt your engine or not, because I'm not sure what you are doing exactly! I think you sig says you have a 7.3 and I don't know much about them at all.
As for the parts that I used, I bought a new oil filler spout from the dealer (my mechanic gave me one to practice on also) and I made the aluminum piece on a lathe in my garage.
I think that you could drill and tap the plastic filler spout with a 1/4" pipe thread if your hose doesn't have much pressure. The fittings I used were 1/4".
SteveO
04 4WD Excursion
leros is offline
Old 09-23-2008, 10:42 PM   #21 (permalink)
oil return line
Thanks for the idea. Would you ever be interested in building a similar piece for a price? Your idea would work just fine too though, I just really like the way yours looks. I just really want to get my bypass filter hooked up. Let me know, yours looks very nice!
I love my Excursion
