Originally Posted by casperjede
Can i remove just he muffler and put a straight pipe in for now and will that void the warranty
Who has the best high flow cat?
Removing the muffler won't cause you any problems at the dealer, but might if you have a local noise ordinance. Most just leave the dealer cat on & go cat back. Some go turbo back with the dealer cat, and some delete the cat (illegally). If you go turbo back, the 4" down pipe can be a bit of a ***** to get in, but it can be done.
You don't have your truck in the signature, so depending on its MY, you may not have much warranty left.
Go with a good 4" cat back & you'll have no problems.
OMC
