K&N filter - noisy? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 08-13-2009, 08:11 PM   #1 (permalink)
philhyde's Avatar
Question K&N filter - noisy?
Sorry if this has already been posted. I could not find anything using search.
My 2006 F250 has a K&N filter on it. I am hearing a very distinct whine/flutter at low RPM's that seem to be related to the speed of the turbo. If I didn't know better, I'd say that the K&N is not dampening this noise, wheras the factory intake would.
Is this typical of the K&N?
Thanks!
2006 F250 Crew Cab Lariat 4x4 6.0L
philhyde is offline
Old 08-13-2009, 08:26 PM   #2 (permalink)
You are correct. I had a AirAid on mine when i first bought it. I put the stocker back on. Yours is probably the open type that just fits on the end of the tube. You need one that has a box with a lid to help quiet the air.
2005 F250 CCSB FX4 Lariat Lux Pkg, Banks Monster Exhaust, Sinister EGR Delete kit, ARP Studs, Dieselsite Coolant Filter, Edge Insight Gauges, Autometer Phantom II Fuel Pressure Gauge, Blue spring upgrade, 6.4 Fuel Banjo Bolts, Upgraded HPOP fitting, Innovative Diesel SCT X3, Red Head steering box.
champelite210 is offline
Old 08-13-2009, 08:48 PM   #3 (permalink)
bugman's Avatar
My Photos: (18)
If you are not running a lot of extra horsepower you would be better off putting the stock filter system back on. It was pr oven a long time ago that it is the best filtering system for a stock or slightly modified truck with the 6.0 engine.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 08-13-2009, 08:51 PM   #4 (permalink)
philhyde's Avatar
I have the stock filter system and fully intend to put it back on. The K&N filters make me nervous anyway. I guess I should explain that I purchased the truck with the K&N filter on it already.
philhyde is offline
Old 08-14-2009, 04:11 AM   #5 (permalink)
I've got K&N style filter on my 99 and you hear alot of turbo noise. the wife says would you take off already dam thing sounds like a jet.
tinkerr is offline
Old 08-14-2009, 07:46 AM   #6 (permalink)
philhyde's Avatar
To be clear, this is not the high pitched turbo whistle, but rather a lower pitched sound that is like a harmonic frequency. It is around 1000-1200 RPM.
philhyde is offline
Old 08-14-2009, 01:19 PM   #7 (permalink)
lubbockguy1979's Avatar
Send a message via Yahoo to lubbockguy1979
The oiled k&n filters and other dry filters have caused a lot of dusted turbos on the 6.0 specifically. People have had warranty claims denied specifically because of aftermarket filter systems. The after market filters do not filter as much dirt out. Ford claims the donaldson unit (stock intake) to be 99% effecient and donaldson claims 97%. On top of this the aftermarket filter system starts to provide gains over stock and close to 3000rpms which on a stock truck or even mild mods (tuner, exaust, small turbo upgrades) will be out of the trucks actual powerband. The stock unit is capible to around 550-600 rwhp and does a better job of filtration.
2006 f250 4x4
crewcab short bed
lariat 6.0psd
auto, electric tcase
soon to have isspro
fire/air/trans/fuel
stock suspension and
pretty much everything
else
lubbockguy1979 is offline
Old 08-15-2009, 03:53 PM   #8 (permalink)
philhyde's Avatar
Today I replaced the factory air cleaner. The whining noise that I was hearing is still there. I guess I'll have to record it and get some feedback.
The truck does seem to drive better with the factory filter on.
philhyde is offline
Old 08-15-2009, 03:59 PM   #9 (permalink)
philhyde's Avatar
This description of a "siren" seems to fit the noise I'm hearing. Yikes!
Turbo whistle to turbo siren "New Findings"
philhyde is offline
Old 08-15-2009, 08:41 PM   #10 (permalink)
350r powervalve's Avatar
Send a message via Yahoo to 350r powervalve
philhide i want to tell you about my friend who has an 04 6.0 and a test by a tech at the dealer on the air going in to the motor with the k/n verses stock and the air with the k/n was 200 degees, i beleive hotter than the stockers because the engine was sucking all that hot air off the motor. i beleive he put the stock one back on and his problems went away.
2005 F350 6liter drw,longbed,4x4, crew cab lariat,gray with ground effects, rhino liner,chrome door handles, sct coming
350r powervalve is offline
Old 08-16-2009, 08:55 PM   #11 (permalink)
i used to have a noise that was a siren sound that was intermitten and the only time i noticed it was under acceleration. i first tried replacing ic boots to no avail i ended up getting a 08+ degas bottle cap which fixed the noise completely. it cost me less that 10 bucks at the dealer
2006 f250 4x4
crewcab short bed
lariat 6.0psd
soon to have isspro
fire/air/trans/fuel
else
Old 08-16-2009, 09:21 PM   #12 (permalink)
philhyde's Avatar
This is the noise.
YouTube - 2006 Ford F250
philhyde is offline
Old 08-17-2009, 02:12 PM   #13 (permalink)
Could be like an exhaust drone. Does it have an aftermarket exhaust? Maybe the down pipe vibrating off something. Check your exhaust clamps for tightness. ???? I'm just throwing out ideas.
Old 08-17-2009, 02:13 PM   #14 (permalink)
philhyde's Avatar
Dealer confirmed the noise is coming from turbo. So it's either a replacement or some kind of repair procedure (writer did not elaborate).
philhyde is offline
