More pics of work done ? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 01-16-2013, 02:05 PM   #1 (permalink)
Bsh102's Avatar
Would this be a sign that the blue spring update has already been done. I have only had this truck less than a week. Trying to find out everything that has been done to her.
2005 F250 Crew Cab Lariat 4x4
Banks 4" exhaust
EGR delete
Blue Spring update
Torque App (coolest thing I have added)
New Oil Cooler
Turbo Drain tube upgrade
Sinister Coolant filter with Cat1 ELC
Next up STC
Bsh102 is offline   Reply With Quote
Old 01-16-2013, 02:23 PM   #2 (permalink)
ford_doctor's Avatar
"Most likely" it is. Not the zip-tie but the fact that the fuel regulator cover is a lighter color than the housing is a sure sign that the cover is not stock... which likely means the cover was part of the regulator kit that contains among other things the spring. The spring was updated quite some time ago so we can be pretty safe in assuming the spring is of the updated specification. To be *absolutely* sure you could unbolt the cover and inspect... or... I would check the fuel pressure.
Ford Master Diesel Technician
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline   Reply With Quote
Old 01-17-2013, 08:06 AM   #3 (permalink)
Band_Member's Avatar
My Photos: (64)
^^^^ This.
Plus you should have a Fuel Pressure gauge anyway. Cheap insurance. Get a bad tank of fuel that clogs your filter(s) you wouldn't know it till it's too late.
2005 F250 XLT SC, LB
6.0 Torqueshift
3.73LS 4x4 ESOF
A/C, T/C
Trk Bld: 02/05/05 KY
Eng Bld: 02/03/05 Indianapolis
2450 Hrs +/-, 90K Miles - No Major Probs
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
4" Banks Turbo-Back Duals
3.5" Ready Lift
Bilstein 5100's
315 - 70R17 Duratrac's
Bodiak Front Receiver
SG2
Coolant Filter
HFCM Plug Upgrade
Blue Spring Upgrade
FP Gauge
Zerex Red ELC
2 Stroke TC-3W Oil added 1oz/Gallon Fuel
~driver like ya stole er~
Band_Member is offline   Reply With Quote
Old 01-18-2013, 05:25 PM   #4 (permalink)
Bsh102's Avatar
Band member, why are you running 2 stroke oil in your fuel ? Confirmed today that the blue spring update complete.
Banks 4" exhaust
EGR delete
Blue Spring update
New Oil Cooler
Next up STC
Old 01-21-2013, 08:54 AM   #5 (permalink)
239F-350's Avatar
hey im in sw fl too
239F-350 is offline   Reply With Quote
Old 01-21-2013, 10:11 AM   #6 (permalink)
Supporting Member
I can't answer for Band Member, but I had my mechanic recommend Amsoil Syn Sabre 2 stroke outboard oil and have been using it in all my 6.0s. The new low sulphur fuel we're getting doesn't supply enough lubrication for the injectors. Now this in only my opinion but it seems to be clearing up alot of our poor starting rough running issues. We use about 1/2 pint per 25 gallons of diesel.
Tim in Central Florida
2012 F350 CC SB Lariat Tuxedo Black w/RollnLock bed cover
2012 F350 CC Cab/Chassis with 9' Knapheid tool box
2006 F250 CC Lariat with ARE construction cap
2007 F350 CC Lariat with 8' Knapheid tool box
2006 E350 Extended Cargo Van
2005 F350 CC King Ranch with ARE construction cap
2005 E350 Extended Cargo Van
2004 E350 Extended Cargo Van
And, sorry to mention on this forum
Two 2012 Nissan NV3500 High Roof cargo vans
Cell1Diesels is offline   Reply With Quote
Old 01-21-2013, 03:52 PM   #7 (permalink)
Bsh102's Avatar
Makes sense, I am running synthetic oil in my 300 Merc for the cleaner burn and lubrication of injectors. Why not in a diesel ? My question would it not have a cabon issue over time or the higher temps of a diesel burning it off ?
Banks 4" exhaust
EGR delete
Blue Spring update
New Oil Cooler
Next up STC
Old 01-21-2013, 06:39 PM   #8 (permalink)
Supporting Member
Amsoil recommends a 300-500 to 1 ratio. I don't think it's enough to cause a carbon issue. As I said it seems to be helping my fleet and with six 6.0s I'll take all the help I can get.
Old 01-22-2013, 01:52 PM   #9 (permalink)
ifightfire93's Avatar
I just started using Opti-Lube Summer Blend. Bought a gallon for around $60.00 with shipping. Use 2 oz for 30 gallons. One gallon is good for 64 fill ups.
06 F250 FX4 CC. ARP studs, banjo bolts, Sinister EGR delete, coolant filtration, Scangauge II, blue spring upgrade, new oem headgaskets, T6 5w-40 synthetic, SCT SF3 tuner, new oil cooler. Exhaust is next.
ifightfire93 is offline   Reply With Quote
Old 01-22-2013, 02:16 PM   #10 (permalink)
Bsh102's Avatar
Are you also using a fuel additive ? Cetane boost ? These are suppose to have a lubrication additive for the injectors.
Banks 4" exhaust
EGR delete
Blue Spring update
New Oil Cooler
Next up STC
Old 01-24-2013, 02:24 AM   #11 (permalink)
Feedback Score: 2 reviews
I run the Ford stuff in every tank and once a week drive it like you stole it to keep the egr valve and turbo clean and working, and use a 5w40 syn oil with Ford filters your injectors will like you for it. Get a set of gauges, I like the Edge Insight CTS plug and play. The ScangaugeII works well also.
2 stroker
06 F350 4x4 PSD Lariat FX4 CC LB
Edge Insight CTS with Expandable pyro
AutoMeter Fuel Pressure Gauge 0-100
Sinister Fuel Pressure Adapter
Updated Fuel Reg. Kit 3C3Z-9T517-AG
WOT 58lbs Idle 62-64lbs Just Right
HFCM Water Separator Drain Plug Upgrade
Ford Cetane boost every fillup
Amsoil By-Pass(Amsoil 5w40)
Fumoto Oil Drain Valve
Dieselsite Coolant Filtration System
Dieselsite Boots
Delo ELC Coolant
Tow Command
Upfitter Switches
Pulling a 14,000 lb Alpenlite 5er
Roll-N-Lock bed cover
97 F350 4x4 PSD CC LB (sold it)
1700 Super Chip
PacBrake&ATS converter lockup
3" dp-4" exhaust
TruCool 28,000 lb cooler
Tymar Intake
A pillar EGT,Boost,Trans
2 Stroker is offline   Reply With Quote
Old 01-24-2013, 08:01 PM   #12 (permalink)
Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
This is where I got my information. Check it out.
Old 01-26-2013, 05:37 AM   #13 (permalink)
My Photos: (64)
I Started adding 2 stroke oil because I read that ULSD lacks the lubricity for the injectors that older diesel fuel used to provide.
In the 2+ years I've been adding it to the fuel I've noticed the engine runs quieter (injectors) and the engine also seems to start easier.
Other than that I've noticed no differences in performance or fuel mileage.
I also add Stanadyne Blue Label or Diesel Kleen fuel additive.
6.0 Torqueshift
3.73LS 4x4 ESOF
A/C, T/C
ZOODAD, SEIC,
Atlas 40 FICM @ 90K
3.5" Ready Lift
Bilstein 5100's
SG2
Coolant Filter
HFCM Plug Upgrade
Blue Spring Upgrade
FP Gauge
Zerex Red ELC
