Manual locking hubs - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 01-29-2008, 04:21 PM   #1 (permalink)
milo55's Avatar
Manual locking hubs
What are the advantages of manual locking hubs? I have them but hate having to get out and lock them so I can engage four wheel drive to get past a small snow patch in my driveway. Can I change these to auto?
2008 F-350 Lariat Crewcab
47000 miles loaded blue with silver
2004 F-350 Lariat Crew cab. 6.0 PSD 6 spd.Manual 175,000 miles, Muffler delete pipe, Bilstein shocks, SCT with custom tunes, Innovative.
milo55 is offline
Old 01-30-2008, 07:30 AM   #2 (permalink)
MDub707's Avatar
You could... probably going to find Ford OEM auto hubs to be quite pricey... which is why your truck probably has the the manual lockers on it now. The manual hubs are also made stronger and will hold better. I've been through a few sets of auto hubs on my other trucks, this truck doesn't have enough time on it yet, but I suspect I will one day replace these auto hubs with manual ones.
DamnKids Motorsports
-Mike-
2006 F-250 6.0 4x4
SCT Xcal2 w/Innovative Diesel Tuning 466/772 7/19/08
2005 Honda 450R - Under construction
2005 Kawasaki KLX110 - slow
tworocks - "yes I can smell it, but it smells better than my wife, so no complaints."
MDub707 is offline
Old 01-30-2008, 08:54 AM   #3 (permalink)
jdc753's Avatar
My Photos: (31)
Send a message via AIM to jdc753
As said above you can probably find em through a dealer I think they were offered, I just can't understand why. I can see auto hubs on an F150 or small suv and stuff light duty applications, but not on the heavier trucks. I was saddened when I found my truck and it had the silly electric shift transfer case (just another thing to fail) but it had manual hubs at least so I don't have to worry there.
Check the dealer they may have them, make sure you keep your old manual hubs though just incase the auto ones break, otherwise you'll be shelling out for warn hubs.
86 Ford F250 4x4 with 4in Rough Country lift and poly bushings all around converted from 351W to 6.9L Diesel (rolling chassis at the moment)
05 F350
jdc753 is offline
Old 01-30-2008, 09:06 AM   #4 (permalink)
I have the auto hubs on my '04 and this summer I will replace them with the manual ones My failed to engage a couple of times and when I tried to turn them from auto the lock I had to get a pair of channel locks to do it
'04 F250 CC Lariat 4WD SWB 6.0L 105k
Bullydog Triple Dog Downloader
AEM Intake Brute Force
'02 Saturn VUE (wife's)
'86 Mazda only 114k
Rkimmel is offline
Old 01-30-2008, 12:09 PM   #5 (permalink)
stevedunham's Avatar
My Photos: (6)
Manual Hubs are typically stronger ( but not always ) than the stock factory auto locking hubs... My factory Ford hubs were fine as long as I ran stock tires but rapidly became light duty once I lifted the truck and started running oversize tires... I've grenaded 3 factory hubs since and replaced them with WARN 31 Spline Manual hubs and then again to WARN 35 Spline Manuals when I upgraded to the Dynatrac 35 spline axle shaft stubs kit... If you look at your factory hub intenals, there are parts in there made of plastic ...! If you look at the Premium WARN hubs, they are all steel... If you don't do much hard offroading and your pretty close to stock tire sizes, auto locks might be fine for your truck... However, I believe I paid $175 each for the Factory auto locking hubs... I also have a set I'll sell 'ya cheap if you really want 'em.. Send me a PM and we'll discuss if you are interested...
** SMD '04 F250 SD King Ranch delivered 8/19/04 **
28% Tint, Leer 100XL Cap, DR Edge 8.5" hybrid lift w/ 5" rear leafs, 37x13.5x17 Swamper M16's, Draw-Tite portable winch mount, WARN xD9000i, WARN Pocket Flares w/ Durabak, MBRP Duals, 4.56's w/ F&R ARB's, original motor blown @ 31,000..! Dynatrac Dana 60 35 spline stubs kit, PIAA 520 ATPs, Xenon HID's, Powerslot Cryos/Hawk LTS, SCT X3, blown Turbo replaced with II 60FORDHY, 58V FICM PICS
stevedunham is offline
Similar Threads
Manual Locking hubs..... lmoore69 1999-2007 General Questions 5 01-04-2007 05:14 PM
manual locking hubs HELP!! skyhawk1 1999-2007 General Questions 7 11-13-2006 11:13 PM
manual locking hubs HELP!! skyhawk1 99 & up 7.3L Power Stroke Engine and Drivetrain 0 11-10-2006 08:35 AM
Manual Locking Hubs Reeftanks Power Strokes 1994-1997 General 5 12-13-2005 12:31 PM
Which manual locking hubs are best? SMF 1999-2007 Upgrades and Aftermarket - General 16 06-03-2005 06:21 PM
