Just installed DPPI Exhaust turbo back, now my 6.0 has a vibration now what do I do????? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 08-02-2003, 12:39 PM   #1 (permalink)
I just had the DPPI exhaust installed yesterday, and was driving it home from the shop I noticed a terrible vibration that started in the gas pedal and shakes the whole cab at higher speeds. It almost sounds like a tire rub, but I know it is not that. I even got out to look and see if something had fallen off or was dragging. Anyone have any ideas on what to look for. I am going to take it back to the shop on Monday, but if anyone has had the same experience, I would like to know what solved the problem. This is not something I can live with it is really bad..Thanx All MIKE [img]/ubbthreads/images/graemlins/shrug.gif[/img]
mikefd024 is offline
Old 08-02-2003, 02:19 PM   #2 (permalink)
Re: Just installed DPPI Exhaust turbo back, now my 6.0 has a vibration now what do I do?????
Sorry, I can't be help, but here goes:
Did you have to drop the driveshaft to install? If so, turn the driveshaft 90 deg in the yoke and try again.
05 GMC 2500HD Dmax "Casper" 11.77 @ 114.5 on fuel only
04 GMC 3500SRW Dmax "Big Blue" 13.12 @ 103 on fuel only
06 GMC 2500HD Dmax "Wendy" 12.92 @ 102 on fuel only
McRat is offline
Old 08-02-2003, 02:21 PM   #3 (permalink)
No did have to remove the drivesahft..Thanx THough
Old 08-02-2003, 02:22 PM   #4 (permalink)
teamroper60's Avatar
Are you sure the downpipe is attached properly to the turbo?? I think I recall the drone some are experiencing with their stock exhaust being attributed to the downpipe somehow. It might be possible that yours is also in the downpipe.
pics
#43
SLAPS President and Webmaster
teamroper60 is offline
Old 08-02-2003, 02:24 PM   #5 (permalink)
Could the downpipe be hitting the firewall? That would do it.
McRat is offline
Old 08-02-2003, 02:27 PM   #6 (permalink)
George C's Avatar
Your system is coming in contact with either the firewall or a frame rail. Somewhere,it's touching, and it can't...
Get under it and look, you'll find the problem.
My 2008 F-350
KEM 345 tuned
2011 Chevy Silverado
2010 Chevy Tahoe
http://community.webshots.com/user/GeorgeC1959
George C is offline
Old 08-02-2003, 03:49 PM   #7 (permalink)
After I installed mine I had a vibiration from time to time.
I loosened the turbo clamp and the next two clamps down on the downpipe and just kind of moved it around until I found the spot where I had the most clearance. Tightened everything back up and I haven't had any virbration since.
2006 Chevy Duramax LBZ
4X4 Crew Cab.
Gale Simpson is offline
Old 08-03-2003, 10:41 PM   #8 (permalink)
guardrail22's Avatar
didn't the mechanic who installed the system detect this when he test drove his work prior to signing off on it?
New Truck
2008 F450 CC Lariat White/Gold, JAD Solutions Lights, 62 Gal Titan, B&W Hitch, Gold Remote Start, TruckTrunk box, Viair 550+2x2.5gal receiver, 2010 NAV and Sync
____________________
2008 Carrilite XTRM5
Traded In Nov 07:
2003 F250 CC LB XLT 4x2 PowerStroke, Captains Chairs, White/Parchment, Torqshift, Heated Mirrors, Trailer hitch,
Delivered 11/27/2002
towing a 2005 Pilgrim 306RL-SS w/Hensly Arrow
guardrail22 is offline
Old 08-04-2003, 08:38 AM   #9 (permalink)
Mike,
GeorgeC is correct, somewhere (most likley the down pipe) the system is on the trucks frame and or engine or both. The 6.0 system is a two piece down pipe and the odds are they loosely installed it and then didn't check out all the pipes before they tightened everything for the final time. They should correct it for you and if not you will need to get under the truck and start at the front and use a flashlight if necessary to see where it's contacting the engine and or frame or both. Hopefully they will be good and take cre of you, and hopefully they didn't go Gorilla crazy with the clamps when tightening it up, it could make it tough to get it to move now if they did. Call us if we can help you in any way we will if we can.
Mark @ DPPI
Mark Craig is offline
Old 08-04-2003, 02:06 PM   #10 (permalink)
Got it fixed pretty easy just loosened the brackets and moved the exhaust around a bit, thanx all for the help, and thanx Mark for such a great product what a difference with my whole truck...
Old 08-05-2003, 08:14 AM   #11 (permalink)
Mike,
Glad you found the problem, don't you just hate to pay someone to do an installation and have to finish it correctly yourself, kind of like insult to injury isn't it!
Mark @ DPPI
