Muffler Delete Pipe - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > 1999-2007 Ford Super Duties > Upgrades and Aftermarket - 6.0L Engine
Old 11-10-2008, 05:48 PM   #1 (permalink)
WhiteDiesel07's Avatar
Muffler Delete Pipe
I was wondering the negative and positive implications of going with a muffler delete pipe on the 6.0 and if the sound was worth it? If so, who carries this pipe?
2007 F250 PSD Crew Cab Lariat Banks Cold Air Intake Tuff Country Leveling Kit Line X Black Westin Sportsman Brushguard Black Westin Tailguards White Knight Reverse Lights Black UWS Deepbox Tint Muffler Delete Pipe Rolling Big Power Black Exhaust Tip 20" Rims on 285 Black Wall BFGs
WhiteDiesel07 is offline
Old 11-11-2008, 08:20 PM   #2 (permalink)
HeavyAssault's Avatar
My Photos: (6)
Negative results: Neighbors hate you in the morning....
Positive results: Increased turbo whistle, throaty exhaust sound on hard acceleration, increased street cred.....
2006 F-350 CC PSD Lariat 4X4 LB 3.73 LS
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 11-12-2008, 09:52 AM   #3 (permalink)
I appreciate the reply, Looks like the positives outweigh the negatives. I reckon the livestock will learn to get used to it. But I was wondering if you knew of anywhere online to order it? The only one I have found has been $100 with shipping and I find it hard to believe that is how much a short piece of pipe should cost.
Old 11-12-2008, 03:42 PM   #4 (permalink)
My Photos: (6)
Seems as the demand for 3.5" exhaust pipe isn't all that high so the local shops can't even bend that size. I'd ask locally first if anyone can get the pipe or at least bend it for you if you provide the materials. After that I guess you need to order the pipe for $100.
Old 11-12-2008, 06:02 PM   #5 (permalink)
milo55's Avatar
I got mine from the diesel site for 90.00. I had to have mine welded into place at a local shop. The pipe was too short to go over the existing pipe to allow the use of clamps. It does give a nice roar when accelarating at idle you can hear the turbo cycling until the egr valve cuts in then there is just a low rumble. The noise in the cab is not a problem and yes the turbo whine is much pronounced.
2008 F-350 Lariat Crewcab
47000 miles loaded blue with silver
2004 F-350 Lariat Crew cab. 6.0 PSD 6 spd.Manual 175,000 miles, Muffler delete pipe, Bilstein shocks, SCT with custom tunes, Innovative.
milo55 is offline
Old 11-12-2008, 06:35 PM   #6 (permalink)
TxPSD9673's Avatar
depends if you have an exhaust system or not. if you do companies like MBRP carry muffler deletes. if not you could always sawzaw your muffler out and weld in a straight piece of piping!
Dakotah
1996 F-350 CC/LB 5sp MANUAL 4x4 7.3 PSD 205,000 MILES
TYMAR INTAKE-PROCOMP RS9000 SHOCKS-MBRP STRAIGHT PIPED EXHAUST-TW CUSTOM TUNES-AUTOMETER GAUGES-FPR SHIM MOD-265/75/16 NITTO TERRA GRAPPLERS-16x8 PRO COMP 1069 SERIES WHEELS-RANCH HAND FULL REPLACEMENT BUMPERS-RAWSON & KOENIG BOX-12'' STAGE 3 ROCKFORD FOSGATE SUB (158.5 dB! )
COMING SOON:
ROSEWOOD STAGE 1 INJECTORS-SOUTHBEND CLUTCH
TxPSD9673 is offline
Old 11-13-2008, 02:08 PM   #7 (permalink)
Thanks for the input, one last question I found a company in Iowa that says they have a stock muffler delete pipe for the '05 for just $69 and they aren't sure if it will fit the 07. I am almost positive they are the same but I haven't had time to check but is the exhaust systems on the '05's the exact same as the '07's?
Old 11-13-2008, 02:16 PM   #8 (permalink)
My Photos: (6)
I wouldn't think the exhaust changed that much between years. Is their pipe stainless steel?
Old 11-13-2008, 04:03 PM   #9 (permalink)
The pipe they have is aluminized, do you think going with SS would be better than aluminized?
Old 11-13-2008, 05:50 PM   #10 (permalink)
My Photos: (6)
For your location I'd say not to worry about it. I'd just keep an eye on it if you are near the coast line.
Old 11-13-2008, 06:55 PM   #11 (permalink)
Alright appreciate it, Ill let you know how it turns out.
Old 11-16-2008, 01:58 AM   #12 (permalink)
As long as you are going to spend the time to go to all the trouble, I would just replace the whole exhaust from the turbo back for a couple hundred and use ss. Just me. I am sure the mufler delete works just fine also though.
Ford f350 6.0 4x4. 4" silverline turbo back, cold air intake, six speed manual tranny, sct x3, 373 rear end, running full synthetic in every part that takes oil.
mt454casull is offline
Old 11-17-2008, 12:27 AM   #13 (permalink)
Turbo Back Exhausts aren't that cheap are they?
Old 11-17-2008, 06:31 AM   #14 (permalink)
My Photos: (6)
Not T409 or T304 SS kits. Maybe some upstart company trying to get in the game? I have found piping but can't find an exhaust shop that has the ability to mendral bend 3-4" piping.
Old 11-17-2008, 08:38 AM   #15 (permalink)
FTG-05's Avatar
My Photos: (25)
$45 from my local muffler shop. Don't even have the muffler any more.
'06 F-350 SRW 6.0 PSD
FTG-05 is offline
